In bed storage box..?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GBourne, Oct 15, 2022.
  1. Oct 15, 2022 at 11:00 PM
    GBourne
    GBourne [OP] Just a regular guy
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    Dumped the Tacoma, that's all it needed.
    Is the drivers side in bed storage bin that is recessed in the side behind the wheel optional, is it no longer offered, or..?
    can it be added if I don’t have it?
    2023 TRD sport short box
  2. Oct 15, 2022 at 11:02 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think it disappeared around 2019, if you find one in the junkyard you can always cut the bed and add it to yours.
    GBourne[OP] likes this.
  3. Oct 15, 2022 at 11:03 PM
    GBourne
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    Guess that I’ll have to figure something out then.
    I want to install a battery in that area, but don’t want to have to crawl under the truck to service it.
    Thanks.
  4. Oct 15, 2022 at 11:25 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Google "boat glove box"...:notsure:
  5. Oct 16, 2022 at 5:16 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    The built in utility behind the rear wheels has gone away. It was a sad attempt to provide a storage box. The boxes leaked and weren’t too useful. Placing them behind the wheel provided a perfect place for wheel/water to throw rain mud water from the road. Not too useful unless you have something that can get wet and dirty. You could buy a waterproof box and install it since I believe the space is still there. Good luck
    gudujarlson and GBourne[OP] like this.
  6. Oct 16, 2022 at 7:31 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    the bed box was/is one of the best features of the truck! i actually use my truck to haul stuff, and it's the perfect place to stow ratchet straps and bungies!
    it works perfect at least until i re-build the bedsides sometime in the next 20 years.
    FloridaFree and GBourne[OP] like this.
  7. Oct 16, 2022 at 7:47 AM
    Tacos4Runnin
    Tacos4Runnin Well-Known Member
    Okanagan…eh
    2021 TRD-Sport AG/MT
    This was no longer added as standard after 2018 I believe. I added this box to my 2021, was a pretty simple mod
    I followed this video and did some more digging around online. A member on this forum was kind enough to sell me one of cubby boxes for a decent price shipped
    https://youtu.be/hoeyiCq_x1I
    Although they removed the cubby from the factory, there is nothing in the way stopped you from adding this back to the bed. If you need any advice let me know if I can help out
  8. Oct 16, 2022 at 8:26 AM
    GBourne
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    I think that I will figure out which battery that I want to use and then build a stainless tray/bin to hold it and seal the bed back up.
    Depending on the battery that gets chosen, I may end up creeping into the bed a bit, but an inch or two shouldn't be an issue really.
    Thanks everyone.
  9. Oct 16, 2022 at 8:39 AM
    Greg-tacoma
    Greg
    2016 Black 4cyl 4wd
    I wouldn’t use a conductive material to hold a battery. Some sort of pvc/ harden plastic and a good caulk.
    Chew and AxisCab like this.
  10. Oct 16, 2022 at 8:46 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    My 2022 SR5 has the passenger side one, I find it is a good spot for the 7 to 5/4 pin extension harness I made for my trailers.
  11. Oct 16, 2022 at 8:48 AM
    GBourne
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    Um, I am sure that it will be fine, seeing as how there are millions of batteries being driven around under hoods of cars that are held by conductive materials...
    Obviously I will have to ensure that the battery is properly secured, and the the composite bed is reinforced enough to handle the added weight and stresses, along with finding some adequate bracing points into a steel/aluminum surface.
    I have a feeling that I will be able to figure it out.
    I do appreciate the concern though.
