In Drive, but no go...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beginah, Aug 31, 2011.
  1. Aug 31, 2011 at 4:26 PM
    beginah
    beginah [OP] Well-Known Member
    I shift into "D" and release the foot brake and the truck doesn't move. I give it some gas, the engine revs and then the wheels go, like it needs to get past a sticking point. Other times i'll shift back into neutral and then into drive again and it works. This happens maybe once a month. Can someone please help with this?
    Thanks!!
  2. Aug 31, 2011 at 4:28 PM
    05TRD4WD
    05TRD4WD Well-Known Member
    Taylor
    Chesapeake, VA
    05 TRD OFFROAD 4X4
    ; 17 x 9 xd revolvers wrapped in 295/70-R17, volant cold air intake, Gibson exhaust, BHLM, Yellow fog covers, access rollup tonneau, kenwood dnx-9960, all jl audio, jl stealth box, 900/5 amp, Fab Tech 6" lift
    mine used to do that but it stopped doing it after a couple months
  3. Aug 31, 2011 at 4:32 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Check the fluid level.
  4. Aug 31, 2011 at 4:34 PM
    DrewH
    DrewH Well-Known Member
    x2 give some more info, someone will more than likely be able to help.
  5. Aug 31, 2011 at 4:38 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Sometimes when your truck gets wet like after you wa dsh it, water gets into the drum breaks and turns the brake dust into a sticky paste. Just need to drive it a bit.
  6. Aug 31, 2011 at 6:57 PM
    TacoDawgs
    TacoDawgs Well-Known Member
    2008 Radiant Red DCSB TRD OR 4x4
    Front 5100s at 1.75. Rear TSB. LoRider tonneau cover. OEM bed mat. OEM bug deflector. Illuminated 4x4 switch. In cab AC outlets. 400W anytime. EGR in channel window visors. Black badges. Rear weathertech liners.
    A belt slipping? I know it's not the same thing or even close to the same type engine but this happens all the time on my four wheeler. Shift to drive, hit the throttle, engine revs, then finally bike starts to move after it makes a sound like you just hit a dog (bad analogy but that's really what it sounds like). Just a thought, though maybe a stupid one. Good luck.
  7. Aug 31, 2011 at 7:00 PM
    TacoDawgs
    I figured I was way off base there. Thanks.
  8. Aug 31, 2011 at 7:05 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    In the name of Jesus, Devil come out!
  9. Aug 31, 2011 at 9:45 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    get a stick shift!
