In need of new Rotors & Pads? EBC or OEM?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by moe2o4, Jul 14, 2017.
  1. Jul 17, 2017 at 5:53 AM
    moe2o4
    moe2o4 [OP] Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    So you guys really suggest going back to oem after them only lasting 34k? I need to get some brakes this week cause I may be doing a 1000 mile round trip to the beach and back the end of next week!
  2. Jul 17, 2017 at 6:01 AM
    Clearwater Bill
    Billy
    Largo Florida
    An excerpt from post #9.............. "If the pads are evenly worn, but just down in the 40% range, that means they have another 25k left. Which is about right."
    Which means they didn't 'last 34k'. They are on track for 60k, which is pretty normal for a rationally driven street vehicle.
    Have you considered taking some of the steps in that post and see what happens?
    And other than just being annoying with pulsation, driving your vehicle 1k with the brakes as is is not an issue.
  3. Jul 17, 2017 at 6:05 AM
    moe2o4
    Corey
    Pittsburgh PA
    My rotors are toast, when braking at 45+ the steering wheel has about a 1-2" wobble back and forth...... And if I'm gonna put new rotors on it its getting pads also so in another 10k I'm not putting pads on it!
  4. Jul 17, 2017 at 6:22 AM
    Clearwater Bill
    Billy
    Largo Florida
    OK. But the OE pads were not your issue. And they are not worn out.
    Since you've chosen not to try some of the suggestions in that post (which is fine) at least read the article on proper brake bedding, and do that with whatever your new brakes wind up being.
    Sorry my original post was too long and complicated. I'll move along now. :hattip:
    TacoJova likes this.
  5. Jul 17, 2017 at 6:32 AM
    ChrisK7UND
    ChrisK7UND Well-Known Member
    Colorado
    2017 Tacoma TRD Sport Double-Cab
    LED Interior Bulbs, Hondo Garage Phone Mount, Tacoma Bed Mat
    the_dau and moe2o4[OP] like this.
  6. Jul 17, 2017 at 6:37 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    I found the cause of your rapid tire wear.
    ChrisK7UND likes this.
  7. Jul 17, 2017 at 6:43 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    OEM OEM OEM. They last the longest. Get the more expensive OEM pads if they offer two choices. You want the 100% ceramic pads for best bite and no brake dust.
    As for pulsing "warped" rotors you can just turn them. The pulsing is from an uneven pad material on the rotor face. Usually caused when your brakes are super hot and you let them sit. It will burn pad to the rotor.
    Also make sure you properly bed the new pads and turned rotors to get a good pad layer on the rotor.
    ChrisK7UND and moe2o4[OP] like this.
  8. Jul 17, 2017 at 6:54 AM
    moe2o4
    Corey
    Pittsburgh PA
  9. Jul 17, 2017 at 6:59 AM
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    Your just gonna keep being in the same position in 30k miles if you don't bed them in. Just try rebedding you current set and see what happens
    moe2o4[OP] likes this.
  10. Jul 17, 2017 at 7:01 AM
    moe2o4
    Corey
    Pittsburgh PA
    • Find an open stretch of road that will allow you to safely stop your vehicle multiple times
    • Accelerate to 35 mph and apply moderate brake pressure to reduce your speed to 5-10 MPH
    • Repeat this process 3-4 times, the goal is to warm up your brake pads
    • Now turn up the heat even more by increasing your speed to 45 mph and braking down to 10 mph
      • Pro Tip: It’s important to avoid coming to a complete stop during this stage as it’s possible to melt brake pads against hot rotors.
    • Your stop-and-go session is now complete. Park the car and allow the brakes to fully cool for an hour. For best results, avoid pressing down on the brake pedal when parked
    JayRolla likes this.
  11. Jul 17, 2017 at 7:04 AM
    TacoJova
    Central Oregon
    I did mine from 60 to 20 8 times and drove a couple of miles with no brakes too let them cool
    moe2o4[QUOTED][OP] likes this.
  12. Jul 17, 2017 at 7:40 AM
    moe2o4
    Corey
    Pittsburgh PA
    Now the real question is.....
    Going to buy a new set of rotors and pads, should I throw the new rotors on and use my old pads if they aren't chewed up that bad since they got about 40% life left. Or just put the new pads on and call it a day? :confused:
  13. Jul 17, 2017 at 8:00 AM
    JayRolla
    Colorado Springs
    I would also add that you should drive without using brakes for a good amount of time before stopping after you bed them. Or he will be back to pulsing.
  14. Jul 17, 2017 at 8:00 AM
    JayRolla
    Colorado Springs
    I believe he needs new pads anyways from what I read.
  15. Jul 17, 2017 at 8:16 AM
    #35
    moe2o4
    Corey
    Pittsburgh PA
    #35
  16. Jul 17, 2017 at 8:44 AM
    #36
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Akebono ceramics. Zero dust.
  17. Jul 17, 2017 at 10:42 AM
    #37
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    #37
  18. Jul 17, 2017 at 1:19 PM
    #38
    moe2o4
    Corey
    Pittsburgh PA
    #38
  19. Jul 17, 2017 at 1:48 PM
    #39
    rz2mbc
    rz2mbc Well-Known Member
    if I keep the the truck I will put 4 wheel disc on all 4 corners.....
  20. Jul 17, 2017 at 1:54 PM
    #40
    santas212
    santas212 I'm on a boat!
    Georgetown, CT
    '09 DCLB, TRD Sport, Barcelona Red
    Mostly miscellaneous electronic mods.... -2 spare Electrical fuse blocks hard wired to the battery with a key on relay. -Hard Wired Radar detector over rearview mirror. -2 Dual Whelen Avenger blue LED emergency lights, one on each side of the rearview mirror. -EP911 Blue LED Light Bar & Traffic Advisor, Rear Windows. -4 corner amber strobes in stock lights. -Hardwired RF Scanner with external speaker under center console. -Huskyliner front splash guards -Fireband 2 way radio in center console. -Herculiner painted on hitch and skid plate. -Switch to power one 12v socket when truck is off. -AntiDark LED strip under hood with switch. -Timbren Rubber Springs - Rear -MBRP Offroad Cat-Back with Resonator -Duratrac's -Provisor -Color matched hood bug shield
    Get the EBC stage 5 kit, drilled slotted rotors with the yellow stuff pads and make sure you bed them in correctly they stopped AWSOME!!!!!!!!! as soon as a burn up another set of cheap Levines Auto pads and rotors im ordering another set of EBC off the web. Totally worth it!
    i have a EBC set for 5 lug trucks for sale but that probably wont work for you guessing you have a 6 lug. (long story)
