In-car tool kit??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Onehugenut55, Feb 14, 2019.
  1. Feb 14, 2019 at 6:23 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    If I drove an old truck it's a different story. I had a 1978 Jeep Cherokee Chief and I couldn't haul enough tools to keep that bitch running. I put a new water pump on it 300 miles from home on a trail on a Sunday morning. Yes I had a spare water pump, along with various gaskets, an axle that always broke and a lot of wire. Oh and a ball joint and tie rod end. It ate tie rod ends. And a drag link too. And a caliper. And a...
  2. Feb 14, 2019 at 6:39 PM
    Lost In The Woods
    Lost In The Woods 4 out of the 5 voices in my head say go for it!
    Eric
    Buckley, WA
    21 Gladiator Rubicon Diesel
    An unusually high amount of pinstriping.
    It depends. What are you're doing and where are you going? With my job, I can be up to 35 miles behind a locked gate and may or may not have cell service. Because of that I have a fairly extensive tool kit along with electrical components. If your just running FS roads you probably would be fine with a basic tool kit with. IMHO if your going to relying on just a cell if you break down, be ready to spend the night.
  3. Feb 14, 2019 at 6:48 PM
    TacoMateo
    TacoMateo Well-Known Member
    Nor Cal
    2019 DBLB TRDOR CEMENT
    I would be careful with a cheap tool kit. I’ve used some that literally fell apart in my hand while using them. Sometimes it pays to have a name brand.
    Not targeting this kit specifically or saying this kit is cheap. Just hard to tell from the picture.
  4. Feb 14, 2019 at 6:56 PM
    Shellshock
    Iowa
    I bought the blue ridge overland tool bag and built a kit based off what’s in the 2nd gen tools thread - sockets, ratchets, Allen’s, torx, end wrenches, etc. Added a few more things like zip ties, tape, gloves. Pretty well set now that I can do nearly anything on my truck.
    Anytime I do work, I use this tool bag so I know I’ve got everything I need.
    Landpirate likes this.
  5. Feb 14, 2019 at 7:03 PM
    Landpirate
    Landpirate Strong like horse, smart like tractor
    North Texas
    2018 Tacoma BBP SR5 4x4 DCSB
    OME HD leafs, 5100s, CaliRaised skids, UpTop Overland Bravo, KB Voodoo rack, Overlander RTT/awning, DECKED
  6. Feb 14, 2019 at 7:07 PM
    Landpirate
    North Texas
    I did pretty much the same thing with a DECKED D Box and the 3rd gen tool list, plus a few other things. In a Cross Box I have a tire kit, compressor, and battery jump pack.
  7. Feb 14, 2019 at 7:15 PM
    Professional Asian
    Professional Asian Ridgeline Enthusiast
    Andrew
    Eureka, California
    2017 DCSB TRD off road MT [OVtuned]
    It’s cheap, you’re correct. I’m probably gonna put my Stanley 10mm,12mm,14mm,17mm sockets and ratchet in there anyway
  8. Feb 14, 2019 at 7:17 PM
    Shellshock
    Iowa
    There’s not much I don’t have in my truck. There’s also usually an ARB dual compressor, tire plug kit, plenty of ratchets, tie downs, jump pack and a bunch of other stuff
    Landpirate[QUOTED] likes this.
  9. Feb 14, 2019 at 7:20 PM
    Admiral_Akbar
    Admiral_Akbar Well-Known Member
    '17
    Even comes in Cement.
  10. Feb 14, 2019 at 7:45 PM
    TacoMateo
    Nor Cal
    Smart idea. You can always test them in the garage and see how they do. Sometimes you can find excellent values on Amazon.
  11. Feb 14, 2019 at 9:59 PM
    duckytw
    duckytw Well-Known Member
  12. Feb 15, 2019 at 6:20 AM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
  13. Feb 15, 2019 at 6:26 AM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    Lol my shock broke through the mount one time while offroading and I taped it to the mount until I could get it replaced. Duct tape is the best tool.
    Onehugenut55[OP] and Black64 like this.
  14. Feb 15, 2019 at 6:36 AM
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    https://www.sears.com/kd-tools-tele...MIpM3K6fq94AIVyQOGCh1NBwPwEAQYBCABEgL-6_D_BwE
    IS ONE i WAS LOOKING AT UNTIL i SAW THIS ONE... ALSO NEED TO ADD IN:
    *tire repair /plug kit w/ compressor
    *a good set of jumper cables, along with some welding rod, and a SHORT piece of welding cable with lugs on them (FOR POSSIBLE TRAIL WELDING)
    *a good lug wrench/breaker bar
    *tie down straps
    *recovery gear (tree straps, tow strap, shackles, and a snatch block (ALL RATED FOR OVER 10,000-20,000lbs))
  15. Feb 15, 2019 at 6:47 AM
    #35
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Retro tool kit.
  16. Feb 15, 2019 at 7:03 AM
    #36
    Tallgrass05
    Tallgrass05 Well-Known Member
    I carry a flashlight, headlamp, and Leatherman multitool in the cab. The toolbox carries a few sizes of regular and Phillips screwdrivers, pliers, a crescent wrench, a socket wrench set, duct tape, assorted zip ties, a tire inflator, jumper cables, and a bag of assorted nuts and bolts. I do a lot of kayaking and have pretty much used everything, from jumping people with dead batteries, to helping people with loose battery connections, to replacing a nut and bolt for a kayak seat because someone lost theirs, to inflating trailer tires that were way low.
  17. Mar 15, 2019 at 8:07 AM
    #37
    muffyinva
    muffyinva Well-Known Member
    Reid
    Lynchburg, VA
    2019 Cement Tacoma DCSB OR
    Call me crazy, but the tools that I carried around in my former Dodge I used mainly for non-truck stuff. You know, you are at your kid's house installing a blind or something and you need a tool, and of course they don't have one so you get one from your truck!!
    finethreads and Tallgrass05 like this.
  18. Mar 15, 2019 at 9:34 AM
    #38
    bigonenine
    bigonenine Carnitas Taco
    NJ
    2018 DCSB TRD OR
    I keep tools in my truck mostly for convenience. I live on the 3rd floor so not having to carry them down to work on the truck or bike is nice. Havent needed anything for an emergency repair yet but it will be nice to have them if the time comes.
    I keep a small husky bag behind the back seat. In there is a ratchet set, some torx bits in sizes for the truck, wrenches, needle nose pliers, screwdrivers, hex key set, channel locks, mallet, duct tape, zip ties and other stuff I’m probably forgetting. Also back there I keep a little camping tarp, hammock, bungees, ratchet straps etc.
    Under the seat I keep a little folding saw and shovel for camping trips. Jump pack, First aid kit a couple shackles, gloves, tow straps, and hitch stuff.
    Tallgrass05 likes this.
  19. Mar 15, 2019 at 10:35 AM
    #39
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
  20. Mar 15, 2019 at 10:38 AM
    #40
    eon_blue
    Azusa, CA
    I keep this Craftsman set in my truck, along with a few other things I know I need that the kit doesn't have (bigger sockets mostly).
    I picked this up last year when Sears had it on sale for just $30 bucks. Only thing that sucks about it is that all the sockets are so small they don't work for things like the diff/tcase/transmission plugs but I have a smaller tool bag with those in them.
