I'm stumped, please help me figure out what's wrong here
Discussion in 'Audio & Video' started by NerdAlert, May 11, 2014.
  1. May 11, 2014 at 7:17 PM
    NerdAlert
    NerdAlert [OP] Well-Known Member
    ‘17 TRD Sport DCSB 6MT
    Installed head unit, amp, sub. Wasn't my first time so I know I did it all right. Everything sounded great, until recently when I decided to add a bass knob. Now, the sub hums.
    The knob intercepts the rca cables from the head unit then goes to the amp. turned all the way down, there's no hum. Turned all the way up, there's no hum. As you turn it up it gets worse until the middle then starts dropping off until full blast when there's no hum.
    What the hell is going on here?!
  2. May 11, 2014 at 7:20 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Did you try to turn the gain down on the amplifier?
  3. May 12, 2014 at 9:09 AM
    devanb3
    devanb3 Well-Known Member
    devan
    hampstead
    where is the wire ran as compared to your other power and rcas
  4. May 12, 2014 at 10:14 AM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    Double check the connections on your knob. (Insert Butt-head snicker). There might be a stray little wire creating a short somewhere. Use a DMM to check for continuity between the terminals on the knob, especially where there shouldn't be any.
  5. May 13, 2014 at 12:24 AM
    NerdAlert
    Ran it under the cup holders but pretty sure it's away from all wires and metal (I feel like I'd notice that). I'll open everything up again tomorrow and maybe wrap all connections with electrical tape
  6. May 13, 2014 at 3:33 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Since the noise is introduced in the middle of the boosts range, I would suspect a bad booster. If it were signal related it would be consistent with the amount of boost you are feeding it.
    Also, I have not seen a boost that wires onto the RCA inputs, is this an aftermarket/universal device?
  7. May 13, 2014 at 8:14 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    ^^This.
  8. May 13, 2014 at 10:11 AM
    NerdAlert
    yep universal
  9. May 13, 2014 at 12:48 PM
    ZMan2k2
    Richard
    Under a tinfoil hat
    Is it powered? A bad ground might cause this, but if it's passive, I would say the knob is faulty.
  10. May 13, 2014 at 12:57 PM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Just a couple of further thoughts:
    - post a link, maybe someone else has used one
    - do you have a friend where you could hook this up and see if the problem follows
    - have you removed it to make sure it is the booster
