Impact Gun
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaEli, Dec 14, 2019.
  1. Dec 16, 2019 at 6:40 PM
    #81
    Timmah!
    Timmah! Well-Known Member
    TIM
    Gunshot-6A likes this.
  2. Dec 16, 2019 at 6:46 PM
    #82
    TacomaEli
    TacomaEli [OP] Well-Known Member
    Eli
    Roanoke, Virginia
    2000 Tacoma XtraCab SR5 TRD 3.4L Auto
    It’s an honor. When you said you had a Dewalt and I saw your name I knew it was you. I’ve watch quite a few of your videos. Im going to try to tackle the timing belt and valve covers soon!
    Timmah![QUOTED] likes this.
  3. Dec 16, 2019 at 8:02 PM
    #83
    btu44
    btu44 Well-Known Member
    Long Beach area, Ca
    04 Tacoma Double Cab, 4WD, TRD Off-Road
    SC with 7th injector. ICON 2.5 shocks and coil overs, SPC UCA, EMU Dakar rear springs. FrontRunner bed rack. ICOM IC7100 amateur transceiver
    I currently have a 3/8 air ratchet that certainly is no breaker bar or impact. But that's okay. I just break everything loose first and then spin off with the air ratchet. Power ratchets would shine removing the A/C compressor or exhaust manifolds. Places that are way to tight for an impact to fit. We have all experienced that one F'ng bolt or nut that take a 1/2 hour to remove because you only get 1 or 2 clicks of a ratchet per turn. Ugh. Power ratchets are also great for install too. I just hand start the bolt first and spin on the rest of the way. I like to hold the air ratchet loose. That way when the bolt bottoms out the ratchet slips in my hand and releases the trigger. Keeps from over torqueing smaller fasteners.
    I like the idea of a cordless ratchet because the air hose often gets in the way or I'm getting tanged up with the hose under the truck.
    tirediron, Thatbassguy and cruiserguy like this.
  4. Dec 16, 2019 at 9:08 PM
    #84
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I've got several Rigid carpentry tools, they're all corded, but I really like them. The circular saw is left handed, lol. The brand itself is nice enough that I'm likely to buy more Rigid stuff when my other lower end stuff (Ryobi) wears out. I have a soft spot for Dewalt, too.
    I have an air powered impact, so right now that's what I use. Cordless would be nice, for sure.
  5. Dec 17, 2019 at 5:11 PM
    #85
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    btu44 and Thatbassguy like this.
  6. Dec 17, 2019 at 7:30 PM
    #86
    Toki
    Toki Don’t get killed by Theta.
    Jon
    San Jose, Ca
    2018 Tacoma 4x4
    Little bit of this and a little bit of that but stock af.
    Can you elaborate on this, I just bought a detent anvil, should I return for the hog ring? What was so pita about them?.
  7. Dec 17, 2019 at 7:33 PM
    #87
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    I've had good luck with mine...can't complain.
    Kevin Jones[QUOTED] likes this.
  8. Dec 18, 2019 at 7:28 AM
    #88
    04tacoma trd
    04tacoma trd Well-Known Member
    Hog ring is preferable for me, too
  9. Dec 18, 2019 at 7:42 AM
    #89
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    This is the same set-up I have (except my I use the stubby with the 1/2" anvil to avoid carrying two sets of impact sockets). I took the big unit out into the graveyard behind our equipment barn (tractors, engines, equipment sitting in the rain and weather, some for 20+ years) and was unable to find anything that the Milwaukee Hi-Torque wouldn't spin off after just a few seconds. The stubby is perfect for 99% of car/light truck work.
    Thatbassguy[QUOTED] likes this.
  10. Dec 18, 2019 at 7:47 AM
    #90
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    The best impact gun to buy is the one I have. Sound familiar? Everyone here who has one of any brand swears by it while knocking another for personal reasons. Read/watch the reviews. Make a choice based on your needs and loyalties or whatever. Your choice will differ from most of us. They all have pros/cons. Price vs Power vs Reliability etc.
    High Noon and tirediron like this.
  11. Dec 18, 2019 at 7:52 AM
    #91
    tirediron
    These aren't meant for high-torque applications. They're not meant to break suspension bolts or crank pulley bolts... What they're meant for is taking the work out of spinning on/off long bolts, or fasteners in locations where you can't much throw on a regular ratchet. I had to replace a Ford alternator a while back, and one bolt was in a location that would have meant either using 4-5 extensions and u-joints (and thus, likely not getting a good angle) or working in a spot where I could only get <10 degrees of swing on the ratchet. With the Milwaukee 3/8 ratchet, I seated the socket, held the trigger and 30 seconds later... done.
  12. Dec 18, 2019 at 1:40 PM
    #92
    TuRDLYFE
    TuRDLYFE Well-Known Member
    An over-taxed town, county, and state
    2020 AG TRD Pro 6MT
    Some detent anvils don't lock the sockets super tight... others do. If you've looked at impact sockets, you'll see that the good ones have a hole in the base in the wall of them about 3/16" up from where they attach to an impact gun. That's where the detent locks in. With this gun, the detent locks into them VERY securely. This is great if you're working on an assembly line and having to install like 2000 of the same size fasteners every day. However, if your're changing sockets left and right, you'll need to grab an 1/8" punch or something else to insert into that hole and release the socket. The hog ring provides just enough friction on the interior surface of the socket to hold it in place without falling off and allows for much easier socket changes. Just my 2¢... I'm a lot happier with it.
    TK-422, CS_AR, cruiserguy and 2 others like this.
  13. Dec 18, 2019 at 9:05 PM
    #93
    Toki
    Jon
    San Jose, Ca
    2018 Tacoma 4x4
    Apparently the local HD's only carry detent anvils. I guess I'll have to just muscle it out.
  14. Dec 18, 2019 at 9:17 PM
    #94
    Martian__
    Martian__ Well-Known Member
    Southern California
    Ingersoll rand
    I must agree. Wrenched at dealership level for over 10 years. Ingersoll Rand offers an a great product. There’s a reason why matco (maybe others) rebrand them as their own.
    CS_AR likes this.
  15. Dec 19, 2019 at 1:53 AM
    #95
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    You won't be happy long term, I'm hoping to just save you some future frustration. That's all. The detent anvil driver I messed with one time was a pain in the ass.
    Toki[QUOTED] likes this.
  16. Dec 19, 2019 at 10:14 AM
    #96
    TuRDLYFE
    2020 AG TRD Pro 6MT
    Get the model type code off of the drill when you buy it. If you get a type 1 or 3, you can buy just the replacement anvil and swap it out for $23. It'll be worth it, trust me. It's only four screws on the face of the gun and swap the grease to the new anvil. Easy peasy.
    https://www.amazon.com/BLACK-DECKER...07MLYJB11?SubscriptionId=AKIAILSHYYTFIVPWUY6Q
    I think there is another part number for other type codes, but I'll let you do the research on that.
    Thatbassguy and Toki[QUOTED] like this.
  17. Dec 28, 2019 at 7:10 AM
    #97
    TacomaEli
    Eli
    Roanoke, Virginia
    image.jpg Got the ridgid, about to try it out.
    MGMSangTaco, Toki, 09 Redneck and 4 others like this.
  18. Dec 28, 2019 at 7:33 AM
    #98
    TuRDLYFE
    2020 AG TRD Pro 6MT
    Good call on the Octane battery!
    gtdad66 and cruiserguy like this.
  19. Dec 28, 2019 at 7:40 AM
    #99
    cruiserguy
    Elijah
    SEKS
    There is definitely nothing wrong with going with Ridgid my man. Stay consistent with the line, there are lots of cool useful tools that will use that battery:cool:
  20. Dec 28, 2019 at 7:58 AM
    #100
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Personally I like this one. It’s more compact but still packs enough power to break loose most rusty bolts. I have the larger version too but this one is much more useful for working on the truck.
    DEWALT 20V MAX XR Cordless Impact Wrench Kit with Detent Pin Anvil, 1/2-Inch, Tool Only (DCF894B) https://www.amazon.com/dp/B078WDTV2F/ref=cm_sw_r_cp_api_i_zM3bEb53D8Y40
