In Depth Review Videos + Official Release Info: Overland Tailor Tuning OTT Tune for 4th Gen Tacoma
Discussion in '4th Gen. Tacomas (2024+)' started by RCTuningFL, Feb 1, 2025.
  1. Feb 1, 2025 at 3:07 PM
    RCTuningFL
    RCTuningFL [OP] OTT Tuner - Florida/Puerto Rico/Caribbean
    RC
    Melbourne, FL & Luquillo, Puerto Rico
    2020 Tacoma TRD Pro @rctuningflgarage
    OTT + Magnuson Supercharger w/ 80mm - 5.29s etc etc.
    IN-DEPTH Review Of The OTT Tune For The 4th Gen Toyota Tacoma! A great video showing the R&D, testing, dyno data, interview with Overland Tailor Tuning OTTs lead calibrator and much more.
    https://youtu.be/h6LeIMX8RVs
    Part 2 Video! 4th Gen Hyrbrid hits the dyno. For those of you waiting on the next gen tunes, the wait will be worth it. Overland Tailor Tuning OTT - Tried, True, Tested! Be sure to follow OTT on FB and Insta for all the latest!
    https://youtu.be/5VqZQx0YPBE
    Please head on over to the official post by OTT on Tacomaworld for full details - https://www.tacomaworld.com/threads...-overland-tailor.759590/page-99#post-30484637
    Overland Tailor Tuning (OTT) is proud to announce the official release of our highly anticipated ECU and TCU tuning solutions for the 2024+ Toyota Tacoma, featuring the 2.4L (T24A-FTS) engine in both gas and hybrid variants.
  2. Feb 1, 2025 at 3:51 PM
    gemiv19
    gemiv19 Well-Known Member
    Ted
    Central Point OR
    2024 DCLB TRD OR Blue Crush
    Totally Stock for now
    Ok so now who do I see in PNW? LOL:spending:
    RCTuningFL[OP] likes this.
  3. Feb 1, 2025 at 3:54 PM
    RCTuningFL
    RC
  4. Feb 1, 2025 at 4:26 PM
    PEAKIT
    PEAKIT Well-Known Member
    UT
    24 Off Road long bed Premium Taco.
    OME 888 nitro front, SPC upper arms,B110 rear shocks, Timberen bump stops, extended brake hoses, U bolt flip, sway bar delete, Dakar HD leaf pack with extra leaf, Snug top HD shell, MobTown Skid plate, cooper Maxx 255-85-16 4:88 Nitro gears,Spider trax 1.5 spacers, AirBedz, debadge, Pro grill.
    Does this tune the Transmission?
    I had the OV tune on my last tacoma that Matt the owner did for me. I really liked it. It changed the shift points and didn't start in 3rd gear anymore.
  5. Feb 1, 2025 at 4:38 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Yes, there are transmission tweaks with our calibration.
    I will say, the transmission tuning is mild in comparison to the 3rd Gen. These trucks did not require NEARLY as much rework for proper operation. But we've cleaned things up, yes.
    TRDPRO68 and PDKTaco like this.
  6. Feb 2, 2025 at 1:28 AM
    Light1984
    Light1984 Well-Known Member
    24 TRD OR Hybrid Bronze Oxide
    I hope by cleaned up you mean you fixed the aggressive shifts from 1>2 and 2>3 (which are even worse in cold weather). I also get a weird shudder sometimes downshifting around 48 mph. The transmission is definitely leagues better than the 3rd Gen though. I'm very excited for this tune. Thank you all for the hard work!
    One thing I am curious about is whether you can disable the auto start/stop with your tune? I have a hybrid OR and I'm in the habit now of shifting over to S8 which doesn't allow the ice to shut off. Or I switch on tow/haul if I need to go into reverse which also bypasses start/stop. Would be nice to not have to do that every time.
    PEAKIT and RCTuningFL[OP] like this.
  7. Feb 2, 2025 at 8:44 AM
    Taco2GR86
    Taco2GR86 Well-Known Member
    2021 TRD Pro 6MT [sold]; 2024 TRD OR 6MT
    Any mention of manual in the video?
  8. Feb 2, 2025 at 9:06 AM
    JustDSM
    Justin
    Ogden, UT
    Manuals are supported.
    I know the rev-hang question is on everyone's mind. We're working on it; while it's not something we addressed on the initial launch, we're actively working on it. It's not a simple switch that can be turned on/off.
  9. Feb 2, 2025 at 10:19 AM
    Light1984
    So I watched the video and I was wondering if you guys could explain Toyota's implementation of the drive mode selector? What parameters are getting modified when we switch from normal to sport mode for example? I assume that the OTT tune is much more comprehensive than what the drive mode selector changes but was just thinking it would be cool if Stage 0 could be flashed to normal and Stage 1 could be flashed to sport. I'm pretty confident this isn't possible based on the design of the systems from Toyota, just thinking out loud. I'm guessing normal and sport modes are just a small handle full of parameters that are part of the larger overall tune, but it would be cool for two tunes to be toggled on the fly.
    JustDSM likes this.
  10. Feb 2, 2025 at 11:15 AM
    JustDSM
    Justin
    Ogden, UT
    Great questions!
    The drive mode selector does a few things (I'm going to simplify things a bit), but generally speaking, there is a separate subset of maps selected based on the drive mode. The most noticeable changes you'll notice are the throttle sensitivity and shift point changes. The primary engine calibration, however, is unchanged based on drive modes. The same boost, fueling, spark, cam timing, etc. all remain the same no matter which drive mode is selected.
    Our calibration work involves more than simply selecting a different drive mode. However, within our calibration, we rework each drive mode independently (where applicable). With independent control, we can tailor the drive modes to our liking. Now, that doesn't give us infinite control, we have elected to retain the OE Toyota control strategy for the drive modes for our production files, as we do plan to put our calibration through CARB and obtain a 50-State EO with these calibrations, and thus custom coding and function was something we wanted to avoid. Future Staged tunes might incorporate custom coding features, but all that is TBD. So, at present, we can't have Stage 0 in Normal and Stage 1 in Sport, as you mentioned. I understand and see the potential in things like this, so it's not off the table, but it would require custom coding.
  11. Feb 2, 2025 at 11:25 AM
    Light1984
    Thank you for the explanation. I can't wait to give this tune a try and I appreciate the extra effort you are putting into these tunes to make them right and to protect the longevity/reliability of the vehicles.
    JustDSM[QUOTED] likes this.
  12. Feb 2, 2025 at 4:47 PM
    AR1978
    AR1978 Active Member
    Could you post a video of a 0-60 time comparing it to a Tacoma Hybrid model? Great review by the way.
    gmtech likes this.
  13. Feb 2, 2025 at 5:21 PM
    JustDSM
    Justin
    Ogden, UT
  14. Feb 3, 2025 at 4:21 AM
    smeredith
    smeredith Member
    SkyTaco
    (F)arvada,Colorado
    2024 TRD OR Tacoma , Celestial Silver
    Does the OTT impact the tow haul mode?
  15. Feb 3, 2025 at 5:08 AM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    no head to head 0-60 times same day same road. 50-70mph drag. 30-65 drag. real world head to head not one on a nice warm day and one on a snowy day with a sloppy road.. 3 trucks one stock one tuned and one hybrid!
    TurboDA6 and LN13 like this.
  16. Feb 3, 2025 at 5:58 AM
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    My only concern is for those of us within the Transmission TSB VINs....what a great excuse this would be for Toyota to deny replacing our transmissions if they fail.
    Vidman likes this.
  17. Feb 3, 2025 at 7:09 AM
    JustDSM
    Justin
    Ogden, UT
    What do you mean by “impact”?
    We have some specific tweaks done in tow-Haul, if that’s what you’re asking.
    PDKTaco likes this.
  18. Feb 3, 2025 at 8:49 AM
    PEAKIT
    UT
    What is happening when i am waiting to cross busy traffic on a hill and i floor it to merge and nothing happens? It seems to just pause 4 seconds before choosing 3rd gear which pulls it back out of boost with low rpm and lags. My 3rd Gen also did this before my OV tuned the trans.
  19. Feb 3, 2025 at 11:00 AM
    rat107
    rat107 Well-Known Member
    Kauai, HI
    2024 TRD Off Road 4x4, Automatic DC/LB Bronze Oxide
    aFe Momentum GT Cold Air Intake System w/ Pro DRY S Filter
    What does the truck run 1/4 mile with the tune?
  20. Feb 3, 2025 at 11:55 AM
    lvmusicman
    lvmusicman Well-Known Member
    In Canada you cannot make any modifications to your truck even just changing the exhaust will cancel all warranties on the vehicle unless it is approved by Toyota .Of course I am talking about mechanical or electronic or emissions.
