Imminent Crankshaft Position Sensor (CPS) failure in 2016s?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by oldschoolczar, Jul 21, 2016.
  1. Aug 18, 2017 at 8:31 AM
    #341
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    None of the visible settings (dash display defaults, radio etc) were changed when my CPS was replaced ... are they stored in some non-volatile memory or do they connect a separate battery to keep those alive? Or is there a dealer-only ECU reset which doesn't involve killing power to the whole truck? I have a Carista OBD dongle but I don't think it has that function.
  2. Aug 18, 2017 at 8:40 AM
    #342
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    In my experience, your settings must be stored in the long-term memory because disconnecting the battery only clears short-term stuff and my dash display, radio, is unchanged. Only thing I do notice from the cab is the XM seems to reset itself and take a minute to recalibrate but my account info and presets are still there when it comes back up.
  3. Aug 18, 2017 at 7:33 PM
    #343
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    The thread that links to the testing Toyota did to identify the problem and come up with some sort of fix talks about the changes to the sensor and the changes are internal and relate to circuit changes.
  4. Jan 9, 2018 at 6:12 PM
    #344
    a400ryan
    a400ryan Well-Known Member
    Garson Manitoba Canada
    2015 SR5 DCLB
    Replaced mine
    Old had no markings
    New “98” has the =
    No issues before, more piece of mind
    $195 Cdn taxes in
    Test drove 5 kms and does seem to run smoother with lower idle rpm
    Build date 01/16 Texas
    I’m happy I did it
    bshammer0, speedtre and shakerhood like this.
  5. Dec 22, 2019 at 2:17 PM
    #345
    Fabfourtacoma
    Fabfourtacoma Well-Known Member
    2016 tacoma trd off road
    3inch revtech lift 33inch durtrac w 2 inch offset fabfour front bumper 4 rigid 4x4 and a 20 inch rigid led bar
    dam thanks guys mine just went out.
    shakerhood likes this.
  6. Dec 22, 2019 at 2:58 PM
    #346
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Since there is a recall I would think it will be replaced free of charge.
    TeecoTaco likes this.
  7. Dec 22, 2019 at 3:52 PM
    #347
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Reminds me I should get this done some day
    shakerhood[QUOTED] likes this.
  8. Dec 22, 2019 at 4:14 PM
    #348
    shakerhood
    Southern Ohio
    That would probably be a good idea brother, better than having it fail at a bad time.
    TeecoTaco[QUOTED] likes this.
