Impressions of shifting/hesitation/power TSB (T-SB-0092-20)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by codemancer, Oct 30, 2020.
  1. Oct 30, 2020 at 12:40 PM
    codemancer
    codemancer [OP] Well-Known Member
    Northern Utah
    2020 Tacoma OR DCSB Voodoo Blue
    KDMAX Pro, RCI sliders and skids, CBI overland bars, 255/85R16 Geolandars, Bestop Supertop 2, ARB Drawers, Uptop Bravo rack
    I'm curious if anyone else has had the update to their ECM prescribed by this TSB. It's supposed to do a lot to help with the engine hesitation and shifting performance on 19-20. Mine is a 2020 purchased in March. I just got this done and my initial impressions are good.
    I tested it on about a 25 mile stretch of interstate that is relatively flat. Going 75mph I normally shift up and down a dozen (maybe two dozen) times. It's an awkward speed for that particular stretch on my truck. After this update, I only experienced a downshift on the two actual hills on the road which I totally expected.
    In terms of hesitation, I notice--what feels to me--like an increase in throttle response or sensitivity (most noticeable in first gear).
    I will keep an eye on this for a while, but so far my initial impressions are really positive.
  2. Oct 30, 2020 at 12:45 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I thought there were no TSBs regarding drivebility on 2019s and up. Interesting.
    Boghog1 likes this.
  3. Oct 30, 2020 at 12:48 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. Some folks have been very impressed on the 2019 side. I haven't heard much about the 04B80 to 04B81 comparisons yet. It should be pretty similar either way. I know that 04B14 felt darn close to 04B91 on a 2020.
    hotrodder636 likes this.
  4. Oct 30, 2020 at 12:48 PM
    codemancer
    Northern Utah
    I didn't think there would be, then I saw this on a Facebook group. My VIN matched so took it in today and they updated it for me (I have no way to verify, but it definitely feels different).
  5. Oct 30, 2020 at 12:57 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Hm, very intetesting. Why cant they just do it before it leaves the factory? :confused: its been going on for almost 5 years for fuck sakes...
  6. Oct 30, 2020 at 12:59 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. We got the Canadian TSB a couple weeks ago along with the software files to flash at home.
    That US TSB was just posted on the nhtsa site a couple days ago. Like you see, it has been floating around on the Toyota side for about a month.
  7. Oct 30, 2020 at 12:59 PM
    codemancer
    Northern Utah
    I think I remember hearing that they already did have an update for 2016-2018 to bring it "up to" what the 2019 and 2020 did, but obviously they needed to do more.
  8. Oct 30, 2020 at 1:01 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    At this point, only the 2016 and 2017 MTs with TSB-0043-20. There is an expectation that the 2018 MTs and other ATs will get theirs.
  9. Oct 30, 2020 at 1:02 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Haven't noticed any problem with mine at that speed, it goes good. Only issue i once had was the odo being off reading fast. Dealer corrected it during my 1st oil change.
  10. Oct 31, 2020 at 3:48 AM
    AUTacoma18
    AUTacoma18 Well-Known Member
    '19 TRD OR DCSB Barcelona Red
    Hopefully getting mine done this morning. I’ll let you know the problems I’ve had and my impressions later today.
    plasticsnaks and tonered like this.
  11. Oct 31, 2020 at 6:23 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Seems like they do what they can at the factory. My 2020 came with 04B81, build date 08/2020.
  12. Oct 31, 2020 at 6:59 AM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    Where did you find the VIN lookup?
  13. Oct 31, 2020 at 7:34 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    OBD Fusion or the Carista app will tell you the ECU ID.
  14. Oct 31, 2020 at 11:02 AM
    mike92y
    mike92y Well-Known Member
    Michael
    Glendale, AZ
    2018 TRD OFF ROAD
    OME all around. SPC UCA. This and that.
    So the TSB is listing ECU ID and not VIN?
  15. Oct 31, 2020 at 12:13 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. That is how the ECU TSBs work.
  16. Oct 31, 2020 at 9:14 PM
    codemancer
    Northern Utah
    That first page shows affected VINs. I think they are 4-9th position.
  17. Nov 1, 2020 at 11:45 AM
    mike92y
    Michael
    Glendale, AZ
    2018 TRD OFF ROAD
    You are correct first page lists part of the VIN and mine matched. I will be calling dealer tommorow. Thanks for the post
  18. Nov 3, 2020 at 6:01 AM
    mchertel
    mchertel Well-Known Member
    Mark
    Colorado Springs CO
    2020 Tacoma Off-road
    Toytec 2 inch boss lift
    Thanks for posting this OP. I went and had mine done yesterday and I do believe it helped. Have not tested it a lot yet but there are a couple of hills that normally cause hunting and I just used to use "S3". The truck seemed to hold on these hills now in drive at the acceleration needed without a lot of hunting. Think it had to naturally downshift once but stayed there until the peak.
    codemancer[OP] likes this.
  19. Nov 3, 2020 at 6:40 AM
    codemancer
    Northern Utah
    Awesome! I'm interested to hear your continuing impressions. Mine are still positive. Shifting seems a lot better, though admittedly I haven't driven a ton since.
  20. Nov 5, 2020 at 3:13 PM
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2025 1794 Tundra TRD-OR
    Just had this TSB done on my 19OR.... You can tell instantly that it runs better. It seems like it prevents the vehicle from downshifting too early, and lower end power feels MUCH nicer.
    Feels like the torque converter stays locked more often instead of the odd "in between gears" that it would do before.
    Anyone who has a 19/20 should go and ask about this TSB, took about 45min to do and has made a massive difference.
    I have to drive from Idaho back to California this weekend so I'll update after that on how it performs.
    hotrodder636 and codemancer[OP] like this.
