In bed outlet.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cooktop86, Jul 20, 2017.
  1. Jul 22, 2017 at 7:13 AM
    #41
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    But it's not going to pull 9A at no load. No different than a engine being rated at 350hp. It doesn't produce 350hp all the time. I'm sure that motor is capable of running continuously under load producing 1100W.
  2. Jul 22, 2017 at 8:08 AM
    #42
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    Then it's labeled incorrectly--the UL label indicates 5 A, this is the maximum continuous current draw per UL labeling requirements--this is necessary so that an appliance's maximum continuous power needs can be known and power sources be appropriately sized. UL does not allow HP numbers (BS or otherwise) to appear on the UL rating label.
    Actually vacuum cleaners are allowed by the FTC to be advertised according to there peak horsepower, which is a complete load of BS calculated by using the the startup current. The peak HP is typically determined using just the bare motor, no fan or ducting--inrush current would be less than the 15.5 A I observed with the little Stanley unit. Startup current for just the motor would likely be in the 9 to 10 A range, giving rise to the 1.5 HP number they tout on the unit's front label
    It would burn up if you applied sufficient load to make it draw 1100 W...
    smitty99 likes this.
  3. Jul 22, 2017 at 8:33 AM
    #43
    Cooktop86
    Cooktop86 [OP] Well-Known Member
    Jeff
    Hatfield, Pa
    2017 Tacoma TRD sport MGM
    I have a Dewalt radio but no batteries.
  4. Jul 22, 2017 at 8:38 AM
    #44
    jowybyo
    Joe
    Baltimore, MD
    The rules must be different for vacuums. For blowers and other tools we can't/don't advertise more than the continuous amp draw of the unit. Except in Europe, where you can advertise the maximum capable wattage of the motor, even if you aren't operating anywhere near that. Some of the Worx leaf blower are advertised as 2500W in the EU and are really only using about 1000W. It's kind of annoying because we end up using larger motors than are necessary just to be able to make claims to compete with the competition.
  5. Jul 22, 2017 at 1:37 PM
    #45
    cliffyk
    Cliff
    Saint Augustine, FL
    The UL requires that the amperage displayed on the electrical information label be the actual continuous maximum draw of the device--and as my tests revealed the little vac does indeed draw the 5.0 A shown on the label (I blocked the hose with my hand). It's the silly horsepower numbers claimed that is pretty much unregulated.
    Most "happy homeowner" small 120 VAC air compressors are like this too; the most one can reasonably retrieve from a residential 120 VAC 15 A receptacle is 1500 watts--85% or so of the circuit breaker's rating. If you throw in an 85% efficiency factor for the motor you're down to 1275 watts or 1.7 HP. Yet you will routinely see small 120 VAC compressors claiming 2.5 even 3 HP.
    My Husky 30-gallon V-twin is more realistically rated as 1.6 HP, 15.0 A @ 120 VAC, 7.4 A @ 230 VAC--because that's what it is and Husky did not feel compelled to BS about it.
    I rewired it to a dedicated 20 A 230 VAC circuit because on the "sort of" dedicated 15 A 120 VAC circuit it sometimes groaned to a sluggish start...
  6. Jul 23, 2017 at 11:33 AM
    #46
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    Best post in this thread!!!
    ANTupLIFE[QUOTED] and TeecoTaco like this.
  7. Jul 23, 2017 at 1:14 PM
    #47
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    My delwalt job site battery charger and radio work fine in it.
  8. Jul 24, 2017 at 10:17 AM
    #48
    gator2764
    gator2764 Well-Known Member
    Mid Ga
    2016 TRD DCLB 4X
    Gonna have to check the shop vac
  9. Jul 24, 2017 at 10:53 AM
    #49
    arnette64
    arnette64 Well-Known Member
    Amos, QC (Canada)
    2016 Inferno TRD Sport Double Cab 4X4
    '16 Inferno TRD sport DC
    It's my 2nd Taco and i've never used the in bed outlet once..... :anonymous:
  10. Jul 26, 2017 at 3:21 AM
    #50
    gator2764
    Mid Ga
    2016 TRD DCLB 4X
    Checked my shop vac and it didn't like it either
