I'm stumped (coilovers: two choices)
Discussion in 'Suspension' started by colinb17, Aug 16, 2010.
  1. Aug 16, 2010 at 3:11 PM
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    I've done all of the thinking and research I can, but still can't come to a conclusion.
    The two sets of coilovers i'm trying to decide between are the walker evans 2.0 with the adjustable reservoir, and the walker evans 2.5 w/o reservoirs.
    this is how i see it so far, any help from people running one of these or who know a good deal about the differences would be great
    2.0 w/ resi----------
    PROS
    -12 way adjustable reservoir (in theorey this also means that with more oil, there is less of a chance of the oil breaking sown due to heat build up)
    -$100 less than the 2.5s
    CONS
    -i couldn't actually find the info, but i'm asuming that the 2.0s have a smaller shock shaft than the 2.5s (which would be more prone to bending/breaking, which i read about another member doing to this exact set of shocks)
    2.5 W/O resi---------
    PROS
    -more oil due to larger shock body (again, helps with heat build up)
    -i'm assuming a larger diamiter shock shaft
    CONS
    -no adjustable reservoir
    -$100 more
    so essentially i'm trying to figure out if the gain of going with the 2.5 outweighs the extra $100.
    oh and here's the link to the COs on all pro's site thanks for the help.
  2. Aug 16, 2010 at 3:15 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i'd go 2.5 if anything WE for the front. i've got the 2.0s non-res though, and not too impressed. better than stock
  3. Aug 16, 2010 at 3:15 PM
    tacoma44x44
    tacoma44x44 Well-Known Member
    Jamie
    Calgary, AB
    07 Dc trd
    if i was you i would get icons over W.E.'s
  4. Aug 16, 2010 at 3:17 PM
    98tacoma27
    Ben
    Not Beech Creek
    I wouldn't worry about heat build up unless you plan on running fast desert races.
  5. Aug 16, 2010 at 3:19 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    With those Prices I'd look towards Kings or Icons.
  6. Aug 16, 2010 at 5:57 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    hey, thanks guys. i know toytec has the icons, but where can you get kings for around that price? i've never seen them that cheap.
  7. Aug 16, 2010 at 5:58 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    I would not get 2.0's.
  8. Aug 16, 2010 at 6:10 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    you have a bad experience with 2 inchers, or do you just really like your 2.5s?
  9. Aug 16, 2010 at 6:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What everyone else said. Look into the Icons, Fox, or Kings. Even Sway-A-way or the 51oo CO's over the WE's.
  10. Aug 16, 2010 at 6:19 PM
    The_Hodge
    SC
    ^^ i'd take WEs over 5100 COs, but the rest are better. bad design on the 2.0s on how the mount goes from the top of the shock to the top strut mount.
  11. Aug 16, 2010 at 6:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah...Your probably right. Strike the 5100's OP :eek:
  12. Aug 16, 2010 at 6:24 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    alright, so the general concensus is no WE...so the options i'm seriously looking at are icon, fox, and king. the icons and foxs can be had for between $1000 and $1100. looks like down south has the kings for $1400. i knwo the guys at DS are great to work with, but just for financial purposes, is there anywhere else yall would suggest checking out pricewise. i recognise the kings are a higher lever shock, so it's expected they will be a little more expensive, just never hurts to ask :rolleyes:
  13. Aug 16, 2010 at 6:44 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    oops, gonna correct myself. you can get the 2.0 resi foxs for $1100. the 2.5s are actually the same price as the 2.5 kings....both with reservoirs. does this sound right? i always thought you had to dish out more for kings over fox???
  14. Aug 16, 2010 at 7:05 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
  15. Aug 16, 2010 at 7:15 PM
    Beast
    Beast Well-Known Member
    Mark
    Slc,Utah
    2010 4x4 SR5
    grillcraft, tinted windows, HID's, Magnaflow exhaust, tsb, Icon ext. coilovers,camburg uca's, oem bedmat, 5100s in rear, wheelers aal, 275/65R18 duratracs, 18x9 kmc monsters
    I would get the icons:D. i just ordered some from downsouth
  16. Aug 16, 2010 at 7:19 PM
    Jason'sLawnCare
    The icons are probably one of the best bets unless you are looking for adjustabilty(as far as dampening). Then you can get the fox 2.0's at AllPro for $1100. They have an 8 way click adjuster. I wonder how much of a difference it is from 1 to 8?
  17. Aug 16, 2010 at 7:24 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    with the 10% off code from toytec you can get them for $945. i hear ya on the not needing resis thing. it just seems like there are more options if you open up to reservoirs. in the 2.5 inch market it seems like icon and racerunner are the only onces making them without. i swear i saw a set of kings on a taco without, but i can't find them online. nothing wrong with overkill though i guess
  18. Aug 16, 2010 at 7:26 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i'm curious too...i haven't really heard anyone on here comment on htat aspect of them.
  19. Aug 16, 2010 at 7:32 PM
    SKINUM
    SKINUM Well-Known Member
    Garry
    Va/Tn/KY border
    07 FJC
    a lot!
    Anyone know why 2.5"s do not come with the adjustable dampening option?
  20. Aug 16, 2010 at 7:41 PM
    TRICOMA
    TRICOMA Tacoma with the TRI package
    Tri
    Carlsbad, CA
    2010 Tacoma DC SB 4x4 TRD Off Road
    King Off-Road Shock Coilover 2.5 with Resi in the front. King Off-Road Shocks 2.5 with Resi's for the rears, Rear Spring TSB, KMC XD Enduros 16x8, Black Vinyl Fenders, Bed compartment locks, Cobra 19 DX IV with Lil Wil mag mount antenna, CoverKing Seat covers front and rear, Built Right UCAs, Aluminess Expedition Bumper, GY Wrangler MT/R with Kevlar 265/75-16, Custom hybrid style rock sliders.
    Kings 2.5s and I love them. Downsouth can get you a good price. I can check with the truck shop too but you have to pay shipping.
