Improving Gas Mileage
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xspmachine18, Oct 16, 2018.
  1. Oct 16, 2018 at 5:52 PM
    #41
    fmrjeep
    fmrjeep Well-Known Member
    Northern Utah
    2018 Inferno Tacoma SR5 DCSB
    Black Softtopper Coverking Seat Covers
    It was slightly downhill the entire time. That second one where I averaged a bit over 29 mpg was going from around 7,000 to around 4,500 over that 100 or so miles.
    Edit: The total round trip was 279 miles which involved driving into the Uintas in Utah. Overall we average mpg according to Fuelly was 24.7 mpg running Maverick 87 octane.
    SpeySquatch[QUOTED] likes this.
  2. Oct 16, 2018 at 5:54 PM
    #42
    SpeySquatch
    2016 TRD OR DCSB
    Don’t think I’ll be hyper miling with this. I’m familiar. I got 25mpg in WY going flat but that was stock.
  3. Oct 16, 2018 at 6:29 PM
    #43
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Put that front deflector back.
    I never went below 20 mpg since I got the truck and I commute daily in one the worst metro traffic in US. ..and hills.
  4. Oct 16, 2018 at 6:29 PM
    #44
    MidCitiesMildMan
    MidCitiesMildMan Well-Known Member
    2017 Toyota Tacoma Limited
    Stock and staying that way
    You don't have to get crazy with it, but knowing about fuel cut on deceleration helps a good bit.
  5. Oct 16, 2018 at 6:38 PM
    #45
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Plan your trips so you are driving in the same direction as the Earth’s rotation. A lot of people don’t believe it, but it works.
  6. Oct 16, 2018 at 6:46 PM
    #46
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    How does that work?
    not knocking, genuinely curious.
  7. Oct 16, 2018 at 7:21 PM
    #47
    Stocklocker
    17TRDORDCSBAT
    Closest I could find to an online answer is below. The difference is so small to be imperceptible, but had to do with the perceived mass of the vehicle when it comes to overcoming inertial forces. I had an old science teacher who told me that it was measurable over a 1000 mile road trip, but only if wind and traffic were somehow identical in both cases, so mostly I was being a smart ass with my answer, but it is true.
    https://www.quora.com/Assuming-no-w...ilage-heading-west-due-to-the-earths-rotation
  8. Oct 16, 2018 at 7:24 PM
    #48
    SpeySquatch
    2016 TRD OR DCSB
    What’s really crazy is the earth is spinning around a 1000mph.
    24,300 er so miles around the belt
    24hrs in a day
    Stocklocker[QUOTED] likes this.
  9. Oct 16, 2018 at 7:35 PM
    #49
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Sorry if I missed it in prior post but what modifications have you done? Have to lifted the truck, put on larger tires, added weight with a steel bumper or shell? All of these will significantly affect mileage. The best mileage you're going to get is with a factory stock truck and maybe lighter, skinnier, higher pressure tires.
    Vlady likes this.
  10. Oct 16, 2018 at 8:25 PM
    #50
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    the truck rolls much loooonger after i had the ECU update done 1,000 miles ago it doesn't fell like the brakes are dragging now... ps i think my mpg is up a mile or so also.
    Ps jacking the psi over 35 will make the truck drive and ride like shit
  11. Oct 16, 2018 at 8:32 PM
    #51
    spiros1
    spiros1 Well-Known Member
    tung
    2017 trd sport double cap inferno
    pro grill, moonroof, plastidip flares
    After upgrading to bfgoodrich at tires i got 17 mpg most of the time but then i got the software update from dealer , mgp was lot better mostly 20 mpg now.
  12. Oct 16, 2018 at 8:54 PM
    #52
    Taco Pusher
    Taco Pusher Well-Known Member
    Brian
    2016 Red TRD off road
    None yet
    hire a flat bed to tow you everywhere.
    Littletinytaco likes this.
  13. Oct 17, 2018 at 8:21 AM
    #53
    DHerrm
    DHerrm Well-Known Member
    Daniel
    2018 SR5
    I drive 35 miles to work and 75% of it is stop and go. I may have more than 50 feet between corners and lights but it's 35 miles that takes me 80+ minutes. I average 20-25mph
    My AC makes a big difference. I get 25-26 in the morning on my way to work without it. Same traffic on the way home and I get 18-19. I drove 80mph on my first quarter of the tank I'm on right now and I'm at 21 right now. Lower than normal. I am pretty sure it's because aside from long interstate drives in a 70mph zone when I go 80, I don't drive like I'm 16. It's the same reason I felt zero improvement from the transmission software update.
  14. Oct 17, 2018 at 9:30 AM
    #54
    DHerrm
    Daniel
    2018 SR5
    That would only work if the earth was rotating. It's flat, we all know that.
  15. Oct 25, 2018 at 6:58 AM
    #55
    xspmachine18
    xspmachine18 [OP] Member
    South Carolina
    2018 Gray Tacoma SR5 XSP 4x4 Double Cab
    If I drive like a grandpa I can manage about 18 in the city
  16. Oct 25, 2018 at 10:28 AM
    #56
    SpeySquatch
    2016 TRD OR DCSB
    Are you OVTuned? If not that must be why. I can’t get below 16.5mpg if I drove normal and not lead footed
  17. Oct 30, 2018 at 6:46 AM
    #57
    xspmachine18
    South Carolina
    I’m all stock except for wheels and tires that came as an offroad package from the dealership.
  18. Oct 30, 2018 at 6:47 AM
    #58
    xspmachine18
    South Carolina
    What is an ov tune
  19. Oct 30, 2018 at 6:50 AM
    #59
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    take off the heavy AT Tires
  20. Oct 30, 2018 at 6:53 AM
    #60
    kite_325
    kite_325 A simple human, being
    North Carolina
    2017 TRDOR
    Keep your air dam and lose the aftermarket equipment. I’ve never heard of anyone getting better mpgs with mods. Sure, your truck won’t be as pretty, but it will certainly sip with its pinky up instead of guzzling gasoline
    Intrepid likes this.
