In the market for a Taco and came across this...
Discussion in '1st Gen. Tacomas (1995-2004)' started by m32, Jan 13, 2011.
  1. Jan 13, 2011 at 9:11 PM
    m32
    m32 [OP] Well-Known Member
    Edwin
    2013 DCSB TRD
    Is this a good deal?
    2002 Tacoma extra-cab with 110k miles (2wd automatic). Clean condition and carfax. Auto/power everything/TRD package with the 4 cylinder motor for $7k?
    Edwin
  2. Jan 13, 2011 at 11:30 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    California
    2002 Tacoma TRD SR5, 3.4, 5spd
    -Bilstein 5100 Series shocks on all 4 corners -Rancho HD lift coils -1/4" Toytec driverside top plate spacer -Toytec 1" diff drop -Wheelers 1.5" AAL's -Toytec 1" lift shackles -Revtek extended length BPV bracket -285/75/16 BFG KO T/A's -Pro Comp rims -ET Conical tyle lug nuts -Spidertrax 1.5" wheel Spacers -CV Boot slide mod -TRD skid plate -Magnaflow 14" round muffler -Shortened tailpipe hidden behind framerail -Toyota bug deflector -Weathertech floormats -Black leather seat covers -Valentine 1 Radar Detector
    It sounds like a good price, it would be close to double that I'm sure if was for sale in this area here.
    Thoroughly look over and check everything on the truck. Drive it and see how it runs, take it a mechanic first to have them check it out if you like, especially to look over the frame to have them check for rust. If everything checks out, seems like it's in good shape and it was well taken care of, go for it if that truck is what you are looking for.
    The 4 cylinder has a chain, not a belt like the v6 has.
  3. Jan 14, 2011 at 5:27 AM
    m32
    Edwin
    2013 DCSB TRD
    Thanks for the info guys. I am new to the tacoma scene and recently changed jobs and need a pickup to drive to work/plant.
    Is there any specific recalls/known issues the 2002 4cyl taco have?
    The timing chain has not been changed. Any idea how much that runs? Is there anything else I should do while I change out the chain?
    Edwin
  4. Jan 16, 2011 at 6:55 AM
    m32
    Edwin
    2013 DCSB TRD
    Good news, picked up my 2002 Taco yesterday! I did some research on here and I believe the concensus is that I don't need to worry about replacing/maintaining the timing chain. Is there anything else I need to replace at 110k miles? Water pump? Tstat? Thanks!
  5. Jan 16, 2011 at 9:21 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor 15x8 D Window Steelies 33" BFG KM2s Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    First, welcome to tw. Congrats on the purchase.
    As a matter of fact, yes...there are a few items to consider. Tires! You'll soon realize you need bigger ones! But to fit them you'll need to add a lift to your truck! Might as well upgrade your springs and shocks while your at it. :D Better get a 2nd job to support your new truck. :eek:
    Any other questions???
