Impact Gun
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaEli, Dec 14, 2019.
  1. Jan 13, 2020 at 7:08 PM
    #141
    stiover
    stiover Well-Known Member
    Corey
    2004 DCSB
    Bilsteins Toyotec Springs OME Dakar leafs TE37X w/ 33s
    Dewalt has a large construction user base and a lot of their stuff is built for construction use. And some specifics, nail guns, wire ties, etc. Milwaukee has the 3/8" ratchets and some other snap on variations.
  2. Jan 13, 2020 at 7:20 PM
    #142
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Ah, sorry I misunderstood. I thought you were talking specifically about the impact guns.
  3. Jan 13, 2020 at 11:13 PM
    #143
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    Oh I did but like I had posted in the Other Thread about cordless impacts I have used Dewalt cordless tools for over 15 years and have never had one fail on me.
    I did buy three 18V Lithium Ion batteries to replace the Nicads at one point since they are better in every way.
    I do have Milwaukee 18V Fuel tools for work. Since I didn't pay for them it's fine by me. I don't really see a difference except the color of the plastic.
    Any brand is better than dragging a cord around.
    TuRDLYFE[QUOTED] likes this.
  4. Aug 3, 2020 at 11:18 AM
    #144
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    I'm split between the DeWalt DCF899HB (hog ring anvil) and the DCF899P1 (detent anvil). From what I understand its the same drill (power) just different mounting options. What are the pros and cons between hog ring and detent for automotive application?
  5. Aug 3, 2020 at 11:35 AM
    #145
    Wulf
    Wulf no brain just damage
    rock raisin
    Marketing
    though DeWalt is lacking the cordless ratchet option, which is disappointing. If I was starting from scratch I'd probably buy into the milfawkees instead
    Ccrowe323 likes this.
  6. Aug 3, 2020 at 1:18 PM
    #146
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Be careful man. I got a brushless Makita impact driver and those things are crazy strong. First....both of the below examples are my fault, so it may never happen to you.
    First thing I broke was using it to secure the radiator overflow box on my wife's Altima. Screwed it down to much and broke the plastic tab!
    Second thing I broke....Taking the flywheel inspection plate on my Tacoma and snapped the freakin bolt head off! Damit! Like a dumbass, I thought I had it switched to loosen when it was turning right. Before I knew it, it snapped the head off the bolt. Had to go to Lowe's and get an extractor.
  7. Aug 3, 2020 at 5:28 PM
    #147
    TacomaEli
    TacomaEli [OP] Well-Known Member
    Eli
    Roanoke, Virginia
    2000 Tacoma XtraCab SR5 TRD 3.4L Auto
    Been using my ridgid for about 6 months now. Haven’t had any issues. Don’t really use mine to tighten fasteners.
    cruiserguy likes this.
  8. Aug 3, 2020 at 6:37 PM
    #148
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Unless you're putting new track pads on a CAT 390, an impact driver / wrench should NEVER be used to tighten fasteners, especially, especially, ESPECIALLY lugnuts!!!!!
    cruiserguy and jammer like this.
  9. Aug 3, 2020 at 7:10 PM
    #149
    jowybyo
    Joe
    Baltimore, MD
    Eh. I pretty much only use an impact driver and gun for almost everything. Drywall screws? Impact driver. Taking apart plastic products? Impact driver. Nearly any bolt on the truck? Impact gun.
    Now, I don’t go balls to the wall unless the situation calls for it. I’m not running lug nuts on to 100 ugga duggas in high setting. But I wouldn’t make a sweeping comment that you should never use an impact on some certain type of fastener.
    Thatbassguy likes this.
  10. Aug 3, 2020 at 7:17 PM
    #150
    tirediron
    Fair comment, by "Impact" I mean a mechanic's impact gun, NOT a 1/4" driver, which I didn't articulate very clearly. What I meant was, for mechanic-ing, using 3/8, 1/2, or 3/4" square anvil impact "guns", they should only be used for removing fasteners. Pretty much every single fastener on your vehicle has a specified torque, and it's really easy to run past that, even on a low range. In short: Impact wrench for removal, ratchet and torque wrench for installation.
    SC4333, jammer and cruiserguy like this.
  11. Aug 3, 2020 at 7:22 PM
    #151
    Ccrowe323
    Ccrowe323 Well-Known Member
    Cory
    Florida
    2001 Tacoma 3.4 DC 5speed TRD OR
    Same here, if we’re to buy again I’d definitely go miluwakee.
    I’ve always bought dewalt. My dad always used dewalt when I was a kid, We still have a set of old school ones retired for use on small wood work projects now, at least 10 years old if not older and still kick ass, other than the batteries died out.
    But my last dewalt drill set I bought for work only 2.5 years ago is kinda crappy. I even bought the “USA made” version and had to take apart the hammer drill to fix the trigger, the chuck doesn’t hold for shit, and now lately the LED only works when it wants to. Nothing major for the hammer drill, it gets the job done but I don’t believe they are nearly what they used to be. Also the impact gun has the 3 speed which is nice sometimes for small stuff like installing doors or something. But for the past year it will randomly just want to stay in speed one no matter what the selector is on and I just have to pull the old give it a light bump until it wants to start working right.
    Also a 2 year old multi tool just crapped out of nowhere a couple months ago.
    I can’t say Maluwakee is much better as I’ve never used them but from what I’ve heard they are over taking the game with successful quality tools. Where dewalt is just selling on name now instead of integrity of quality tools.
  12. Aug 3, 2020 at 7:22 PM
    #152
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    Been happy with this one so far.
  13. Aug 5, 2020 at 2:04 PM
    #153
    04tacoma trd
    04tacoma trd Well-Known Member
    My Milwaukee impact gun has three torque settings. One of the settings produces very consistent torques just below the 93 ft-lbs called for by Toyota for the lug nuts. So, I use the impact gun every time and then follow up with the torque wrench for final torque. Otherwise, you are sitting there all day spinning a wrench.
    Gunshot-6A and StevenP like this.
  14. Aug 5, 2020 at 2:20 PM
    #154
    khail19
    khail19 Well-Known Member
    Khail
    Reno, NV
    2000 Prerunner SR5
    I've been using the Rigid 18v lineup for years and never had an issue with a tool. Out of 10 or so batteries I've only had to warranty a couple of them. The process was mostly painless as long as you register them when purchased. The 1/2" X4 impact gun has been great and I use it a lot. I do wish they had a cordless ratchet option like Milwaukee.
  15. Aug 5, 2020 at 5:47 PM
    #155
    BlackSportD
    Los Angeles
    Damn that sounds nice. My DeWalt just came in, variable speed but not variable torque...
  16. Aug 5, 2020 at 8:15 PM
    #156
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Got the same one, works great :thumbsup:
  17. Aug 5, 2020 at 8:43 PM
    #157
    StevenP
    StevenP Well-Known Member
    Steven
    Alta, Ca
    2003 Tacoma DCSB TRD
    Build thread in Signature
    Another positive experience with the Milwaukee impacts here. I have the 3/8 stubby impact and the big bad 1400# 1/2 impact. After doing the front end suspension by hand I decided to give them a go.. wish I had done this YEARS ago! Really makes wrenching more enjoyable and SO MUCH FASTER.
    As mentioned before, there are a few options for torque on each of the impacts that let you work safely without worrying about damaging anything, you just come in and do a final torque with a torque wrench. As for getting things off, these things don’t break a sweat. It’s stupid easy and quick to remove things.
    I also picked up their M12 fuel 3/8 ratchet, and that thing kicks ass in much the same way. I would highly recommend those three tools for anyone who likes to do their own wrenching but is looking to get some assistance from power tools, and if you’re on the fence about it don’t be.. it’s so much more efficient than turning things by hand and struggling with breaker bars and cheater pipes and split knuckles.
    I’ll end my rant with this one last thing; I worked with crap tools and an insufficient tool set for a long time, and have only recently started investing in higher quality stuff. Worth every damn penny.
    tirediron and Hamer95USA like this.
  18. Aug 5, 2020 at 11:52 PM
    #158
    Boone Wesley
    Boone Wesley Well-Known Member
    Boone
    LA 818
    01 4D 4WD Limited
    See attached
    tirediron likes this.
  19. Aug 6, 2020 at 7:31 AM
    #159
    tirediron
    Agree on all counts; I'm slowly building up quite a respectable collection of Milwaukee tools, and the 3/8 ratchet and two impacts (I got my stubby in 1/2 just to simplify socket accounting) are my go-to tools for mechanic-ing, 'though to be totally frank, I don't get a lot of use out of the big bruiser; the stubby, with 250 ft-lbs does 99% of the work on a passenger vehicle. I was pulling final drives out of an old (50s era) Bucyrus-Erie shovel, and Big Red spun those 7/8" bolts out of there without even breaking a sweat!
    cmacblue42 and StevenP[QUOTED] like this.
  20. Aug 6, 2020 at 7:39 AM
    #160
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    time is money, you really think if im slinging tires all day im going to put 32 lug nuts on by hand. not.
