inaccurate fuel indication
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tinker57, Jun 27, 2025.
  1. Jun 27, 2025 at 9:43 AM
    tinker57
    tinker57 [OP] New Member
    2015 Toyota Tacoma TRD off road manual transmission
    2015 Tacoma TRD off road manual transmission has inaccurate fuel indication. Shows empty when it has about a quarter tank and low fuel light comes on. We use the trip meter to stay safe from running out of fuel but we have to make sure we use the correct trip meter or the maintenance indicator comes on. I want to fix this fuel problem. Is there a fuel sensor somewhere besides the fuel tank? My Nissan had a sensor near the fill tube that had failed and was an easy fix. Will this problem show up as an error code on a code reader?
  2. Jun 27, 2025 at 10:57 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    No and no I believe are the answers. Though Im sure someone else will chime in soon
    Dm93 likes this.
  3. Jun 27, 2025 at 11:19 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    That is correct.
    The sending unit (for the gauge) is on the fuel pump housing.
    There are no code for the sending unit.
    The gauge operates off of resistance.
    Most of the time it's the sending unit.
    Almost never is it a wiring issue. (but it could be.....if you are really unlucky person).
    Dm93 likes this.
  4. Jun 27, 2025 at 11:23 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Personally, every time I've seen a fuel gauge problem it was always the sender in the tank.
    With the exception of Chevy, they had issues with clusters on all the trucks and suvs. But that gauge would flutter or go dead, not related to accuracy like you mentioned
    Dm93 likes this.
