Impact Gun
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaEli, Dec 14, 2019.
  1. Aug 6, 2020 at 8:08 AM
    #161
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    The shop I go to for tires, which is a small, but very busy one does every single lug on every passenger vehicle with a torque wrench. Granted they run them up with a battery powered nut driver (which probably has a peak torque of about 25 ft-lbs), but they're all finished by hand with a torque wrench, set to that vehicles spec. If a couple of extra dollars is more important to you than doing a proper job, that's your prerogative - I wouldn't patronize your establishment, but I'm sure lots do, so if it works for you....
  2. Aug 6, 2020 at 8:10 AM
    #162
    TurtleCrawler
    TurtleCrawler Well-Known Member
    2000 Tacoma SR5 TRD
    255/85/16 KM3s
  3. Aug 6, 2020 at 8:31 AM
    #163
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    well what you said is kinda of the point I was making, they still drive them on with some sort of device... obviously you finish with a torque wrench lol
  4. Aug 6, 2020 at 11:17 AM
    #164
    tirediron
    It should be obvious, but I've seen (as I'm sure you have) a lot of places (Wal-mart and Canadian Tire leap to mind) where the first year apprentice is driving lug nuts onto a friggin' smart car with a 1/2" impact... makes me want to throat-punch them!
  5. Nov 4, 2020 at 6:25 AM
    #165
    ssoulssurfer
    ssoulssurfer Well-Known Member
    1998 Tacoma 4x4 SR5 TRD MANUAL TRANS 3.4L V6
    2.0 FOX COILOVERS FRONT, 5100 BILLSTEINS REARS
    Along with a 1/2" impact gun, I also want to get one of those 3/8" milw ratchets. The fuel and the regular look and feel different. Looks like the regular has a torque around 35 ft/lb and the beefier fuel (slightly bigger too) has like 55 ft/lbs. Anyone used either of those, any thoughts?
    StevenP likes this.
  6. Nov 4, 2020 at 6:31 AM
    #166
    Kwikvette
    Fresno County
    4 run, 2 don't
    It's only the perfect companion; got both -
    Both Fuel.
    StevenP and tirediron like this.
  7. Nov 4, 2020 at 6:35 AM
    #167
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I hardly use the electric ratchet except for when under the truck and a ton of short strokes are needed to remove bolts or a bunch of bolts in succession, then they have a purpose. Most of the time for me they are too big and clunky to use comfortably.
    skeezix likes this.
  8. Nov 4, 2020 at 6:39 AM
    #168
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    I got the regular since the head is a bit smaller I can wedge it in places a little easier. Plus the 35ftlbs means I can zip on a decent amount of bolts without worrying about over tightening.
    Either one will be a godsend though if you wrench alot, my 1/2 impact and 3/8 ratchet are easily my 2 most used tools
  9. Nov 4, 2020 at 6:47 AM
    #169
    tirediron
    I have the same, as well as the M12 impact in 1/2"... there isn't much I can't remove when I want to! :D
    Kwikvette[QUOTED] likes this.
  10. Nov 4, 2020 at 6:51 AM
    #170
    StevenP
    StevenP Well-Known Member
    Steven
    Alta, Ca
    2003 Tacoma DCSB TRD
    Build thread in Signature
    I use my 3/8ths fuel ratchet all the time, saves a TON of time zipping things in and out as long as you can access them - unfortunately it’s pretty large and doesn’t get into as many nooks and crannies as I’d like - with that said, I would happily buy it again and definitely recommend it.
    Kwikvette likes this.
  11. Nov 4, 2020 at 3:31 PM
    #171
    ssoulssurfer
    Yeah that's what I was wondering about. I'm thinking gonna get the big 1400lb milw, then maybe that regular m12 3/8 ratchet for smaller stuff
  12. Nov 4, 2020 at 8:18 PM
    #172
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    *83
    I do the same though, cinch it to 3 clicks on the low setting, then torque to finish. Dang near perfect every time
  13. Mar 16, 2021 at 9:56 PM
    #173
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Left hand pulling the trigger with my pinky blind around a corner. Fucking things rock.
