Improving mall crawling (i.e., road handling)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crvz, Nov 3, 2019.
  1. Nov 4, 2019 at 4:03 PM
    44-16 Taco
    44-16 Taco Do I look like a guy with a plan?
    KMS
    2017 SuperWhite DCORSB
    That's probably why he chose not to elucidate his point
  2. Nov 4, 2019 at 4:13 PM
    xaircav
    xaircav Well-Known Member
    Bill
    Wheat Ridge, CO
    '10 TRD Access Cab 6 speed manual
    TRD intake, skid plate, cat back exhaust and short throw shifter. Bilstein 5100 leveling front and 5100 shocks rear. 32” Falken WP AT4W tires on Gen 3 wheels.
    eurowner[QUOTED] likes this.
  3. Nov 11, 2019 at 7:06 PM
    Inferno!
    Inferno! Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
    Just ordered Hellwig sway bars. Thanks for the feedback.
    su.b.rat likes this.
  4. Nov 11, 2019 at 7:41 PM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    You could have tried a sway bar from a TRD sport.... lord knows there's enough people taking them off
    xxTacocaTxx likes this.
  5. Nov 11, 2019 at 7:47 PM
    Inferno!
    El Dorado Hills
    Too small.
  6. Nov 11, 2019 at 7:48 PM
    swissrallyman
    Bigger than what's on the Offroad and feels a lot different actually
    Inferno! likes this.
  7. Nov 11, 2019 at 8:01 PM
    Inferno!
    El Dorado Hills
    I ordered Hellwig....bigger than TRD Sport.
  8. Nov 11, 2019 at 8:54 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Just keep in mind the sway bars will limit your rear travel to minimal and seriously tear stuff up if you go mildly off road like anything bigger than a speed bump at the mall.
    Inferno![QUOTED] likes this.
  9. Nov 11, 2019 at 9:04 PM
    Inferno!
    El Dorado Hills
    True that. I’ll either disconnect swaybars or more likely use my crawler for crawling. :D
    Grossomotto[QUOTED] likes this.
  10. Nov 11, 2019 at 9:11 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    You might play around with tire pressure. I just got new tires and the shop set the psi at 29 (which is on the door sticker). I like the handling better at 34 psi.
  11. Nov 19, 2019 at 9:17 AM
    Inferno!
    El Dorado Hills
    Thank you @St.Germain for the reviews on the HellWig sway bars in this post and others. Your information help me decide to install them. I'm still getting the "feeling" of the new bars and haven't pushed them to the limit. My initial impression is that the front bar is really great. Very stiff and a significant upgrade from the stock OR bar. I like it a lot. I drove for a few days with just the Hellwig front bar and no rear bar. Body roll was significantly reduced. I'm sure I had major under steer in this configuration. I put on the rear bar and frankly, I couldn't even notice the difference with or without the rear bar under normal driving. Felt just like only having the Hellwig front bar. I think the rear bar is a little light for my taste even though I have it set on the stiffest setting. It is pretty small diameter bar for a heavy vehicle. Hellwig probably designed the bars to maintain some under steer for safety (not a bad thing). I will do some additional testing and might keep my eye out for stiffer rear bar. I'm very familiar with big sway bars on heavy cars, but not on trucks, so I'm learning as I go.
    Overall, I love the HellWig sway bars on the Tacoma. Much better fun factor to drive and more stable and better turning.
  12. Nov 19, 2019 at 10:27 AM
    Inferno!
    El Dorado Hills
    I just went out and over drove my Taco a bit. Towards the limit, it performs really well in a turn. Almost like the rear bar comes into action under hard cornering. I mentioned in my previous post that the rear HellWig bar is pretty light weight. Now, I'm not sure that is the case. I need to do some more doughnuts for additional testing. :D It might be alright after all.
    Dave3359 likes this.
