Inconsistent fuel delivery issue.
Discussion in '1st Gen. Tacomas (1995-2004)' started by CitizenSnips5, Jan 5, 2023.
  1. Jan 5, 2023 at 6:49 AM
    CitizenSnips5
    CitizenSnips5 [OP] Well-Known Member
    Hey all,
    Chasing a bit of a white rabbit with this one, but I'll attempt to describe the issue as best I can here.
    1998 PreRunner Tacoma, I'd say 70% of the time fires right up after a few cranks. The other 30% of the time it'll either crank a few seconds longer before firing up, or in the worst cases will start right up and then immediately cut out and die.
    12v battery is healthy
    Replaced fuel filter & fuel pump with a new Denso
    Not seeing/smelling any sort of gas leaks. No codes on the truck other than a 0446 Evap every now and again.
    Where would you look next?
  2. Jan 5, 2023 at 6:57 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Have you cleaned your throttle body and the IACV? If not might help you out. Careful with how you clean the IACV though. I would look up Timmy the toolman on YouTube and watch his video on how to do it. My 98 with the 3.4 had those same problems you are describing. I also put some Lucas Fuel injector cleaner in the tank. Seemed to help but might just be snake oil. idk. Make sure to disconnect your battery before you do all that to reset everything. It will idle high for some time to relearn what's going on (normal). Good luck!
  3. Jan 5, 2023 at 8:44 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Fix your evap code.
    Probably time to change your injectors and or fuel pressure regulator.
    Bivouac likes this.
  4. Jan 5, 2023 at 10:54 AM
    CitizenSnips5
    I actually did clean out the Throttle body and IACV when I first got the truck. Was pretty gunked up with carbon, took it off the engine and got everything I could out.
    Injectors we're recently changed to the Fiveo MotorSport ones for the 3RZ. Haven't changed the fuel pressure regulator though, maybe I'll give that a shot next. I also have a new charcoal canister on the way.
    Xbeaus[QUOTED] likes this.
  5. Jan 5, 2023 at 11:47 AM
    Xbeaus
    Beau
    Sucks throwing parts at it. I wonder if you can get the fuel system pressure tested first? Even a compression check. I would assume the evap canister isn't cheap and if you don't use OEM you know what they say about that :) It could work and then it could be defective right out the gate. Let us know what you find out as I am really curious on what you find.
  6. Jan 5, 2023 at 9:08 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    I have similar situation on a 2rz......
    has new injectors from Five-o, new regulator, and the 446 code every other tank.....
    My only guess on mine is I didnt get the tank seal back right when I put last fuel pump in...
    I dont get that whoosh any more when I pop the gas cap.....
    When I stop and get gas with less than 1/8 tank......sometimes wont start until I put some gas in....and /or wait a little......
    got in trouble when I had to jump to another pump......the push of shame.....
    I bought a new seal.....but its a bit of a job getting to it.......unfortunately.......
    curious as to what you find......as I also have and extra used vsv valve and almost new canister I bought off our classifieds last spring.....
  7. Jan 17, 2023 at 9:21 AM
    CitizenSnips5
    If anyone was interested in the final outcome here is what I did:
    - Replaced the charcoal canister with an OEM Denso off eBay ($180 shipped)
    - Replaced the fuel pressure regulator with OEM eBay ($80 shipped)
    In replacing them I found the fuel line tubing connecting the regulator to the charcoal canister was a bit moist, and when I pulled the fuel pressure regulator out of the fuel rail I found the small o-ring on the stem to be cracked. This was most likely my biggest issue. The new regulator came with a new oring so I just replaced the whole thing since I had it, as well as putting the new charcoal canister in.
    Cleared my 0446, and 48 hours later so far so good. Starts up much faster with minimal cranks and so far the code has not returned.
  8. Jan 29, 2024 at 8:00 PM
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    still holding up good?
  9. Jan 30, 2024 at 5:07 AM
    CitizenSnips5
    Still holds up - no codes since!
    Stout890[QUOTED] likes this.
  10. Jan 30, 2024 at 6:49 AM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    That's good info, thanks for posting back what seems to be a win, I hope so for you.:thumbsup:
