Im stumped
Discussion in 'New Members' started by Thatsahnice, Aug 6, 2024.
  1. Aug 6, 2024 at 12:44 PM
    Thatsahnice
    Thatsahnice [OP] New Member
    1997 Toyota Tacoma 2.4 alternator not charging, however the battery light isn’t on(and yes it works) also my check engine light has been on forever, but now isn’t on since the charging issue starte
    d
    buckhuntin-tacoma likes this.
  2. Aug 6, 2024 at 12:44 PM
    saajanpatel1
    saajanpatel1 Well-Known Member
    Saaj
    MA
    2022 Tacoma Limited
    None
    Are you getting any codes?
  3. Aug 6, 2024 at 12:55 PM
    Sonofliberty92
    Sonofliberty92 T O Y O T A
    Mark
    Maryland 4 South
    2014 DCSB TRD OR, 2005 Tundra V8 4WD
    How old is the alt?
  4. Aug 6, 2024 at 1:01 PM
    Thatsahnice
    The alternator is maybe 2 years old, the real question is the check engine light quit working at the same time it quit charging and for some reason the battery warning light isn’t on but is on with just the key on, I’m sure this is connected somehow. Also I do have battery voltage at the stud on the alternator
  5. Aug 6, 2024 at 1:02 PM
    Sonofliberty92
    Mark
    Maryland 4 South
    Almost sounds like you have some corroded wiring from the alt to the battery or multiple. This might explain why the truck isn't detecting weak battery.
    SecureIT2021 and Thatsahnice[OP] like this.
  6. Aug 6, 2024 at 1:52 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    Thatsahnice[OP] likes this.
  7. Aug 6, 2024 at 4:59 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Have you checked your ALT-S fuse (7.5A) and GAUGE Fuse (10A)?
    SecureIT2021 likes this.
  8. Aug 6, 2024 at 7:03 PM
    Thatsahnice
    I checked both the alternator fuses, not sure about the gauge fuse……..tomorrow is another day
  9. Aug 6, 2024 at 7:11 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    They both provide power to the alternator regulator so they are the first thing to check, Gauge Fuse is in the interior fuse box.
    If they are both good then you need to check for power on Pin 2 (Red) and Pin 3 (White) at the alternator connector with the key on.
  10. Aug 8, 2024 at 9:10 AM
    Thatsahnice
    Thanx ill check now
  11. Aug 12, 2024 at 5:04 AM
    Thatsahnice
    UPDATE!! After checking all fuses and connectors, it started working again!! I believe it was the connector on the back of the alternator ……thanx for all the help
    Sonofliberty92 likes this.
  12. Aug 12, 2024 at 10:35 AM
    Sonofliberty92
    Mark
    Maryland 4 South
    Yea figured it was a short. Good on ya.
