In need of fog lights for 2012 taco
Discussion in 'Lighting' started by toyotatacoma2012, Feb 11, 2013.
  1. Feb 11, 2013 at 8:29 PM
    toyotatacoma2012
    toyotatacoma2012 [OP] Member
    Sergio
    Texas
    2012 Tacoma Prerunner
    Guys I have a 4 banger taco that came with out fog lights. Would you all know of spots or websites I could find an oem light kit that will install? Please help!
  2. Feb 11, 2013 at 8:38 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Ebay would be a start......ur gunna need the wiring i think.......i dont think the 4 cylinders came prewired
  3. Feb 11, 2013 at 9:52 PM
    RedTacoDriver
    RedTacoDriver Out of my mind....be back later.
    Dale
    Portland, OR
    2012 Tacoma Regular Cab 2.7L
    BakFlipG2, Westin Nerf Bars, Harbor Freight Bed Jacks, Flame Devil Horns, vinyl raven emblems, intermittent wiper switch swapout More to come.
    No wiring and no relays. I am in the same boat.
  4. Feb 11, 2013 at 9:53 PM
    mclovin
    mclovin chicka chicka, yeah!
    RAFL UK
    16 TRD OR DC Barcelona Red
    Prev, 04 Xtra Cab Prerunner, 12 SR5 4x4 AC
    im going to have mine up for sale in a month or two if you can wait, probably just going to be the lights though.
  5. Feb 13, 2013 at 1:00 PM
    toyotatacoma2012
    Sergio
    Texas
    Thanks guys, I'll start with eBay and Amazon and go from there. I appreciate the response and knowledge.
  6. Feb 13, 2013 at 6:40 PM
    Rotorheader
    Rotorheader Active Member
    Don
    Eugene, OR
    2012 Prerunner 4-cyl
    Fogs for a 2009 Camry fit perfectly, eBay has them for $60. Add a $5 relay, and a couple hours, and you're good to go
  7. Feb 13, 2013 at 9:58 PM
    clc clc
    clc clc Well-Known Member
    Paul
    Carlisle, Pa
    2012 Reg cab 4x4
  8. Feb 14, 2013 at 6:21 AM
    toyotatacoma2012
    Sergio
    Texas
    Thanks McLovin, I have a prerunner so I think it is prewired with relay I just have to check. Don I will check for those fog lights after I make sure what my taco is set up for.
    CLC, how long have you had that kit installed?
    thanks fellas!
  9. Feb 14, 2013 at 1:43 PM
    clc clc
    Paul
    Carlisle, Pa
    2012 Reg cab 4x4
    I havent had a chance to install them yet but the kit comes with everything needed. Fast shipping time as well.
  10. Mar 11, 2013 at 11:55 AM
    MojoTaco
    MojoTaco Well-Known Member
    Idaho
    Base 4W
    Have you had a chance to install these yet?
    I bought this kit, and installed the lights, but the wiring diagram (where to tap in under dash) doesn't match my 2013 wiring. I haven't been able to figure out where to connect the wires inside the dash, and don't want to &^% it up. McDonough is still checking out why.
  11. Mar 11, 2013 at 2:43 PM
    Throttle8
    Throttle8 Member
    British Columbia
    13 DCLB SR5
    Hey MojoTaco
    Do the lights install like they came from the factory? or does it require some customization?
  12. Mar 12, 2013 at 9:29 AM
    MojoTaco
    Idaho
    Base 4W
    They are direct fit. I had my bumper off so it was easier, but I ended up loosening the wheel-well liner, and pushed it out of the way to get at the screws to remove the bezel cap. The lights just bolt right in with the same screws. The flat plastic trim piece that surrounds the light stays right in, so you don't have to remove that at all.
    I was impressed with the wiring harness. Everything you need wiring-wise is already there, and the wires to the relays have preinstalled sockets that just plug into the relays. No soldering or connectors to install.
    The only problem that I have is that my under-dash wiring does not match the pictures shown in the instructions, so I'm waiting for an answer from the techs before I attempt to make final connections.
    If I get a chance later today, I'll snap a pic of the installed lights, so you can see the fit.
  13. Mar 13, 2013 at 11:49 AM
    MojoTaco
    Idaho
    Base 4W
  14. Mar 14, 2013 at 8:39 AM
    Throttle8
    Throttle8 Member
    British Columbia
    13 DCLB SR5
    Thanks MojoTaco! I will have a look.
  15. Mar 14, 2013 at 1:12 PM
    blaks 06 pre
    blaks 06 pre Active Member
    brandon
    kent,WA
    06 prerunner
    So I have a 2006 prerunner v6 and was wondering if it had factory hook ups for fog lights Or what I might need I got a factory switch from a dealer friend
  16. Mar 15, 2013 at 9:57 AM
    MojoTaco
    Idaho
    Base 4W
    I thought prerunners came with fogs?
  17. Mar 15, 2013 at 11:09 AM
    blaks 06 pre
    brandon
    kent,WA
    06 prerunner
    It is a added feature just like running lights
  18. Mar 16, 2013 at 10:49 AM
    mdkingen
    mdkingen Hang on, I saw this done in a cartoon once!
    Las Vegas
    2012 Tacoma
  19. Mar 16, 2013 at 6:08 PM
    eric3187
    eric3187 Well-Known Member
    i will sell the factory fog lights from my truck (2011) i have no need for the lights.. cant help ya on with wiring though. im in houston tx, not sure where you are in tx OP
  20. Mar 25, 2013 at 9:49 PM
    NPComplete
    NPComplete New Member
    4 Cyl 4x4
    I just finished installing their kit on a new 2013 & it's probably about as smooth as it will get for this kind of job. It works as advertised; links up with the low beams/no DTRL. If you choose to go this route, here's a few things I found: The tie wraps in the kit are junk. Very brittle and break easily so get some elsewhere. The wiring harness is equipped with spade lug connectors, and those mate with T tap crimp on connectors to hook up to the under dash wires. I've found T tap crimp ons to be suspect, and these did not disappoint. I wound up soldering but perhaps you'll have better luck. Apart from that it's exceptional. The harness is sized correctly and the lights are Toyota OEM. Be sure to grab the two instruction sets off their web site as they are in color - the enclosed guide is not. I think I spent around 10 hours installing but I'm way too anal retentive.
