Increase Ground Clearance
Discussion in 'Off-Roading & Trails' started by randyp5763, Apr 23, 2012.
  1. Apr 23, 2012 at 10:57 AM
    randyp5763
    randyp5763 [OP] Member
    Missouri
    11 Tacoma Off Road
    Hello everyone, looking to add ground clearance to my 2011 Taco, off road model. Does anyone know how to do this without using a lift kit? I've seen other tacomas like this but have never found the owner to ask them this question. I checked to see if anyone had asked about this but nothing popped up when I did the search. Thanks!
    Randy
  2. Apr 23, 2012 at 10:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW! The only way to achieve more ground clearance is by using larger tires. Depending on size, you either have to lift, or do alot of cutting.
  3. Apr 23, 2012 at 11:01 AM
    randyp5763
    Missouri
    11 Tacoma Off Road
    Thanks, I wish I would have joined this site sooner! When I read my owners manual and searched online for the biggest possible tires it was shown that I already have them installed from the factory. Oh well, not looking to do any real big mods, just wish the truck had more ground clearance. People post quick on here! Thanks for the response!
  4. Apr 23, 2012 at 11:38 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You can run 265/75/16 on stock Offroad wheels without rubbing
  5. Apr 23, 2012 at 11:42 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Are you 2wd or 4x4?
  6. Apr 23, 2012 at 12:24 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2 and I believe there's a 255 series tire that's even taller than can be run without rubbing.
  7. Apr 23, 2012 at 12:27 PM
    OZ-T
    Peter North
    British Columbia
    255/80/16 ?
  8. Apr 23, 2012 at 12:35 PM
    Pugga
    Massachusetts
    Beats me, I thought you were the one pioneering 255 series tires for max height :eek:
  9. Apr 23, 2012 at 12:37 PM
    medic2230
    Murph
    Bama! Roll Tide
    I don't think your going to be running that tire w/o a lift on it.
  10. Apr 23, 2012 at 12:39 PM
    OZ-T
    Peter North
    British Columbia
    You're thinking of 255/85/16
  11. Apr 23, 2012 at 12:44 PM
    medic2230
    Murph
    Bama! Roll Tide
    80 to 85 really gonna be that much of a difference?
  12. Apr 23, 2012 at 12:52 PM
    OZ-T
    Peter North
    British Columbia
    32" to 33 1/4"
  13. Apr 23, 2012 at 5:53 PM
    randyp5763
    Missouri
    11 Tacoma Off Road
    Its 4wd, though I think whats on it now w/o checking is 275's, the BF Goodrich tires.
  14. Apr 23, 2012 at 5:55 PM
    OZ-T
    Peter North
    British Columbia
    275/70/16 ?
  15. Apr 23, 2012 at 6:02 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Portal Axles :gossip:
    haha not even close to a budget though...
  16. Apr 23, 2012 at 7:06 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Just hack away until you can fit 255s. Shouldn't take much.
  17. Apr 23, 2012 at 7:54 PM
    valon5150
    valon5150 Well-Known Member
    Steven
    redding
    01 taco turd
    all pro lift, 33s, home made sliders, bumpers, skids
    if you're gonna start hacking just keep going till the 35's fit
  18. Apr 23, 2012 at 8:04 PM
    OZ-T
    Peter North
    British Columbia
    Uh , the OP isn't planning on lifting
  19. Apr 23, 2012 at 8:15 PM
    valon5150
    Steven
    redding
    01 taco turd
    No lift is required for 255's or 35's. if you are to use a standard 3 inch suspension lift it doesn't actually change anything but utilize your suspension droop. when stuffed you will be in the exact same spot as stock.
    Edit: If you use a 6 inch lift to fit either of those it is pointless. ruins your center of gravity. Well that is from a wheelers point of view...mall crawling is a completely different mind set that i dont try an understand
  20. Apr 23, 2012 at 8:16 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Look under your truck around the transfer case. You can improve ground clearance there by re-routing the exhaust crossover pipe.
