In bed outlet.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cooktop86, Jul 20, 2017.
  1. Jul 20, 2017 at 6:50 PM
    Cooktop86
    Cooktop86 [OP] Well-Known Member
    Jeff
    Hatfield, Pa
    2017 Tacoma TRD sport MGM
    Does anyone use the outlet in the bed? I'm going to a tailgate at a baseball game this weekend and some of the guys I'm going with want to use the outlet in the bed for a radio. I know the radio does not exceed the allowable power but I just don't want to go to leave the game to a dead battery.
    TXpro4X4 and Benzdriver81 like this.
  2. Jul 20, 2017 at 7:47 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    That's no problem. Start the truck up once a while if you are worried about it...or bring jumper cables. Either way, you'll be fine
    outlawtacoma and Cooktop86[OP] like this.
  3. Jul 21, 2017 at 3:35 AM
    Cooktop86
    Jeff
    Hatfield, Pa
    Thanks.
  4. Jul 21, 2017 at 3:51 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    I would imagine you could run a radio for a LONG time without running down the battery.
    A jump pack is your best friend, they are reasonably cheap nowadays and one should be on the list of ''just in case'' items one keeps in their vehicle.
  5. Jul 21, 2017 at 6:03 AM
    rewted
    rewted Well-Known Member
    2017 Black TRD Off-Road Double Cab Short Bed
    Warn Zeon 10-S, BFG KO2 265/75/16, Bakflip MX4, Split Dual Battery System, TRD Pro Grille, Tokonsha P3 Brake Controller, ScanGauge II
    Dual Battery system just for this (and other bigger purposes)
  6. Jul 21, 2017 at 6:29 AM
    mbarbay
    mbarbay Well-Known Member
    Baton Rouge, LA
    2016 Tacoma BBP DCSB LTD 4X4
    how much power does it take. doesn't the truck have to be running for he 400W anyways? only 100W if truck isn't running
  7. Jul 21, 2017 at 6:50 AM
    rewted
    I could be wrong here but I think it's 100W in motion and 400W in park. I don't know if that changes with the engine off. But it'd be an easy test because there's an indicator.
    Tacowin1013 likes this.
  8. Jul 21, 2017 at 6:53 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    Well that not a problem running the battery dead bc the outlet wont work with out the truck running... 400W idle and 100W while driving.
    Edit: I actually charge my Ion speakers all the time that lasts 12 hrs on 75% volume. If I forget to charge it before a trip I'll plug it in on the way over to the event which is usually enough.
    TomTwo and pra4sno like this.
  9. Jul 21, 2017 at 8:09 AM
    rewted
    No it's actually like I said, 100W in motion at 400W at idle.
    The flip of that doesn't make any damn sense anyway. :)
    http://www.ttguide.net/power_outlet_120_vac_8727_-114.html
    TomTwo likes this.
  10. Jul 21, 2017 at 8:11 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    I've used it a couple of times to charge my dog remote collars when headed to hunting or training grounds because I forgot to plug them in overnight. Otherwise it's not really powerful enough to run any tools. It would probably work fine for a small light or radio...
    Otherwise it's not something I couldn't live without
  11. Jul 21, 2017 at 8:20 AM
    gator2764
    gator2764 Well-Known Member
    Mid Ga
    2016 TRD DCLB 4X
    It runs my electric pole saw and a rather large hedge trimmer. Not at the same time.
  12. Jul 21, 2017 at 8:23 AM
    smitty99
    Scottsdale
    Seriously? It won't push my Shopvac
  13. Jul 21, 2017 at 8:24 AM
    gator2764
    Mid Ga
    2016 TRD DCLB 4X
    Yep. I made up a 25 ft cord and it works great. Long driveway and I got tired of hauling cords. I was surprised it works.
    smitty99[QUOTED] likes this.
  14. Jul 21, 2017 at 8:46 AM
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    smitty99 likes this.
  15. Jul 21, 2017 at 9:19 AM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    Ive used it to trickle my marine battery for the minn Kota a couple times. Worked ok, the outlet in my chev van is way better than this outlet.
  16. Jul 21, 2017 at 9:27 AM
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    I'm pretty sure it's the other way around (unless 3rd Gen is different from 2nd Gen)
    100W driving, idle, and engine off
    400W only during idle.
    I don't think they like vacuums. It won't run my little Costco shop vac either, but it'll run my DA polisher just fine :notsure:
  17. Jul 21, 2017 at 9:30 AM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    shopvac no go for me as well but I have used hedge trimmers before as well.
  18. Jul 21, 2017 at 10:13 AM
    TacoRD16
    Houston, TX
    Yeah I believe another person quoted the Manual. What happens when you just blurt stuff out.
    Benzdriver81[QUOTED] likes this.
  19. Jul 21, 2017 at 10:54 AM
    Benzdriver81
    Kevin
    PNW
    05 DCLB Sport
    Whoops, didn't read every post :anonymous:
    also I was actually curious if there was a difference between 2nd and 3rd Gen outlets. I guess not :fistbump:
  20. Jul 21, 2017 at 11:38 AM
    matt636
    matt636 Well-Known Member
    Central, IL
    2017 TRD Sport 4x4 DCSB Inferno
    and doesn't it only run power when the vehicle is ON - maybe ignition, but still I don't think I can just plug something in. pretty sure that I spent a bunch of time rigging up some rope lights inside by bed under my tonnau cover to plug in for bed lights when needed, only to find out the truck had to be on for it to work, so therefore I quickly removed. my fault for not testing first.
