Discussion in '2nd Gen. Tacomas (2005-2015)' started by shaff33, Jan 21, 2010.
  1. Jan 22, 2010 at 2:08 PM
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
    Definitely check your tire pressure. When my mileage starts to drop off (and I'm not driving aggressively), its almost always a tire pressure issue.​
  2. Jan 22, 2010 at 2:23 PM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    I've wondered about this as my wife asked me if this truck just takes longer to warm up then her old car(4cyl toyota camry). Are the Tacomas in general a little slow to warm up.
    On topic now, the worst milage I've had was 20 and the best close to 24. I just don't ever get rushed, leave early and take my time:)
  3. Jan 22, 2010 at 2:45 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    Not sure if you mean an auto or not. The OP has an MT. This is standard procedure for me when driving. I always put it in neutral and let out the clutch at all red lights. The point is not to save gas though.
  4. Jan 23, 2010 at 8:05 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Still looking for an answer on this...
  5. Jan 23, 2010 at 8:36 AM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Scangauge shows mileage goes to 9999mpg which is in response to the Throttle Position Sensor. This coincides with a noticeable shudder from the engine and if you're not going down a fairly steep hill you will immediately start losing speed - engine braking. As long as the wheels are rolling and the drivetrain is connected then the cylinders will keep turning, you're just not burning fuel to do it.
  6. Jan 23, 2010 at 8:44 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Hmmm, excellent...all good signs
    I have a very good idea but I'll need some real technical help. This will spawn a new thread.
  7. Jan 23, 2010 at 8:48 AM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    Pull a "me" and don't drive your truck over 35 mph and don't rev your Rpm's over 2k. I get Like 22-25 in my v-6!!! And like 400 miles to a tank and I don't even let it get to "E"
  8. Jan 23, 2010 at 12:11 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Scangauge2 and pretend there is an fresh egg between your foot and the accelerator.
  9. Jan 23, 2010 at 12:15 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    At 70mph versus 65mpg on a 200mile trip I save about a quarter of a tank of gas based on slower speed alone.
  10. Jan 23, 2010 at 12:21 PM
    Robbie 09
    Robbie 09 Member
    Robbie
    Canada
    "09 Tacoma Sport
    Toytec ultimate lift.Sno-Way plow.Back-rack Weather tech mats.TRD shifter knob. Replaced sport decals with offroad decals
    Don't mean to change subject, but curious about the difference in mileage between a manual and automatic transmission.How would two similar trucks with different transmissions only compare?
  11. Jan 23, 2010 at 12:30 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Auto gets slightly better MPG due to its slightly taller final gear.
    I'm purely stating what others have said so if I fucked up I apologize. I do know that autos get better mpg, and its to do with the final gear.
  12. Jan 23, 2010 at 12:31 PM
    SlurpeeBlueMetallic
    Gearing on the 6-speed manual transmission is different which contributes to the overall lower MPG rating. I suspect you could offset that with changes in driving style by being able to better control which gear you're in all the time. I originally wanted to get a 6-speed manual but literally couldn't find one within 600 miles when I went to buy.
  13. Jan 27, 2010 at 1:34 PM
    dgr540
    dgr540 I've got the FUNK
    Friendswood, TX
    2013 Wrangler Unlimited
    XDs Trail grappler 35x12.5x18 Winch 8K lbs Front bumper 4in Lift
    I generally get the best when I have my wife behind the wheel and I am pushing it! other days I get 18mpg.
  14. Jan 14, 2017 at 10:42 PM
    wilhed
    wilhed New Member
    wilhed
    Seattle, Washington
    black sand pearl '03 Tacoma manual 4x4 V6 Dohc 54z
    Fog lights; iridium spark plugs; otherwise all stock.
    Not much to add to all of this but I struggle w/the same w/ my '03 Tacoma manual V6. Scangauge II sounds like a good idea. Coming to the peak of a hill w/ a stop sign, make sure you reach pinnacle so you don't have to gun first gear to get up to the precipice from stationary. As folks have said, coasting in general is the single best strategy to improve mileage. No need to drive fast - you aren't driving a Corvette.
  15. Jan 15, 2017 at 4:44 AM
    #35
    mike s
    mike s Well-Known Member
    South Carolina
    2019 TRD OR
    Someone mentioned tire pressure already, that is a big one.
    You could also consider tune up things like cleaning your fuel injectors, spark plugs, air filter.
