Increase tire size on 2012 4 door long bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bayrider, Jan 13, 2018.
  1. Jan 13, 2018 at 1:56 PM
    Bayrider
    Bayrider [OP] Active Member
    Kal
    Hatteras,nc
    4dr,4wd,v6 auto
    Can I go to 275/70/17 without changing rims
  2. Jan 13, 2018 at 2:06 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Only if you currently run 17” rims.
    JoefromPTC and ChemDawg like this.
  3. Jan 13, 2018 at 2:11 PM
    Bayrider
    Kal
    Hatteras,nc
    4dr,4wd,v6 auto
    The truck came with 17” rims. How much larger tire can run without changing rims. At what point will I need the speedometer calibrated
  4. Jan 13, 2018 at 2:42 PM
    JoefromPTC
    JoefromPTC Well-Known Member
    Joe
    Atlanta Georgia metro
    2005 Tacoma TRD Sport 4X4 6MT
    You never "need" to recalibrate your speedometer, it will just be a bit off. Most vehicles are not 100% accurate from the factory.
    This will answer all your questions on tire size: https://www.tacomaworld.com/tirecalc
    There are other considerations as well. One size up, you should be fine.
    Bayrider[OP] likes this.
  5. Jan 13, 2018 at 3:57 PM
    PackCon
    Connor
    The last number (17) in the tire size corresponds to the wheel size. As long as that number matches, they fit the wheel.
    Your speedometer will be off no matter what tire size you go with if its bigger or smaller than stock. Recalibration is up to you. I personally didn’t feel like spending the money to be able to do it.
    JoefromPTC likes this.
  6. Jan 13, 2018 at 6:18 PM
    Bayrider
    Kal
    Hatteras,nc
    4dr,4wd,v6 auto
    Thanks, guys. I drive on the beach looking for the fish and feel a wider footprint will help me stay on top.
  7. Jan 13, 2018 at 6:22 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Are stock or lifted?
  8. Jan 13, 2018 at 6:24 PM
    JoefromPTC
    Joe
    Just be careful not to go too wide, you'll start to rub. Especially if you're lifted in front, it pulls the upper control arm down and closer to the tire. The right tread pattern can also make a big difference.
    Bayrider[QUOTED][OP] likes this.
  9. Jan 13, 2018 at 6:39 PM
    Pigpen
    Dan
    Northwest Montana
    air down
  10. Jan 14, 2018 at 5:55 AM
    Bayrider
    Kal
    Hatteras,nc
    4dr,4wd,v6 auto
    Oh, I air down to 18lbs or lower at times because tourists who don’t know the difference think because the have a Jeep it’s no necessary. What they don’t realize is how much they’re tearing up the beach and heating their trannys.
    Bottom line is I need new shoes
