Improving Gas Mileage
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xspmachine18, Oct 16, 2018.
  1. Oct 16, 2018 at 8:43 AM
    xspmachine18
    xspmachine18 [OP] Member
    South Carolina
    2018 Gray Tacoma SR5 XSP 4x4 Double Cab
    On average i get 15 mpg in the city and with gas being so overpriced its burning a hole in my wallet. Anyone have a suggestion on how to improve mpg?
  2. Oct 16, 2018 at 8:44 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Drive slow, keep engine under 2k RPM.
  3. Oct 16, 2018 at 8:46 AM
    AlabamaBlackSnake
    AlabamaBlackSnake Well-Known Member
    Jim
    4wd TRD OR 2017 dcsb
    Chrome..lot of chrome
    Man I thought mine was bad at 18mpg. I thought that’s why we got a sluggish 6cyl and tranny that hunts for gears. Try runnin premium a few tanks see if it improves gas mileage. A guy in another thread claimed this helped MPGs so much that people were coming out ahead despite the cost of premium
    Junkhead and Coma owner like this.
  4. Oct 16, 2018 at 8:46 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    If its city only driving then there is not a whole lot that can be done. Your burning up all your fuel accelerating. If it was highway, then you could do some aero dynamic changes, but they would be minimal (2-3 mpg)
    For city, just accelerate slowly, and start coasting early.
    RA77, Junkhead and Blazingbluesport like this.
  5. Oct 16, 2018 at 9:44 AM
    DHerrm
    DHerrm Well-Known Member
    Daniel
    2018 SR5
    I am mostly city driving and I average 23mpg. I'm big on the tranny in general but 23mpg works.
    RA77 likes this.
  6. Oct 16, 2018 at 9:57 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    I get 22mpg combined consistently from driving an hour to work half city half freeway every day, I don't drive necessarily slow either.
  7. Oct 16, 2018 at 10:03 AM
    1911tex
    1911tex Well-Known Member
    2018 Silver Metallic Limited
    Learn how to hyper mile....I learned it driving my wife's Prius. Amazing what a little coasting will do! Now I just ignore the tailgater and it works.
    RA77, Tacompa, specter208 and 3 others like this.
  8. Oct 16, 2018 at 10:10 AM
    phsycle
    phsycle Well-Known Member
    CA
    City miles. You'll spend $3k on lighter tires, lighter wheels, aero mods, etc. Which will net you maybe 1mpg. You'll break even in 40 years.
    You might as well get an e-scooter, bike, or another commuter.
    jmneill, 4×4×4, auskip07 and 5 others like this.
  9. Oct 16, 2018 at 10:11 AM
    Jfish12
    Jfish12 Well-Known Member
    2017 Black Tacoma TRD Sport RWD
    21 mpg mixed and have BFG KO2s c-load. Also RWD. With stock I got 24 MPGs mixed... that was nice.... I don’t race people with my truck. Get the TSB updates and you will be fine.
    Go all stock if you want great MPGs, drive like a granny, and remember it’s a truck....
  10. Oct 16, 2018 at 10:12 AM
    psmura
    psmura Well-Known Member
    Paul
    Syracuse, NY
    2018 TRD OR MT
    Slow down and ease back on acceleration. Your not going to get much better driving in the city with a truck.
    There are much easier ways to save money in your everyday life that can be used to offset rising gas prices.
    4×4×4 and over60 like this.
  11. Oct 16, 2018 at 10:16 AM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    Inertia management is definitely the key. Traffic can complicate that considerably though. My mileage to work varies between 23 and 19.
    I use the real time mileage bar to determine the right pedal input. A mm of pedal travel can be the difference between 20 and 12.
    The most is gained by coasting though. During a decel in drive the ECM cuts fuel which makes mileage infinite. Try to figure out how to coast as much as possible between traffic lights and you will start seeing a big difference.
    Most drivers I watch just go back and forth between the gas and brake with no coasting at all. Think ahead and let momentum bleed off if you know a stop is ahead.
    Junkhead, AKGSD, joepagejr and 3 others like this.
  12. Oct 16, 2018 at 10:22 AM
    AlabamaBlackSnake
    Jim
    What’s the fuel tracker website say this truck gets? Fully?
  13. Oct 16, 2018 at 12:23 PM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Cheapest way to improve your mileage is to run your tires at the max PSI. Aside from that, take a look at your driving style. Less braking = better mileage. Be sure to use the same foot to operate both the gas and the brake.
    RA77 likes this.
  14. Oct 16, 2018 at 12:25 PM
    T4RFTMFW
    Burning up $600 tires by having them overinflated is a funny way to squeeze an extra mile out of 30 cents.
    RA77, th3118, twitchhero and 9 others like this.
  15. Oct 16, 2018 at 12:31 PM
    Taco Mustard
    Taco Mustard Well-Known Member
    TRD SPORT
    Stay under 2000rpm. I have a tank of 93 in now. I drove about 80mph when I could during my 90min commute and was stuck in slow moving traffic for 30mi of it. Got to work with an average of 20.3 on the lie-o-meter. Even I thought it would have been higher then that using 93. With a tank of 87 on a normal commute I’m just shy of 23mpg normally. So the extra cost is not worth it in my opinion. The other thing is it’s a truck which has NEVER gotten great gas mileage and I knew that going into it. However I do save money on the HEMI I traded in.
  16. Oct 16, 2018 at 12:38 PM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    I get 24-25mpg on tanks with no highway driving. Slow acceleration and tires kept 38-39psi.
    mu.n8ball likes this.
  17. Oct 16, 2018 at 12:59 PM
    1911tex
    5# tire pressure over door recommendations will actually extend life of tires and better mileage due to temp changes and periodic air refills @ 5# under. Unless you have Michelins which really hold pressure longer, don't know why, but my experience proves it. Remember, the Tacoma weighs almost 5k #'s loaded ! Its a TRUCK.
  18. Oct 16, 2018 at 1:02 PM
    Pine State
    Pine State Well-Known Member
    Maine
    2018 Tacoma DCSB SR5 4x4
    Same here but my stock tires are at about 32PSI cold.
  19. Oct 16, 2018 at 1:17 PM
    Xena1
    Xena1 Well-Known Member
    Ron
    2017 Tacoma Access Cab
    I run 89 octane non-ethanol gas and always get 20 mpg+. On highway trips get 22 mpg+.
  20. Oct 16, 2018 at 1:21 PM
    Travelinman301
    Travelinman301 4 x 4 Fanatic
    Florida
    2018 Blazing Blue Pearl Tacoma TRD Sport 4 x 4 DCSB
    KDMAX-PRO-10.0 Diode Dynamics Sport Fog Lights Morimoto Clear Tail Lights TRD Skid Plate
    I'm averaging over 24mpg combined city and highway driving to and from work. I just don't understand the 1st and 2nd generation owners that say an increase of "a few miles per gallon" is just not a big deal. I'm in the electrical trade and when back in the 80's Panasonic had a 15 watt screw-in A19 compact fluorescent light bulb. They went balls to the wall to develop a 14 watt that put out the same lumens as the 15 watt. Doesn't sound like much to save 1 watt but after a year, they had success. That research and development cost them neatly 3 million dollars. Point being, any savings in any industry is a big deal because God only knows how much it cost Toyota in R & D to "save a few mpg". It is a big deal to the developers and most consumers.
    Kai420, RA77 and Intrepid like this.
