I'm stumped..
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dwill817, Jul 2, 2013.
  1. Jul 2, 2013 at 5:08 PM
    Dwill817
    Dwill817 [OP] Well-Known Member
    Drew
    Alabama
    1981 Toyota Pickup 4x4
    Hey guys,
    I'm normally an avid lurker here and around customtacos. I normally just read and learn and always search and normally find my answers but not this time. I have found myself in a bind and don't know how else to solve my problems so here goes nothing:
    2001 Tacoma 2.4L 5spd ~175,000
    My truck is skipping. Specifically on cylinder 3. It did the exact same thing about 6 months ago and I fixed it.
    So it should be an easy fix right? Well not this time.
    - changed all the plugs six months ago but changed the 3rd one today again.
    - also six months ago I changed the ignition coil on 3. Fixed it then. Well I spent another $80 on a new one today and it still didn't fix it.
    - so I pulled the fuel rail and injectors and cleaned them. Nope.
    - checked all my hoses and connections. They're all good.
    - also just put a fuel filter on a few months ago.
    Still not fixed. The only thing I haven't done is a compression test. There's no oil on the spark plugs and my valve cover isn't leaking. No white smoke, so no head gasket. Good coolant level and flow, and no overheating. I need to change my oil but its just now time. I know all that doesn't really matter but I'm checking off a list for you guys.
    Before I did all the today I had advanced check it and it said misfire on 3. The lady told me to take it to someone with a better system so I took it to a local mechanic who has one of those $20,000 Snap-On computers and all it said was misfire on 3. He told me to change the coil and plug and as a last resort clean the injectors.
    Any ideas? Before I lose my mind and I blow my savings on a 2JZE swap :devil:
  2. Jul 2, 2013 at 5:17 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, 31" tires, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    I'd replace the #3 injector, before giving up on it.
  3. Jul 2, 2013 at 5:22 PM
    Dwill817
    Drew
    Alabama
    I had considered it. Any way to check it before I spend the money? And I'm not anywhere near the giving up point. The motor will have to split in half and fall out before I swap another in.
  4. Jul 2, 2013 at 5:57 PM
    polack
    polack Well-Known Member
    swap the injector from number 3 with number 1 and see if the problem moves to number one.
  5. Jul 2, 2013 at 6:29 PM
    Dwill817
    Drew
    Alabama
    I forgot to mention that it doesn't skip until it is warmed up!
  6. Jul 2, 2013 at 6:46 PM
    rmerchant3
    rmerchant3 Insert nonsense here
    Burnt valve. Do a compression check when warm to confirm.
  7. Jul 2, 2013 at 7:26 PM
    Dwill817
    Drew
    Alabama
    I'll do a compression test in the morning and switch up the injectors!
  8. Jul 2, 2013 at 7:36 PM
    SDSam
    SDSam from Dirt bike to Dezert Couch
    San Diego
    00 Tacoma prerunner
    Icon Shocks, BTF front, Deaver f67, 33's on stocks, Fiberwerxs 1pc, TDR S/C, Bed & Eng Caged
    might have to.
    This ^^ . Compression test, vacuum gauge, leak down test, or lab scope (snap on scan tool) will help finding this type of problem.
    Good luck
