Improve an 08 4cyl gas mileage???
Discussion in 'Performance and Tuning' started by Steve E, Mar 26, 2009.
  1. Mar 26, 2009 at 9:27 PM
    Steve E
    Steve E [OP] Well-Known Member
    Southern Missouri
    2014 TRD Sport DCSB 4x4
    I have an 08 4 cyl auto access cab and was wondering what can I do to increase fuel mileage. I already have K&N air filter on it, I don't want to do anything to the exhaust yet. Any ideas?
    Steve E.........
  2. Mar 26, 2009 at 9:33 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well......you can take out the secondary air filter..........gives the 4 banger a decent change. and,if you wanted to....you can swap the k&n out for a afe pro dry s air filter. its a dry filter, and filters better than a k&n.
  3. Mar 26, 2009 at 9:35 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    x2 on the secondary air filter. The K&N may provide the best air flow, however it does not do the best job filtering
  4. Mar 26, 2009 at 9:56 PM
    Steve E
    Southern Missouri
    Now that is a new one on me, I didn't know it had a second air filter. Can someone educate me where it is? Thanks for any info.
    Steve E..........
  5. Mar 26, 2009 at 10:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    open up the airbox.....its right behind the normal air filter. its connected by small plastic rivets.............you can cut the heads off with a razor knife......just make sure no plastic shavings get into the intake. here is more info......................http://www.tacomaworld.com/forum/performance-tuning/2012-diy-secondary-air-filter-removal.html
  6. Mar 26, 2009 at 10:04 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if he did it very carefully.....he could make it work i think.
  7. Mar 26, 2009 at 10:17 PM
    Steve E
    Southern Missouri
    We only have about 24 months left till an Air Force retirement and then we leave this God forsaken place they call Kommifornia. Thanks for the info on the filter, I guess I can leave it alone till we leave. My 4 door Tacoma (2000 V6 Prerunner) would get 19/21 mpg in Hawaii and my Wifes car would get 28 mpg(these were averaged per tank for 4 years) there but when we came to Kommifornia my truck dropped to 14 mpg and my Wifes car dropped to 21 mpg, these were averaged per tank for about a year. Finally found a Tech at the local Toyota Stealership that told me it was the way Kommifornia formulates it's gas.
    Steve E.........
  8. Mar 26, 2009 at 11:47 PM
    BUK 0H5
    BUK 0H5 Still For Sale
    Queen Creek, AZ
    Silver 09 2.7L Manual AccessCab SR5 PreRunner
    Removed Mud Flaps, Suspension TSB, 5100's all around, JVC KW-AVX710 Head Unit with Metra surround.
    Wonder if that has anything to do with the Ethanol content in the CA gas vs the HI gas. 14 for a 4cyl seems reeeeaaly bad to me. I get 23 in town with mine. All I have done is remove the secondary air filter and the mud flaps. Removing the secondary air filter didn't really seem to help anything much from what I could tell, but I think I only had it a week of two when I removed it so who knows.
  9. Mar 26, 2009 at 11:52 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
  10. Mar 27, 2009 at 9:31 AM
    Steve E
    Southern Missouri
    The vehicles averaged the same in Maryland as Hawaii, we did 3 yrs in Md and 4 in Hi then came to Kali and that is when the mpg went down starting with the very first tank on each vehicle.
    Steve E........
  11. Mar 27, 2009 at 10:06 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    What is it that CA puts in their gas....MTBE
    It supposedly doesn't produce as much smog, but lowers mpg's. Combine that with Ethanol (not sure if it's in gas in CA) and you will probably get a few mpg's less than with "normal" gasoline.
    However, 14 in a 4-banger sounds really low, even for CA and even city driving. I think I'd have it checked out.
  12. Mar 27, 2009 at 4:44 PM
    Steve E
    Southern Missouri
    afd23a
    The 14 mpg was for my 01 4 door Tacoma with the v-6. My 2008 Auto Access Cab 4 cyl gets around 21/22 mpg city.
    Steve E.....
