Importance of a torque wrench?
Discussion in 'Towing' started by jmg256, Mar 15, 2010.
  1. Mar 16, 2010 at 1:43 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i like! we test bolts with a gauge called a skidmore (i think). havent done it in a while, but it reads tension. ...big huge 1" bridge bolts. mega torque stuff. fun stuff.
  2. Mar 16, 2010 at 1:49 PM
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2019 OR 4x4 6MT
    Correct! Skidmore-Wilhelm.
  3. Mar 16, 2010 at 7:42 PM
    fauskar
    fauskar Active Member
    Rick
    Wisconsin
    SR5
    Hitch
    Drill a 1/16" hole through the stem of the ball and insert a cotter pin above the point the nut secures it. Saftey wire will also work quite well. So get the torque about right, secure and forget it.
    This is an effective solution I have performed. Getting the position of the hole correct is the hardest part. Drill press and vise works fine.
    Simply, safety wire and pins have been used for a long time in situations much more cricital than this. Don't over think it... it bad for brain cells.
  4. Mar 26, 2010 at 9:50 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    For a hitch, use an appropriate size wrench, or 1/2" drive socket wrench, and tighten it snug, re-tighten after use. Good enough. Torque is not complicated, 65 ft lbs is 65 lbs of force on a 1 foot lever.......You can guess close enough, especially for a hitch.
