In cab, Power Station charging
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TrdAaron, Aug 12, 2023.
  1. Aug 14, 2023 at 12:06 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Here's my question for an all 12v system.
    The EcoFlow has one 12v input. I have a solar panel plugged into it and I have the Taco inverter connected to the AC. When I start the Taco (and remember to push the inverter button :rolleyes:) it auto switches from the solar to AC inverter. If I get a 12v DC-DC charger I don't think you can plug both in at the same time, but I don't know. Having to switch 12v plugs isn't practical for me.
  2. Aug 14, 2023 at 12:07 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    You could get a higher end DC-DC charger that can handle both solar and alternator charge and even combine them. The nice Redarc can do this.
    Naveronski and BKinzey[QUOTED] like this.
  3. Aug 14, 2023 at 6:39 PM
    TrdAaron
    TrdAaron [OP] Well-Known Member
    Ventura, CA
    2012 Silver Tacoma TRD Off Road Access Cab 6MT
    Full OME BP-51 kit, TRD Pro 16in wheels, bel air camper, arb bumper, some other neat stuff….
    I tried using the same cord but plugged into the river pro. It charges for about 3 seconds and gets up to 10W before stopping charging and then another 3 seconds later it restarts that cycle. I reached out to ecoflow. They said “your car is more powerful than others” and as far as DC charging from the outlet goes that I’m out of luck lol.
  4. Aug 14, 2023 at 6:41 PM
    TrdAaron
    Ventura, CA
    That’s what I did when I had a solar panel on my old camper. It worked pretty well. I think if sticking with the power stations AC charging is the way to go. They seem pretty sensitive with DC if over ~100W
  5. Aug 29, 2023 at 6:16 PM
    JDKred
    JDKred Well-Known Member
    JD
    16 MT KDMax Tuned
    What wires did you tap for the in cab 110v outlet? I hear they are different with the manual trucks?
  6. Aug 30, 2023 at 9:54 AM
    BKinzey
    Beauford
    Hollywierd, CA
    I followed the instructions on one of the threads for in cab 120v outlets. I also did the 400w anytime mod. Sorry, I don't have links.
    JDKred[QUOTED] likes this.
  7. Sep 19, 2023 at 9:31 PM
    aarcarr
    aarcarr Well-Known Member
    Arizona
    23 Tacoma TE | 18 4Runner SR5
    08 4Runner SR5 sold 03 Tacoma TRD sold
    Does your River pro let you charge from the 400w AC bed outlet? My River 2 max just clicks like the guy in the video posted earlier
  8. Sep 20, 2023 at 9:31 AM
    TrdAaron
    Ventura, CA
    I had to set my river pro to the SLOW AC charging speed. Then it works fine. I have an older generation of the river pro and I believe in that video he said the newer river series batteries have updated sine waves that are different from the trucks sine wave… or something like that. I would try the slow setting through the app if you haven’t
  9. Sep 20, 2023 at 9:33 AM
    TrdAaron
    Ventura, CA
    I did the in cab outlet. But the truck doesn’t like charging both batteries at once. It gives the in cab battery 200W, while only giving the bed battery 80W and it goes in and out. I think it’s drawing too much for the inverter maybe.
    I think my final answer to this problem is just to pull the trigger on a dual battery and rely on DC to DC charging and call it good.
  10. Sep 20, 2023 at 12:44 PM
    BKinzey
    Beauford
    Hollywierd, CA
    I haven't tried the bed outlet. Other than testing it a few times I find I don't use it. I don't know, but I suspect the stock inverters are of cheap quality. Maybe some work better than others.
    I do know that my inverter's output is all over the place. Sometimes the voltage is as low as 90v and I think the highest I have observed is 126v. It's constantly changing.
    Sorry I can't give more knowledgeable answers.
  11. Oct 22, 2024 at 9:43 PM
    ORtoCOTaco
    ORtoCOTaco Well-Known Member
    Colorado
    2018 White Tacoma TRD Off Road DCSB 4x4
    BodyArmor 4x4 HiLine Winch Bumper, Warn Zeon 10-S, Uptop Bravo Roof Rack, ExtremeLED Super Stealth 40" LED Light Bar, DV8 Offroad 20-Inch BRS Pro Series LED Light Bar, Truxedo Roll-Up Tonneau Cover, Automatic Tailgate Lock, Trailgate panel, cheap Amazon ditch lights.
    How many watts is Slow charging mode taking in?
  12. Oct 23, 2024 at 7:35 AM
    BKinzey
    Beauford
    Hollywierd, CA
    The River Pro slow charges at 100w and fast charges at 660w. I think with the newer versions you can vary the charge rate with the software.
  13. Oct 23, 2024 at 7:46 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    That's a BS answer from ecoflow, the electrical load (ecoflow power box) determines how much power is drawn from the inverter. It will only draw what it can accept, the reason they give you 2 charging rates is some electrical systems cannot provide the power needed to charge the ecoflow at it's higher rate so they offer the option to reduce that, again that's all done in the power bank, the truck is just a dumb charging source. The inverter's output rating sets the upper limit to the power available.
    TrdAaron[QUOTED][OP] likes this.
