Increase in torque
Discussion in 'Performance and Tuning' started by HamerMan, Nov 20, 2013.
  1. Nov 20, 2013 at 1:10 PM
    HamerMan
    HamerMan [OP] Well-Known Member
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Is there any mods or bolt-ons that focus more on torque? Nobody really bothers with torque it seems, just HP.
  2. Nov 20, 2013 at 1:14 PM
    zacharypaul89
    zacharypaul89 Eat right, be fit, die anyway
    Zach
    Georgia
    2019 Quicksand Trd Offroad
    throttle body spacer should increase torque
  3. Nov 20, 2013 at 1:46 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Is there anything else that I can do?
  4. Nov 20, 2013 at 1:48 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    these are pretty much horseshit...
  5. Nov 20, 2013 at 1:49 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Weren't they for caurberated engines?
  6. Nov 20, 2013 at 1:56 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    supercharger or turbocharger. maybe headers. anything else is a waste of money.
  7. Nov 20, 2013 at 1:58 PM
    zacharypaul89
    Zach
    Georgia
    that's what I've heard
    yep
    I got curious and did some reading on them and it said they're pretty much useless on a fuel injected engine, but do serve a purpose on older carborated engines. Sorry, OP.
  8. Nov 20, 2013 at 2:06 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Supercharger, turbo, or save your money. No other mod will give you more power down low which is what I assume you are going for when you say that you want torque.
  9. Nov 20, 2013 at 2:06 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    I know superchargers are ungodly expensive.. And turbos need expensive supporting mods and stuff. Hmmm..
  10. Nov 20, 2013 at 2:07 PM
    zacharypaul89
    Zach
    Georgia
    If you don't mind me asking, why do you want more torque? Tacoma's are known for a lot of things, but torque isn't necessarily one of them
  11. Nov 20, 2013 at 2:10 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    not for 1st gens, you can get them new for ~2.7K
  12. Nov 20, 2013 at 2:13 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Exactly. Make more torque on a non torqueing engine
  13. Nov 20, 2013 at 2:13 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    How much used or in need of a rebuild?
  14. Nov 20, 2013 at 2:17 PM
    95 taco
    95 taco Battle Born
    From what i've read you can usually find them on craigslist for under 1km and a rebuild is 6-700 IIRC.
    Its not cheap, but not as expensive as the 2nd gen blowers.
  15. Nov 20, 2013 at 2:19 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    So about 1k less total?
  16. Nov 20, 2013 at 2:19 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    more torque just regear
  17. Nov 20, 2013 at 2:19 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Just like you, I'm only interested in mods that will improve torque, and don't care about horsepower. The best bang for the buck is long tube headers. They will make peak torque at lower rpms as well as fattening up the peak itself.
    If you do put on headers... don't open up your stock exhaust with high flowing aftermarket mufflers and pipes, because when you lose backpressure, along with it you'll also give up low end torque. However, you'll likely gain more top end horsepower, but it will come at the cost of low end torque. Unfortunately no one makes long tube headers for your engine. These JBA short tube headers for your 5VZ FE 3.4 are under $500 from 4wheelparts, but will not make as much low end torque as long tubes would.
    Greg
  18. Nov 20, 2013 at 2:20 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    But if theres a blower, then shouldn't all back pressure be eliminated?
  19. Nov 20, 2013 at 2:22 PM
    memario1214
    Colton
    Missoula, MT
    Okay, let me lay it out this way... You are 16 and you have got a Tacoma with the 3.4L in it. The way you are answering questions I am guessing that your budget is no more than a couple hundred bucks. Let's just say that on top of what you already have you were to get every single N/A mod available which would probably cost you around $1k (headers, fuel management, etc). What are you going to do with that additional 20 "pavement shredding" lb/ft of torque? On a truck like this you honestly probably won't even feel it. On top of it all you will have thrown off the vehicles stock exhaust scavenging and will probably lose a decent amount of torque down low. Buy a super/turbocharger or don't buy anything performance related at all unless you are just buying it for the sound or something. Go spend the $100 on getting some tail and I can almost assure you that it will pay better dividends in the future. :cool: Wait until you have a better platform for power and some real disposable income.
  20. Nov 20, 2013 at 2:43 PM
    zacharypaul89
    Zach
    Georgia
    But why? Just go get a Dodge 2500 v10.
