In town which is best D or 4
Discussion in 'Technical Chat' started by Charlot, Oct 20, 2014.
  1. Oct 20, 2014 at 2:46 AM
    Charlot
    Charlot [OP] Well-Known Member
    Ontario, Canada
    Tacoma TRD 2018 Upgraded
    Hi guys.
    This might seen like a dum question,but i just got my Tacoma about three weeks ago,and i have nt had a 4x4 in many many years.
    This one is a 2007 V6 4x4, with 90 ,000 kilometers.
    The previous owner told me that in town he was using a lot the 4 position besides the D ,then would use 4 when going on highways.(on 2x4 of course)
    So is it wiser yo stay on D all the time in town,or best yo use that 4 when we are going slow in town from one stop to another,which we do have a lots here in a small town??
    This might sound like a strange question,but would like to know what is best.
    Thank
    My regards
    Charly
  2. Oct 20, 2014 at 2:54 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Just use D. I can't see a reason to use 4.
    Someone else might chime in with a reason
  3. Oct 20, 2014 at 5:17 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Keeping it in 4, or even 3, when in town is fine. It will make for snappier accel, since it doesn't need to downshift everytime you want to move faster and makes braking a bit easier due to more engine braking.
    But, it will cost you mpg's. I've tried this on my Tacoma and on my last truck. Results were the same, better drivability, but costs milage. I keep it in D....
  4. Oct 20, 2014 at 2:16 PM
    Charlot
    Ontario, Canada
    Yes i think in D is just find.
    Not much difference in power either.
    Thanks
    Charly
  5. Oct 20, 2014 at 2:17 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I use 4 most of the time
  6. Oct 20, 2014 at 2:25 PM
    OZ-T
    Peter North
    British Columbia
    Also I've compared running around in 4 all the time and in D and for my never on the highway rural driving there is zero discernable fuel economy difference per tank
  7. Oct 21, 2014 at 2:56 PM
    Charlot
    Ontario, Canada
    OZ
    Thanks for the reply!
    So ,there is nt much difference!!
    Probably the speed has a big factor in gas consuming,,i think!!
    I noticed though that at high speed it will make a difference which is understandable!
    All the best
    Charly
  8. Oct 21, 2014 at 3:02 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    I use 4 for speed up to 55-60 and more "stop and go" traffic/roads. Usually only highway driving or known open roads will I use D.
  9. Oct 21, 2014 at 3:46 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The higher the gear you tranny can shift into, the slower your engine runs, the LESS gasoline you will burn.
    It is an AUTOMATIC transmission, and D is for drive. Let it do what it is made to do.
    IF you are going downhill and want to let the engine compression help slow you instead of the brakes only, then you can select a speed limiting gear down from 5th (D)... 4,3,2,L (1). Also on the rare times your truck is struggling up a grade and keeps trying to stay in a higher gear, but needs to down shift repeatedly, then drop it down manually... but watch your tachometer to not over-rev the motor.
  10. Oct 21, 2014 at 4:14 PM
    OZ-T
    Peter North
    British Columbia
    So driving around with it in D continuously hunting between 4th , 5th and TC locked 5th is the way to go because it's an AUTOMATIC ?
  11. Oct 21, 2014 at 4:55 PM
    Charlot
    Ontario, Canada
    Thanks David ,sound good!
    Regards
    Charly
  12. Oct 21, 2014 at 5:43 PM
    OZ-T
    Peter North
    British Columbia
    I think some people would be better served with a shifter limited to P D N R
  13. Oct 21, 2014 at 5:45 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Towing or steep grades I use 4.
  14. Oct 21, 2014 at 6:11 PM
    teneighty
    :rolleyes:
  15. Oct 22, 2014 at 9:28 AM
    David K
    Some people should have a manual tranny if they want to select the gears continuously?
    Obviously if the truck is hunting between two gears on a grade, I said that would be one of the rare times selecting a position other than drive makes sense. The other is to slow the truck as a position below D would by the top gear limit.
  16. Oct 22, 2014 at 2:22 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  17. Oct 22, 2014 at 2:29 PM
    OZ-T
    Peter North
    British Columbia
    Not that " rare " of an occasion for me , that's why I said I use 4 most of the time even though it is an AUTOMATIC tranny .
    I had a manual tranny truck for 14 years before I bought my Tacoma , and when the truck is lugging at 1200 rpm trying to hold D , I would rather it be in 4 and have some pick up and response , I would shift before that in my manual , why wouldn't I do the same in my auto ? I mean that's why it's selectable
  18. Oct 22, 2014 at 2:35 PM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    are we going to see a fight like in West Side Story?
    i will use this thread as a reminder to use 4 more; i'm always driving around town and it's hilly in Seattle and i've got slightly larger tires. i use 4 on hills in the hwy but usually not in stop and go street traffic where i would probably like it best.
  19. Oct 22, 2014 at 2:37 PM
    OZ-T
    Peter North
    British Columbia
    Can't hurt anything to try it out
  20. Oct 22, 2014 at 2:49 PM
    teneighty
    I always use 4, it's natural for me when I get in to shift right to 4. I sometimes forget if I het the highway and I hear the revs haha "shit!, shift up"
    I just hate when it lurks for 5th...
