In cab AC plugs for 5 lug auto
Discussion in '5 Lug' started by jacobigindi, Dec 27, 2011.
  1. Dec 27, 2011 at 9:32 PM
    jacobigindi
    jacobigindi [OP] Well-Known Member
    Jacob
    Socal
    '11 SR5 5 lug AC
    So i've seen PSU Taco85's writeup on the 400 watt inverter but I'm confused as to how to wire just the AC plugs. I just want to install a plug in the bed and one in the center console. Sorry, I'm not very knowledgeable about electrical circuits and I want to understand it before I try and mess with anything. Would I follow his writeup? or is there another one to follow? In other words, do i need to do the 400W mod or can I just install the plugs somehow?
  2. Dec 27, 2011 at 9:35 PM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
    :popcorn: I would like to know this too
  3. Dec 28, 2011 at 6:56 PM
    ISUGrad05
    ISUGrad05 Public Servant Enemy #1
    Wichita, KS
    2012 4x4 5.7 Tundra DoubleCab
    I would look into an aftermarket inverter and mount it somewhere in the cab, maybe under the rear seat and run wiring out to the bed under the truck. 400 watts won't power anything with more than a 3.3 amp draw at 120v. You could probably find an aftermarket inverter rated at 1000 watts that would be good for 8.3 amps which run some smaller power tools.
  4. Dec 28, 2011 at 7:00 PM
    ISUGrad05
    Wichita, KS
    Yes you need an inverter. The inverter contains a transformer to step up the voltage from 14.4v ~12.5v rms to 120v. It also contains the circuitry to convert the voltage from DC to AC.
  5. Dec 28, 2011 at 7:05 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    I installed a 800w inverter under the passenger seat. I have the usb and 120V plug in the front little bin and another 120V plug in the center console. I ran a 4g hot wire from the battery to the inverter through the fire wall and ran my ground to the body.
    Its a Cobra unit I got off of Amazon. It works great!
  6. Dec 28, 2011 at 10:16 PM
    jacobigindi
    Jacob
    Socal
    '11 SR5 5 lug AC
    so it looks like the inverter has two outlets and a usb plug already, so how did you install the plugs where you did? did you just use a power lead directly from the outlet in the inverter?
    sorry, i'm really new to all this :eek:
  7. Dec 28, 2011 at 11:21 PM
    S.B.
    Sean
    5 lug tacos don't come with a factory inverter, you have to buy your own. I bought 2 extension cords (1 per outlet) and chopped off one end (female plug). I bought these: http://www.mouser.com/ProductDetail/Schurter/43000701/?qs=fxxZwZgTYwD60mSnvPxFpA==
    Just cut a hole and snapped them in. For the USB I bout a USB extension cord and cut a hole and glued it in.
  8. Dec 29, 2011 at 12:07 PM
    jacobigindi
    Jacob
    Socal
    '11 SR5 5 lug AC
    aah, i see, thanks, and the inverter just gets hooked up to the battery?
  9. Dec 29, 2011 at 8:41 PM
    ISUGrad05
    Wichita, KS
    Yeah, the inverter installs similar to a car audio amplifier. Fuse and hot lead wire to the battery, and terminal to a suitable grounding point.
  10. Nov 1, 2012 at 4:47 PM
    VA7DRR
    VA7DRR Member
    Don
    Kelowna
    09 Tacoma TRD Sport with a Leer canopy
    a yellow (Nissan Xterra yellow) canopy custom built, 3" leveling kit
    are there any videos on how to install the ac plugs and wires to the trucks inverter?
