In need of some help
Discussion in 'New Members' started by 06toytacoma, Jan 1, 2017.
  1. Jan 1, 2017 at 6:09 PM
    06toytacoma
    06toytacoma [OP] New Member
    Paul
    06 toy Tacoma prerunner doublecab
    Toytec lift, Bilstein's front, Fox resivors rear, a/f calibrator, Doug thorly headers, banks monster exhaust, jet map sensor , urd tcai, strata monster rims , 285/70/17 BF Goodrich all terrains
    Hi I'm having trouble with my toy, setting codes po171,174 lean on both banks. I changed map sensor , I changed fuel pump with urd's upgrade kit and checked for vacuum leaks. I drive about 10 miles and codes set. I've been. Trying to get diagrams on truck and anything that would help. The dealer wants an arm and a leg to bring it in and I'm tapped from
  2. Jan 2, 2017 at 9:49 AM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Welcome!
    What engine mods do you have?
  3. Jan 2, 2017 at 10:38 AM
    06toytacoma
    Paul
    Urd tcai, Doug thorley headers , banks exhaust, urd maf calibrated, just recently changed map sensor jet performance , urd fuel pump upgrade aem hi flow fuel pumpand fuel pump because I thought that was the problem, I've checked for vacuum leaks I'm leaning toward the urd calibrater but don't know how to check it
  4. Jan 2, 2017 at 10:56 AM
    mattgecko
    South San Jose, CA
    Just a shot in the dark, have you tried putting the stock air intake back on and see if it still throws a code?
  5. Jan 2, 2017 at 10:59 AM
    06toytacoma
    Paul
    No , I've had the intake on there for over two years , threw the old one away
