Improving The 3rd Generation Tail Lights
Discussion in 'Lighting' started by CanesFan95, Jan 18, 2020.
  1. Jan 18, 2020 at 7:59 AM
    CanesFan95
    CanesFan95 [OP] Well-Known Member
    Florida
    Currently Shopping...
    I've always thought the 3rd generation brake lights and turn signals were lackluster. Those small little 'L' shaped dealies are thin, dim, and just not very vivid. They should've made 'em with bigger brighter lights that light up the whole panel. Too many times I'm behind a Tacoma and barely notice they're signaling a turn. And I've always preferred yellow turn signals like on the older generations.
    So what are some good options to improve this? One thing I've seen out on the road a couple times are these strips of LEDs that go along the bottom of the tailgate, like these:
    https://www.amazon.com/OPT7-Redline-LED-Tailgate-Light/dp/B00Z8TGYR6?th=1
    They work in sync with the turn signals and reverse lights and are a real improvement. Any other ideas? And am I the only one who thinks the stock tail lights are just plain dismal?
    Tullie D likes this.
  2. Jan 19, 2020 at 6:09 AM
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    Check out meso customs total tail kits.
    Tacospike likes this.
  3. Jan 19, 2020 at 7:09 AM
    CanesFan95
    Florida
    That's interesting. They're sold out and can't see the price, but an earlier thread shows they're $150.
  4. Jan 19, 2020 at 7:28 AM
    slowlane
    AZ
    16 double cab MGM
    They sell quick. Follow the total tail for sale thread. The guy that makes them is active on the forums. Super cool dude. Products are top notch and customer service is even better. I have the stage 1 kit. It's a vast improvement over stock. If I had to, I would buy this product over and over.
  5. Jan 19, 2020 at 6:42 PM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    Welcome to the forum from Eastern North Carolina. :thumbsup:
    Use your imagination. o_O
    https://youtu.be/isuOE3UoI4k
  6. Jan 20, 2020 at 4:07 AM
    CanesFan95
    Florida
    Good demo video, there. Definitely some ideas that look good...
  7. Jan 20, 2020 at 2:18 PM
    Tacospike
    Two Trucks
    stage 1 runs $150
    Stage 2 runs $220 if I remember correctly (what I have)
    stage 3 will probably run somewhere under $400 but somewhere in the $300-400 range. It released yet, just upgraded output leds. Just speculating for the price as pricing from VLED pricing for extreme brake lights ($175 a pair)
    The last run of stage 1’s were in stock for weeks though
    MESO likes this.
  8. Jan 21, 2020 at 2:36 PM
    Xx_Evilvirus_xX
    Xx_Evilvirus_xX Well-Known Member
    Houston, TX
    2018 Tacoma TRD Offroad 4x4
    Toyota should have made oem led tail lights from the start. 4th gen T4R have them why not us
  9. Apr 28, 2020 at 11:28 PM
    BearWithMe
    BearWithMe Well-Known Member
    Four Corners
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    Every truck I’ve seen with a thin light strip below the tailgate has a bunch of burnt out LEDs and it looks like crap. When you have hundreds of individual emitters your chance of failures goes way up. Better to replace your factory bulbs with some good LED bulbs. You can wire up your tail and turn so that both segments light up together. I used a “Turn As Tail” module.
