In need of a MAF diagram
Discussion in '1st Gen. Tacomas (1995-2004)' started by CoreyF, Jan 21, 2010.
  1. Jan 21, 2010 at 9:12 AM
    CoreyF
    CoreyF [OP] Corey
    Suffolk, VA
    2013 Tacoma 4WD SR5 Access V6
    Does anyone have instructions on how to remove, clean, then reinstall the MAF sensor for a 1999 Tacoma 4x4 2.7L 3RZ-FE 5-speed. I heard you have to do this very carefully. I'm getting a CEL (P0420) randomly and I want to clean this area good and then see if I need to replace it or not. I have already replaced the O2's and checked the exhaust and done all other maintenance.
    Thanks,
    Corey
  2. Jan 21, 2010 at 9:15 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    It's just two screws at the intake tube coming out of the air box. They are loctited in so it will take some pressure to get them out. Just disconnect the NEG battery cable, then the sensor plug, remove the 2 screws and it's out. Just be careful spraying it and only use MAF or Electronic contact clear. NOTHING ELSE.
  3. Jan 21, 2010 at 11:18 AM
    CoreyF
    CoreyF [OP] Corey
    Suffolk, VA
    Thanks Ben, I figured it couldn't be too difficult. So I should just spray it down and let it dry only? No rubbing?
  4. Jan 21, 2010 at 12:01 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    YES, just spray it. Do not, for the love of God, touch it. Spary it, let it dry (evaporates pretty quick), spray it, dry, spray, dry...............etc. You get the picture.
  5. Jan 21, 2010 at 4:56 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Spray liberally and let dry, pretty simple.
  6. Jan 21, 2010 at 4:58 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    make sure you use MAF sensor cleaner NOTHING ELSE!
  7. Apr 22, 2011 at 2:21 PM
    newgalvestonian
    newgalvestonian New Member
    Jesi
    Galveston, Texas
    1999 SR5
    Just joined and you've already helped me fix my most aggravating problem. Sensors clean, light out and running like a panther she is!
