Immobilizer Garbage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco0677, Aug 23, 2023.
  1. Aug 23, 2023 at 10:23 AM
    Taco0677
    Taco0677 [OP] Active Member
    06 SR5 4x4
    Is there a way to get the truck to start with a broken immobilizer, but have original key? I've seen a ton of threads on how to bypass, but all seem to have an immobilizer that still works and it's just a reset. I gotta get to work and can't afford a new immobilizer at the moment someone please help.
  2. Aug 23, 2023 at 10:36 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Immobilizer is Broken?
    LeakyAC likes this.
  3. Aug 23, 2023 at 11:36 AM
    Taco0677
    06 SR5 4x4
    Yes, it's fried burn marks on it so not able to read the chip in my key
  4. Aug 23, 2023 at 12:05 PM
    Taco0677
    06 SR5 4x4
    There's gotta be a way to start the truck
  5. Aug 23, 2023 at 12:06 PM
    Taco0677
    06 SR5 4x4
    Ok, so was able to get it cranked but please if anyone has a way around this damn thing in case it happens again which I'm sure this temp fix won't last long I'd greatly appreciate it.
  6. Aug 23, 2023 at 12:08 PM
    Yoda_Mike
    Yoda_Mike YotaWerx Authorized Tuner
    Michael
    South Glens Falls, NY
    2019 Tacoma TRD Sport
    YotaWerx Blackhawk 2.0 tuned. Typer Auto tail light guards. Rough Country tri-fold tonneau cover. Start-X remote starter. Injen CAI. MBPR Armor Plus high clearance exhaust.
    In my 10+ years working for Toyota, I've not seen one successfully bypassed. I suspect the only way you could do this is some creative rewiring to eliminate the system from the starting process entirely. Risky and certainly not something that can be done quickly, I'm afraid.
    tacoman45 likes this.
  7. Aug 23, 2023 at 12:14 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    In short, No.
    The immobilizer sends a signal to the main ECU. The main ECU validates the the information from the immobilizer.
    With out the immobilizer, you won’t get spark or fuel.
    I suppose you could “maybe” hack the system and delete the check. But I’ve never seen it. It’s much easier to “hack” a key. AKA- Program a key to match the check sum of the current stored key code.
  8. Aug 23, 2023 at 3:43 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Save yourself the headache and just get a new immobilizer.
  9. Aug 23, 2023 at 3:54 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    There's no way I know of to bypass/delete the immobilizer, that would defeat the purpose of having one.
    Picture of what is burned? I've never seen one fry itself without help.
