IMMEDIATE HELP ASAP!!! Projector retrofit and BHLM
Discussion in 'Lighting' started by jimmybee1108, Aug 26, 2013.
  1. Aug 26, 2013 at 2:25 PM
    jimmybee1108
    jimmybee1108 [OP] Well-Known Member
    JM
    San Antono
    2012 blk DC sr5 v6 prerunner
    bilstein 5100s, wheelers AALs, amazon dual 10 sub box, with two jlw1s cheap HIDs
    I have a 2012 tacoma and have done the projector retrofit and BHLM.
    To reseal i scraped out most of the stock goo as i could and placed a generous amount of the 3M window weld in the channel where the lens meets the housing.
    Went well for awhile after aiming, re-aiming, and re-aiming again.
    but now the 3M stuff isnt holding at all and the lenses have almost fallen completely off!
    i thought it might have been the reflective bowl pushing out too much, but i really dont know. if i aim them down anymore then my beam wont be high enough for any benefit.
    PLEASE HELP BEFORE I LOSE MY LIGHTS!
    anything someone can recommend besides the 3M stuff?
  2. Aug 26, 2013 at 2:34 PM
    AK27
    AK27 Well-Known Member
    Did you make sure you squeezed them together enough to engage the plastic clips? What about the three screws?
  3. Aug 26, 2013 at 3:04 PM
    XXFattyHunterXX
    XXFattyHunterXX Well-Known Member
    Westminster, Colorado
    T4R
    When sealing them up, bake them, push them together, then use clamps to hold them down, then bake again then push once more for extra measure. If it's leveled when you aim then the reflector shouldn't be pushing out too far. Also make sure the housing lock in to the tabs around the headlight like mentioned above.
  4. Aug 26, 2013 at 3:43 PM
    04TacomaLimited
    04TacomaLimited Active Member
    San Diego
    Bone Stock Tacoma Limited
  5. Aug 26, 2013 at 8:27 PM
    boltstaco
    boltstaco Well-Known Member
    eric
    oceanside, ca
    panty droppa
    AFE intake, 3" spacer w blocks in rear
    Yea what he said. I used the butyl sealant from trs and have had no problems.
  6. Aug 26, 2013 at 10:59 PM
    jimmybee1108
    JM
    San Antono
    Ill try rebaking wen I can. And making sure those clips engage. And recheck the screws. At least until the rope arrives.
    Crap-ola :/
    But thanks guys
