Immobilizer malfunction - still runs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2wheelintacoma, Nov 3, 2020.
  1. Nov 3, 2020 at 6:05 PM
    2wheelintacoma
    2wheelintacoma [OP] Member
    2008 Prerunner 6speed
    2008 Prerunner V6 6Speed Manual
    130000 miles
    Bluedriver pulled a code: B2799
    Truck turns on and drives. No issues.
    Factory key.
    Fob does not work. Tested new batteries in it. Still won't work. Lost other, Fob that did work.
    Do I need to spend money on a new FOB?
    My understanding is if the immobilizer doesn't work. Then the truck won't start.
    I've had no issues starting my truck.
  2. Nov 3, 2020 at 6:09 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The immobilizer and fob are 2 separate things.
    The fob plays no part in starting the truck.
    The key is what let’s the truck start.
    Here is simplified version of how the system works.
    It’s not exact, but gives you an idea of how it works.
    Ther key has a chip inside of it.
    There is an Amplifier that strengthens the signal form the chip in the key, this signal is picked up by the Transponder ECU. The Transponder ECU tells the truck its
    OK to start.
