Incoming Air Temp Far Higher Than ambient Temp
Discussion in '4 Cylinder' started by TRVLR500, Aug 18, 2019.
  1. Aug 18, 2019 at 8:19 PM
    TRVLR500
    TRVLR500 [OP] Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I'm just wondering why my Scangauge is saying that my incoming air temp is 118 when I know it's only around 80 degrees. My 2004 2.7 "seems" to be a little lower on power as well. While 2.7's are low on power to begin with I have noticed a decrease. Just installed a new fuel filter.
    Could it be the MAF sensor or is there another sensor in the intake system that senses the temperature of the air? There are no codes.
  2. Aug 19, 2019 at 2:49 AM
    ancient11
    ancient11 Well-Known Member
    robert
    tallahassee
    2019 4 cyl srsx ac
    My intake air is usually 10 + degrees higher than ambient (ultra gauge)
  3. Aug 19, 2019 at 2:57 AM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Heat soak. If you're just sitting there in idle traffic, the engine bay gets quite hot without airflow and that heat is absorbed by anything like plastic, metal, pretty much everything under the hood and changes the IAT more than you would think. Over 30° difference in your case.
  4. Aug 23, 2019 at 10:26 PM
    TRVLR500
    Wyoming
    That's what I was thinking it just seems the temp difference has been higher than a year ago. I guess it's probably nothing. Thanks for the info.
  5. Aug 24, 2019 at 2:58 AM
    ancient11
    robert
    tallahassee
    2019 4 cyl srsx ac
    Just noticed op that yours is a 4 cyl. Traded trucks a week ago and now I'm driving a 4 cyl. So far the temperatures are closer, even as little as 1 degree. Must be due to having more room under the hood. Up front theres enough room for a door gunner or a dog box, etc.
  6. Aug 26, 2019 at 9:51 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Where is the IAT sensor?
