In Bed Power
Discussion in '3rd Gen. Tacomas (2016-2023)' started by spence13e, Mar 3, 2021.
  1. Mar 3, 2021 at 12:53 PM
    spence13e
    spence13e [OP] Well-Known Member
    NCK
    2021 Barcelona Red Tacoma OR MT
    NA
    I have no idea what the actual specs on the motor are, I believe it’s a 3/4 hp, but I don’t remember beyond that. It takes a bit to spool up, and I can’t grind super hard on shoes, but it’ll work for most general use of a power outlet is unavailable.
    Just thought I’d kick it out there since I’ve seen it discussed lately and had been curious if it’d do it or not.
    https://youtu.be/IAtS1te3gWM
  2. Mar 3, 2021 at 1:28 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Obviously, it'll spin the motor. Then the question becomes how much can you work it before you start popping the breaker?
    Is there a plate on the motor identifying the amps/wattage? You've only got 400 watts available (400/110 = ~3.6 amps).
    While the power outlet is a neat feature, its capacity is rather limited.
  3. Mar 3, 2021 at 2:31 PM
    spence13e
    NCK
    NA
    yeah that sheet fell off a long time ago. Just by the lag in it, it’ll only potentially do light work.
