impulse red paint
Discussion in '1st Gen. Tacomas (1995-2004)' started by jcremeans11, Jan 9, 2011.
  1. Jan 9, 2011 at 2:47 PM
    jcremeans11
    jcremeans11 [OP] Well-Known Member
    Jon
    Ohio
    01 Tacoma SR5
    Spectre Cold Air Intake, Michelin XLT's (265/70/16), Escort Solo S3, Grounded Throttle body
    I went to autozone and couldn't find any paint specifically meant for the impulse red Tacoma, is there another color that's close to it? I'm painting a headlight filler so I need a spray can.
  2. Jan 9, 2011 at 5:06 PM
    jcremeans11
    Jon
    Ohio
    01 Tacoma SR5
    bump...anybody?
  3. Jan 9, 2011 at 5:19 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    I got duplicolor that matches from Canadian Tire. They had it in both touch-up and spray can. I believe it was 3P1, which is #1609 in the cans
  4. Jan 11, 2011 at 3:03 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Yep - Impulse Red Pearl = Toyota paint code 3P1.
    A good paint shop should be able to order or mix up some if you give them the factory paint code.
