In a jam 4WD stuck on!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nelz1, Mar 23, 2012.
  1. Mar 23, 2012 at 5:43 AM
    Nelz1
    Nelz1 [OP] Well-Known Member
    Boston
    07 Tacoma DC TRD - 20 Tacoma DC off road
    Bilstein 5100 leveled bed panels fabricated, bed d rings, fog light mod.
    :confused:Help Can anyone recommend how to manually release the four wheel drive put a boat in yesterday and now I cant get out of 4 low.
    The trucks in a lot 15 miles away and wanted to get it home.. tried driving to disconnect , tried unplugging the battery for awhile too?
    Just wanted try some other fix befere flatbeddding it..
    Thanks!!! :confused:
  2. Mar 23, 2012 at 6:24 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    im guessing somethings wet under there. i would think that in order to shut it off youd have to remove an actuator probably. id try disconnecting the actuators plug at the transfer case and spray some wd 40 into it to help dry it out. it may dry on its own since its nice out today. might wanna check the fuse for that also in case something shorted...good luck sorry im not a lot of help
  3. Mar 23, 2012 at 6:25 AM
    fixer5000
    massachusetts
    one more thing. next time use 4 high instead. at least you can get her home
  4. Mar 23, 2012 at 6:31 AM
    arrrghhh
    arrrghhh Well-Known Member
    Denver, CO
    09 TRD Off-Road
    Custom Front Bumper, Smittybilt XRC-8, 3" OME lift, 33" Falken A/T tires
    This ^^. Does it even seem like it's trying? What's happening?
  5. Mar 23, 2012 at 7:35 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    um, stick it in neutral like the manual says, make sure your foot is on the brake, no e brake and then take it out of 4l. Try rolling forward a bit, brake, then go neutral again and re-try.
  6. Mar 23, 2012 at 7:38 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Sounds like you need to seize the carp and go drive up a mountain. Look at this as a good thing. It wants to be driven.
  7. Mar 23, 2012 at 7:39 AM
    Nelz1
    Boston
    Thanks guys!!!
    I didnt get the tranny wet and it beeps when the dial is in 2hi and 4hi not in 4low but the truck is stuck in 4low still I'm going to look for some plugs on the transfer case maybe for an actuator and unplug them for awhile and keep trying until tow time...SUCKS
  8. Mar 23, 2012 at 7:45 AM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    My 2009 got stuck in 4low yesterday. Blinking light and beep. I kept rocking it back and forth and hitting the brakes and then stopping and trying the switch took a few mins but finally disengaged.
  9. Mar 23, 2012 at 7:48 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Try going in reverse, stopping, jerk it forward a bit. Sometimes it just takes some nudging.
  10. Mar 23, 2012 at 7:49 AM
    WhiskeyDeltaTango
    WhiskeyDeltaTango Resident Redneck
    Will
    Braselton, Georgia
    Dirty Black Taco
    ARB Bull Bar, ProComp 9" lights, Dual Hella aux backup lights, WARN VR10000, OME 886x, Dakar Leafs, UWS Low Profile Toolbox, Kicker CVT10, Kicker 750.1
    blinking light and noise means its not engaged.
    to engage 4lo:
    put truck in neutral, select 4lo, put truck in drive.
    use this same order to disengage 4lo:
    put truck in neutral, select 2hi, put truck in drive.
  11. Mar 23, 2012 at 7:50 AM
    Kappes03
    Kappes03 Legend of the UG
    Colorado
    2014 Tundra CM
    Also what Whiskey said.. if it's flashing and beeping while your switch is in 4lo, then it's now in 4lo.
    Edit: read above.. so it's in 4lo and engage if it's not beeping with the switch there.
    Auto or manual?
    if it's a stick, have the switch in 4lo, put in neutral, press the clutch completely to the floor, switch to 4hi, drive a few feet, if it goes in 4hi, then do the same for 2.
    That's the steps I take
  12. Mar 23, 2012 at 8:16 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    It could be that driveline is wound up. Ive never done this, but maybe try jacking up each wheel until its off the ground, then lower it. After youre done with all 4, then do the rolling it foward and backward in neutral thing.
    Are the lot and boat ramp paved?
  13. Mar 24, 2012 at 6:10 AM
    Nelz1
    Boston
    So I went the next morning and took my time opened the book did the whole neutral brake thing took deep breathes and it came out of four wheel.
    I've always just turned the four wheel knob at a stand still and its worked,(the neutral step I think was overlooked)
    Should of opened the book right away instead of running to to the forum lesson learned.
    Appreciate everyones speedy responses and all the input!!!!:D
  14. Mar 24, 2012 at 6:31 AM
    Kappes03
    Colorado
    2014 Tundra CM
    :thumbsup:
  15. Mar 24, 2012 at 11:17 AM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    I was in 4 hi yesterday and move it into 2 wheel like I normally do. The light stayed on. I had to engage into 4 low then back into 4 hi, then it allowed me it disengage 4 wheel drive. Weird moment, hopefully it doesn't happen again.
  16. Feb 10, 2014 at 10:23 AM
    ldwarner
    ldwarner New Member
    SR5 DC 4x4
    Hey Duke, had the same thing happen to me yesterday while I was coyote hunting. I had just driven slowly though a rough snowy corn field. I was stuck in 4H, did the same thing you did and it went out and worked ok the rest of the day. Have you had it happen again?
  17. Feb 10, 2014 at 10:51 AM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    Random question OP, when was the last time you used 4wd? I engage mine pretty often and it goes in and out smoothly. I know you are supposed to engage it every month or so to keep everything lubed up.
