Im stuck need help...
Discussion in 'Off-Roading & Trails' started by silvertaco82, Jan 31, 2010.
  1. Feb 1, 2010 at 9:08 AM
    #101
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    if its near a road... claim it slid off the road due to snow
  2. Feb 1, 2010 at 10:21 AM
    #102
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Because we support insurance fraud!
  3. Feb 1, 2010 at 10:22 AM
    #103
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
  4. Feb 1, 2010 at 10:25 AM
    #104
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
  5. Feb 1, 2010 at 10:27 AM
    #105
    JimBeam
    JB
    2015 Tundra
  6. Feb 1, 2010 at 12:08 PM
    #106
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    joking:D
  7. Feb 1, 2010 at 5:34 PM
    #107
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    The story I told my insurance company (coincidentally, the truth) was that I was driving around a dirt road (no name, not on a map) that goes around a local fishing pond on base. I've been taking this route to get to fishing spots and a particular spot on the bank where I go to eat my lunch during busy days at work when I need a break for months. There have always been a few mud puddles in the trail but I usually don't even need 4WD and the hubs hardly ever get wet. This mud hole wasn't much different, just a little longer. I usually hit 4Lo and the rear locker just to be safe and never slip a tire. Well this particular day I go in, the front end gets sucked down the engine locks up and momentum takes me in deep enough to bury the exhaust too. Then I begin the half naked recovery. Well a couple weeks later a co-worker is out running around the pond and sees LMTVs...
    Visual Aid
    PRACTICING FUCKING RECOVERY TRAINING IN THE SAME MUDHOLE THAT ATE MY TRUCK. And by recovery training I mean they drive into the middle, lock up the brakes, and bury the 40 inch tires and sink it to the frame and then spend the rest of the day getting it out by whatever means necessary. So my nice innocent dirty puddle got turned into a bottomless quicksand pit.
    The claim originally went on file as flood damage, because rains has caused conditions to swell a little bit (thus not noticing new tire ruts or massive fucking changes to the hole). Then offroading damage when I couldn't produce or a street name or approximate address. Then finally after I explained the situation in a legal recorded statement, it was just an accident/water damage.
    Even still when the appraiser went out he said the truck was repairable since all the damage was in the engine, $8,000 max if they bought a brand new motor. Water wasn't high enough to get the ECU behind the dash and all the electrical was fine (cause I replaced the starter my damn self). After the insurance company was financially committed the dealership found the fried ECU and locked up throttle body. My truck should have been totalled. Now it doesn't even have a salvage title. Just an accident on record and no carpet.
  8. Feb 1, 2010 at 5:59 PM
    #108
    silvertaco82
    silvertaco82 [OP] No way, get real
    Bozeman, MT
    2010 AC TRD Sport 4x4
    TRD Seat Covers, Weathertech floor mats, Sockmonkey Decals, Pro Comp 6", 35" Nitto Trail Grapplers, 18x9 XD addicts, 20% tint, Kenwood Dnx 5120, 2 10" Kicker Shallow mount subs
    alright well took up our tractor and got my truck up in the building(butler building with big garage then two floor aprtment-sick place to spend the weekend!) to thaw out. It will turn over but not start. all electronics work fine. My subs even still work. Have diagnosed problem as the modules in the fuse box for the fuel pump and efi are out. This because no fuel is getting up to the fuel filter either because it is still frozen or one of the modules/ fuses is out. Before the truck was making no noise after warming up the starter it was able to turn over and sound like it was trying to start. So tomorrow i will change out the modules and once i get that fuel to pump through it should start. put anti freeze "heet" in gas to get any water in there out. I will change the oils after i get it running but the oil did not seem to be watered down.
    No way i could have gotten it towed tractor was only way. it was down big hill climb was able to drift it down into the creek that it was across then tow it out of there and up the hill climb. calling tow truck would have been waste of time and money.
  9. Feb 1, 2010 at 8:42 PM
    #109
    Jon M
    Jon M Well-Known Member
    SE Minnesota
    09 Tacoma SR5 TRD Sport w / Towing Pkg
    let's see some current pics
  10. Feb 1, 2010 at 9:05 PM
    #110
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    i broke a tie rod on my last truck when going through that much muddy water/soup. I had to leave the truck overnight the next day i break the ice around the truck and highlift the front out of the water, replace tie rod and lower the truck back into the waste deep freezing water. Thank god for fishing waders. i climb in truck starts up shooting water out the pipe. i back out truck runs for 10 minutes then quits. to make long story short the cat got clogged with water/mud and did not allow airflow. the o2 sensor fails adding fuel to the mix and fouls the cat along with the mud. A plugged cat will keep a truck from running.
  11. Feb 1, 2010 at 10:39 PM
    #111
    luni
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
  12. Feb 1, 2010 at 10:56 PM
    #112
    tvbd56
    tvbd56 Epic Member
    Tyler
    Sacramento, Ca
    2018 Black DCLB OR 4x4
    :facepalm:Dead H2:rofl:
  13. Feb 1, 2010 at 11:40 PM
    #113
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    whoa... you're from livermore... I was born there but lived in Oregon since about 3yrs old.
    Aaaaand back on topic in......3......2.....1..... :laugh: @ H2
  14. Feb 2, 2010 at 3:05 PM
    #114
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Hey Mike, any word on your taco? : notsure:
  15. Feb 2, 2010 at 4:54 PM
    #115
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    That sucks....fuckin' LMTV's.
  16. Feb 2, 2010 at 5:29 PM
    #116
    luni
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
  17. Feb 2, 2010 at 6:15 PM
    #117
    silvertaco82
    Bozeman, MT
    this sounds exactly like what is happening with my truck. Ordered modules for efi and fuel pump should be in tomorrow around 8 depending on this snow:cool:. So did you have to replace the o2 sensor or just unclog the catalytic converter?
    My truck was left overnight same as yours and when i go to turn it over it sounds as though the engine is not getting any fuel. changed engine oil and filter. for the life of me i cannot find the transmission stick if there is one? where is the transmission oil located?
  18. Feb 2, 2010 at 6:18 PM
    #118
    silvertaco82
    Bozeman, MT
    i will take some soon
  19. Feb 2, 2010 at 6:18 PM
    #119
    bwood_usmc
    bwood_usmc Wiskey Tango Foxtrot....
    Ben
    Clayton Ga / Clemson SC
    06 Tacoma TRD Off Road package
    3" Trux Lift, 285-75-R16 BFG All Terrains, K&N Cold Air Intake
    There is no transmission dip stick for these trucks brother:thumbsup:
  20. Feb 2, 2010 at 6:19 PM
    #120
    silvertaco82
    Bozeman, MT
    you know how to change it? couldnt find it in manual
