Imminent Crankshaft Position Sensor (CPS) failure in 2016s?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by oldschoolczar, Jul 21, 2016.
  1. Aug 3, 2016 at 6:28 PM
    #101
    Truggin
    Truggin What a long, strange trip it's been
    Don
    39.15737720308645, -77.92212986904099
    Black 2016 TRD Sport V6 4x4 Access Cab
    It's a work in progress. See my build thread.
    My cat absolutely failed at the same time. The smell of rotten eggs was distinct.
  2. Aug 3, 2016 at 6:28 PM
    #102
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    UN-burned or raw fuel has long been the culprit of fried cat-convertors, but for them to burn out after just one instance or in such a short period is new to me. They must be making these things a lot cheaper now.
  3. Aug 3, 2016 at 6:29 PM
    #103
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Several minutes of misfires is enough to kill them in my experience. But ymmv
    The hammer[QUOTED] likes this.
  4. Aug 3, 2016 at 6:32 PM
    #104
    Truggin
    Don
    Well... My CPS failed. It went to the dealer. They diagnosed it as a bad cam gear and solenoid. Replaced those. 47 miles later it started mis-firing again, and that is when the smell made me wanna hurl.
  5. Aug 3, 2016 at 6:34 PM
    #105
    Aussiek2000
    2016 Offroad AC
    Rotten egg smell?
  6. Aug 3, 2016 at 6:34 PM
    #106
    The hammer
    And I was just thinking the newer cats are made different as of a few year ago according to something I read. In other words, looks like we're fooked!
    Hope that helps
    Cheers!
  7. Aug 3, 2016 at 6:37 PM
    #107
    Truggin
    Don
  8. Aug 3, 2016 at 6:42 PM
    #108
    The hammer
  9. Aug 3, 2016 at 7:06 PM
    #109
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yes it can, but that engine would have to be severely misfiring for a good long amount of time before it gave up the ghost. A few feet of driving while the CKP is failing should never have killed a cat converter if it is a quality one. Now if it is el cheapo made in China junk, that is a different story.
    Rotten eggs indicates an overly rich condition. Which tells me that as the CKP fails, spark is the first one to go, fuel trails right after. What you smell is mostly raw gas being spit right out of the exhaust pipe. If your cat failed at the same time as the CKP, that would tell me one of two things, either you had a defective one, or the cats they are putting now on these 3rd gens are just that cheap.
    Edit: Wait hang on. These new engines are DI. A misfire even a for a short amount of time could very well be detrimental to the cat converter.
  10. Aug 4, 2016 at 3:16 AM
    #110
    Aussiek2000
    2016 Offroad AC
    DI plus the cats are mounted very close to the cylinder head. Doesn't take much to kill them
    12TRDTacoma and The hammer like this.
  11. Aug 4, 2016 at 5:23 AM
    #111
    hoob
    hoob Member
    For those that have had the CPS failure but no cat work, would it be good to ask for a warranty extension on the emissions control system (beyond 8 years or whatever it is by default) due to the apparently high risk of contamination when misfiring?
  12. Aug 4, 2016 at 5:55 AM
    #112
    va_whitewater
    va_whitewater Active Member
    Joe
    Virginia
    2016 DCSB TRD Off-Road
    I haven't had any problems yet, but it might be time to start shopping for an extended warranty...
  13. Aug 4, 2016 at 6:12 AM
    #113
    Friggin Fuego
    Friggin Fuego Well-Known Member
    2004 Toyota Land Cruiser, 2007 Toyota FJ Cruiser 6MT 4x4, 1988 Toyota Hilux SSR Diesel 5MT 4x4
    10 counts that we know of people active on this forum. I believe the number is a lot higher. Let's say you have about 900 active 3rd gen owners on the forum and 10 reported the issue. Seems like the problem is more widespread.
  14. Aug 4, 2016 at 6:31 AM
    #114
    Truggin
    Don
    If our sampling is representative, then it would be 1 out of every 90. So if 500,000 sold, that would be about 5,555 of them failed. That's a lot. One would think if they have seen 5K failures, they should be well aware of the issue. So why are dealers having trouble diagnosing? :confused:
    Friggin Fuego[QUOTED] likes this.
  15. Aug 4, 2016 at 6:35 AM
    #115
    Truggin
    Don
    I would think that 8 years would be sufficient time for it to manifest itself, but any extended warranty (for free) is a (very) good extended warranty.
  16. Aug 4, 2016 at 6:46 AM
    #116
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Why? DI doesn't inject more fuel than MPI.
  17. Aug 4, 2016 at 6:52 AM
    #117
    Friggin Fuego
    Maybe it takes some time from corporate to get a TSB going. Nearly every single automatic transmission had issues which led to more owners complaining and getting that TSB 2 weeks ago. Or maybe Toyota doesn't have a long-term fix at the moment for the CPS issue so until then dealers are on their own until Toyota comes out with a fix.
  18. Aug 4, 2016 at 7:20 AM
    #118
    The hammer
    The CSP sensor may be a supplier issue. Somewhere down the line during manufacture, and depending on the type sensor, a component such as resistor, shield, diode and such is most likely out of specs.
    Moreover, by this time Toyota should have identified what it is and how many maybe affected.
    They better not let this go on for years like the cheap faulty GM ignition switch did to save a few cents, because we are very aware.
    Cheers!
  19. Aug 4, 2016 at 8:30 AM
    #119
    Truggin
    Don
    OK, so it takes a while to develop a TSB. That's OK. But shouldn't they at least send the dealers an advance notification or something like that to assist in diagnosis? Maybe something as simple as:
    "Hey dealers, we are beginning to see a higher than expected number of CPS failures. Typical symptoms are blah, blah, blah, and include these codes. Please perform the following steps to test the CPS before disassembling the engine."
    If my dealer had not disassembled the top half of the engine on my SR5, and replaced the cam gear and associated solenoid, (meaning they also had to: replace the cylinder head gasket, fuel pump gasket, drop the oil pan to check for any foreign debris, and replace the oil pan gasket) and instead had simply replaced the CPS when it failed, then the cat wouldn't have failed on the second incident (in fact, there wouldn't have been a second incident 47 miles later), and I would still have the SR5, and they wouldn't have a problematic truck that had been in a very minor accident that they will likely have to take a loss on to resell.
    All of that said, I am happy with the new truck, and how the dealer handled it. Full details are here: https://www.tacomaworld.com/threads/engine-issues-on-my-3rd-gen.441399/
    nevadabugle likes this.
  20. Aug 4, 2016 at 8:39 AM
    #120
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The massive pressures which DI injects is much more than MPI though. It may be the same amount of fuel going in, but the presures going in alone could spell trouble in the event of an unplanned, and untimely misfire. I don't really know much about DI, but from what I do know about it, it could spell trouble for other parts of engine emissions systems (the cat in this case) or the tech working on it. (Ruptured line has enough pressure to injure said tech supposedly)
