Improve your truck! (Without SCing)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JustADummyInATaco, Jun 12, 2016.
  1. Jun 12, 2016 at 10:16 PM
    JustADummyInATaco
    JustADummyInATaco [OP] Active Member
    Riley
    UTAH
    06 sr5 driven by noob
    6" Procomp Coilover lift, 18 inch motometal wheels, too small of tires, magnaflow exaust, highly illegal tint, poser TRD off-road stickers, TRD intake, NFAB nerf bars, lots of love.
    So my main question is this, what can be done to improve your Tacoma? I'm looking for more power/reliability/quickness without breaking the bank. What would you recommend in order of importance? Looking for tips on upgrades/maintenance (I.E. Clean your air filter/throttle body, headers/MAF sensor upgrade) P.S. I already have an intake and exaust so that's out. Ideas/pre-existing threads I should check?
    ChadsPride likes this.
  2. Jun 12, 2016 at 10:31 PM
    Pigpen
    Dan
    Northwest Montana
    There's not much that can be done to improve performance on these trucks without SC/ turbo. There are lots of threads. Use the search function and check the search titles only box. Keep trying different keyword combinations, you'll find lots of reading material.
  3. Jun 13, 2016 at 5:37 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    The cheapest and easiest thing you can do is drop weight from the truck if you want to make it quicker. Take out unneeded tools, run OEM size tires, no roof racks, no gas cans, light bars, etc.
    Or you can spend a few thousand on a supercharger or performance tuning.
  4. Jun 13, 2016 at 6:05 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  5. Jun 13, 2016 at 10:28 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    ChadsPride and ODNAREM like this.
  6. Jun 13, 2016 at 3:45 PM
    xbxb
    xbxb Well-Known Member
    Jim
    O.P. Kansas
    2013 SR5 DC, SB, 4WD Pyrite Mica,
    undercover flex, Clazzio seat covers, Flyzeyes, Pop N Lock, Shackle to drag me out
    That's like $60 per 1 hp!
    Crom and ChadsPride like this.
  7. Jun 13, 2016 at 5:17 PM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Smaller and thinner tires will make it accelerate faster. And you can also do like 2015WhitOR said and drop weight. Ditch spare tire and unused seats and anything else not needed.
    It may sound stupid, but what do you expect? Needs a sc or turbo.
  8. Jun 14, 2016 at 4:26 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    At least the argument has shifted from "mods don't give you any improvements," to "it's to expensive."
    Progress. :thumbsup: :laugh:
    For those that didn't proceed onto the page with what all is included - http://urdusa.com/store/URD-Perform....html?osCsid=a7d2c5f57a00988a8c5b2c4b32a32c60
    $1500 of that $3k is the UCON alone. This is why I said buy the pieces individually. Then $1500 for multiple parts isn't too bad.
    Either way, it is N/A. The dollar per hp is always higher than F/I. These N/A mods work with the two s/c kits available, so then it becomes an even worthier investment.
  9. Jun 14, 2016 at 6:53 AM
    JustADummyInATaco
    Riley
    UTAH
    So I think my main goal is to get my truck to be as powerful and prepared as possible because I want to eventually step up to 35 inch tires. I don't really care about how fast I go. I just know those 35's will be parisitic on the motor, so I want to have the best fighting chance I can.
  10. Jun 14, 2016 at 7:43 AM
    327 Well-Known Member
    Mark
    Covington, LA
    Former 06 TRD Sport Silver Current 06 Sport 4Runner
    I'm not trying to hijack, but has there been any attempt to bore/stroke these blocks to get a little more power? It seems like if you were going to rebuild the shortblock and had unlimited money... maybe it could be done?
    But by that point, it might make more sense to squeeze a 4.7 V8 into it. Just wondering out loud basically.
  11. Jun 14, 2016 at 8:08 AM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    practical tip, move to 100% synthetics. Especially for the x cases, axles, manual tranny - I have had good results with Redline oils, as has a mechanic friend, and guy I met that works at a local dyno shop. It is not going to add horse power but you will loose less HP to driveline friction more so if you have a stick shift.
    Maybe not so practical is having the cylinder heads shaved- get the compression up. I have done both of these on a prior Jeep i owned- not huge gains but noticeable.
  12. Jun 14, 2016 at 9:37 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    What about leave it all alone and just regear to make up for the larger tires?
    WOODEX M.E. and Neutral like this.
  13. Jun 14, 2016 at 1:11 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I have an over bore 4.18L 1GR and a 4.3L stroker 1GR.
    327[QUOTED] likes this.
  14. Jun 14, 2016 at 1:22 PM
    eon_blue
    Azusa, CA
    There's no replacement for displacement. That said, the closest you'll get is forced induction. Anything short of that offers little to no gains and is mostly just done for looks/sound.
    Shedding weight and re-gearing are possible options, re-gearing especially if you're concerned about larger tires affecting performance.
    WOODEX M.E. likes this.
  15. Jun 15, 2016 at 8:37 AM
    Woundedyak
    Woundedyak Well-Known Member
    Indy
    LS3 or be the first to try and get a ecoboost In there.
