Inconsistent idle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jbucky, Dec 31, 2023.
  1. Dec 31, 2023 at 4:28 PM
    jbucky
    jbucky [OP] Member
    Jane
    2008 Tacoma
    hi. i’m a bit of a noobie to this, so i’ll try hard to fit in as much as i can
    I have been trying to diagnose a rough idle problem.
    I have researched and tried a few things (listed at the end) but i’m at a loss as what to try next and i’m hoping you can help.
    I have a 2008 4cyl manual with 198,000miles and I adore it.
    here’s the idle problem:
    ambient temperature is 44 degrees on a cold engine
    startup
    needle bounced between 1100 and 1500 rpms
    white billows from exhaust
    after about 90seconds
    needle will bounce between 800 and 1000
    after about 3 mins
    no more white billows from exhaust
    temp reads at about 1/3rd up from Cold
    600 and 800 sometimes 900
    temp is now 1/2 way at about 4mins 30
    I drive for 20mins seems ok
    idle when stopped goes back to fluctuations between 600 and 900
    Cab fan blower is set to off
    I have checked MAF sensor and PCV valve and they seem fine.
    She has a newer air filter and an even newer battery that I put in.
    Any ideas on the peculiar idle?
    many thanks
  2. Dec 31, 2023 at 4:35 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Have you cleaned the throttle body and reset the learned values by disconnecting the battery for a few min?
  3. Dec 31, 2023 at 4:36 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Clean the MAF and the throttle body
  4. Dec 31, 2023 at 4:40 PM
    jbucky
    jbucky [OP] Member
    Jane
    2008 Tacoma
    The MAF looks very clean so I didn’t spray any cleaner on it.
    I haven’t cleaned the throttle body. I can probably do that. Is there a special cleaner or just brake cleaner?
    thanks
  5. Dec 31, 2023 at 4:41 PM
    Bishop84
    Bishop84 Well-Known Member
    There's actual throttle body cleaner, but WD40 or any penetrating fluid works as well. (they are solvents)
    jbucky[OP] likes this.
  6. Dec 31, 2023 at 4:41 PM
    rnish
    Tacoma 2nd gen
    ‘Get throttle body cleaner, some people use carb cleaner. No no no on the brake cleaner.
    jbucky[QUOTED][OP] likes this.
  7. Dec 31, 2023 at 5:20 PM
    oldtoyman
    oldtoyman Small bore freak
    Kevin
    North of Seattle
    1994 Harley heritage,2019 Honda Monkey,2023 klx300 , 2013 prerunner TRD off-road
    Do like others suggested. FYI when ever I do an oil change on any of my vehicles I take out the MAF and clean it. Doesn’t matter what it looks like. It does sound like a dirty throttle body.
  8. Dec 31, 2023 at 5:27 PM
    jbucky
    jbucky [OP] Member
    Jane
    2008 Tacoma
    thank you soooo much everyone :) . I will take in your expert advice.
    hny
  9. Dec 31, 2023 at 8:13 PM
    lr172
    lr172 Well-Known Member
    ‘11 DCLB 4.0 Auto
    Oil creates blue smoke, fuel creates grey or black smoke and water (50% of coolant) creates white smoke. With coolant flow into cylinders, the smoke usually only appears at startup. Are you having to refill coolant? Seeing little air bubbles in the radiator?The cycling of rpm would point me to a sensor issue. Dirty mafs and tbs tend to change the rpm at idle as well as rich or lean conditions, but usually do not create cycling rpm. Sometimes bad data to the ecu that keeps reacting by moving the throttle plate and keeps chasing the changes leading to the cycling. Rpm data comes from the cps, so that is also on the table.
  10. Dec 31, 2023 at 8:27 PM
    jbucky
    jbucky [OP] Member
    Jane
    2008 Tacoma
    hi, coolant levels seem to be fine and I don’t have to refill.
    The rpm ups and downs are definitely apparent at idle and depending on engine temperature it determines where the ups and downs span on the rpm range.
    when the engine is warm there is a constant up and down cycle / wave from 600 rpm to 800 rpm, sometimes 600- 900rpm.
    I was thinking a bad sensor also. but I don’t know which sensor would affect that symptom
  11. Jan 1, 2024 at 5:55 AM
    lr172
    ‘11 DCLB 4.0 Auto
    there is a feedback sensor in the throttle body. on scanner, go to live data and view the throttle position data pid along with rpm and look for any signs that something is wrong. If TP is moving, that means the TP is bad OR the ECU keeps moving it as it is trying to compensate for a unexpected rise or drop in RPM. also look at coolant temp for fluctuations. iat sensor is also possible, so observe that too.
  12. Jan 1, 2024 at 12:42 PM
    jbucky
    jbucky [OP] Member
    Jane
    2008 Tacoma
    again sorry to be a newbie , there seems to be a million odb scanners from $20 to $700. Do you have a scanner brand or model you recommend that can monitor the live data like you mention. Thank you so much in advance.
  13. Jan 1, 2024 at 1:13 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'd do the throttle body cleaning and see if that fixes it before you get too deep into it.
    jbucky[OP] and winkel like this.
  14. May 10, 2024 at 3:51 PM
    jbucky
    jbucky [OP] Member
    Jane
    2008 Tacoma
    hi. everyone!
    just a follow up.
    sorry for the delay, but cleaning the MAF sensor and the Throttle Body did the trick.
    Works super great now.
    Thank you sooooo much for your help.
    And yes the Throttle Body was quite dirty!
    Wasn't too hard of a job to do either. Hardest bit seemed to be getting the Toyota Parts guy at the dealership to sell me a Throttle body gasket... ha ha.... are you sure you want this,,, ha!
    Dm93 likes this.
  15. May 10, 2024 at 6:55 PM
    Clearwater Bill
    Billy
    Largo Florida
    Next time you encounter a silly catalog jockey like that, say 'Yes please. Me Jane. Just picking up what Tarzan asked for'
