Impressions of shifting/hesitation/power TSB (T-SB-0092-20)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by codemancer, Oct 30, 2020.
  1. Nov 25, 2020 at 1:10 PM
    #101
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2025 1794 Tundra TRD-OR
    I decided against OVtune after this, and I was planning on doing it before.
    Everyone should be doing this if they can, massive difference in driveability.
    cryptolyme and hotrodder636 like this.
  2. Nov 25, 2020 at 2:42 PM
    #102
    dansflhti
    dansflhti Well-Known Member
    Nova Scotia
    24 TRD Sport +.16 Mustang GT. 14 Street Glide
    I agree...massive difference in my truck. This tsb makes my truck a joy to drive. It doesn't feel like I'm towing a 10k lb trailer all the time. I haven't pushed the ECT button since.
    hotrodder636 likes this.
  3. Nov 26, 2020 at 10:04 AM
    #103
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Appreciate the pics of the TSB. Applies to the 6cyl 2GR only, not my 2.7L 4 cyl. I’ve never had a problem with acceleration delay on my 2019.
    PEOPLE - PLEASE Post what models/engines/etc the TSB or problem you are having applies to when you post!! Not everyone is running a 2GR V6!!! And glad with all the complaints I don’t have one.
  4. Nov 26, 2020 at 10:05 PM
    #104
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    I have a 2019 OR that, frankly, I don't have many powertrain complaints about. However, it does this 3rd gear RPM dance that has always bothered me, if only slightly. Second to third settles to a low RPM (TC lock?) then buzzes up a couple hundred RPM (TC unlock), then settles again. Any indication the new TSB addresses this?
    neatoneto likes this.
  5. Nov 26, 2020 at 10:06 PM
    #105
    Sand_In_My_Taco
    NOR*CAL
    Yup!
  6. Nov 27, 2020 at 5:56 AM
    #106
    CDNTacoma2019
    CDNTacoma2019 Well-Known Member
    Ontario, Canada
    2019 SR5 DCLB 4x4
    Is the Canadian TSB the same number?
  7. Nov 27, 2020 at 6:12 AM
    #107
    Westsideott
    Westsideott Well-Known Member
    Ottawa, ON
    2020 DCSB OR
    The Canadian version is attached to a thread around page 2 or 3 I think
    tonered likes this.
  8. Nov 27, 2020 at 6:18 AM
    #108
    CDNTacoma2019
    Ontario, Canada
    2019 SR5 DCLB 4x4
    The TSB lists the model of the 3.5 V6 right at the top on the papers attached. Nobody complains about the 4 cylinder except for its lack of power.
  9. Nov 27, 2020 at 6:35 AM
    #109
    seanbabs
    seanbabs Well-Known Member
    Arvada, CO
    2020 Quicksand OR
    So my truck matches the VIN and was manufactured late 2019. Like everybody else, the worst thing about the truck is how it hunts for gears. Annoyingly, when I go to the Toyota website and put in my VIN it returns no recalls or TSBs. I’ll ask at the dealership (going in a couple weeks), but it is disappointing if they don’t notify all affected. I’ve heard nothing about this fuel pump recall either.
  10. Nov 27, 2020 at 7:34 AM
    #110
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The Toyota site never shows applicable TSBs.
    seanbabs[QUOTED] likes this.
  11. Nov 27, 2020 at 7:40 AM
    #111
    seanbabs
    Arvada, CO
    2020 Quicksand OR
    I called them to add this to my service and they said it wasn’t for my vehicle. I bet they just went to the same website I did.
  12. Nov 27, 2020 at 7:42 AM
    #112
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No. They have more info than you do. If you are a later 2020 build, you might be 04B81 already.
  13. Nov 27, 2020 at 7:47 AM
    #113
    seanbabs
    Arvada, CO
    2020 Quicksand OR
    I’m hoping so!
    tonered[QUOTED] likes this.
  14. Nov 27, 2020 at 8:23 AM
    #114
    willeneum
    willeneum Member
    Alberta
    Is there a definitive way to tell?
  15. Nov 27, 2020 at 8:27 AM
    #115
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. TechStream with a Tactrix adapter or the Carista or OBD Fusion apps with a wireless adapter.
    hotrodder636 and G8R_Taco like this.
  16. Nov 27, 2020 at 10:29 AM
    #116
    davidstacoma
    David
    NC
    Looking at the actual TSB is how I discovered that. My point is it would be helpful to point out what a TSB applies to when you make a post about it. Fortunately someone posted the TSB so I could see what engine it applies to. Maybe when a TSB comes out only applying to the 2TR-FE (apparently rare) I will post about it excluding any links or info regarding the applicability and leave you V6 guys scratching your heads until you see the TSB. ;)
    bbahunter likes this.
  17. Nov 27, 2020 at 1:05 PM
    #117
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Open your door and see when the build date is. Mine was 08/2020 and came with 04B81.
  18. Nov 27, 2020 at 1:23 PM
    #118
    JWestie
    Great. Will try to schedule the flash during next oil change (if they relent).
  19. Nov 27, 2020 at 3:28 PM
    #119
    wj3v
    wj3v Active Member
    2022 TRD Sport
    Did this today on my 2019 sport. Definitely made an improvement.
  20. Nov 27, 2020 at 3:52 PM
    #120
    AutoTaco
    AutoTaco Well-Known Member
    Jay
    Pittsburgh, PA
    2021 Lunar Rock TRD Pro
    Calliraised Sliders, Diamondback HD, 265/75 Wildpeaks
    Do you have a recommended wireless adapter to work with OBD Fusion or Carista? Also, is Caista or OBD Fusion better than one another? Thanks for your feedback, I'd just rather buy the right one the first time. Seems OBD Fusion is more in-depth.
