increase tire size
Discussion in 'Wheels & Tires' started by dirtroader, May 22, 2008.
  1. May 22, 2008 at 6:11 PM
    dirtroader
    dirtroader [OP] Member
    USA
    03 taco bone stock
    Hi guys I got a 03 5 lug with stock rims/tires with coilover and leafs in the rear. I would like to put in coil spring spacers and 30-31" tires. How much of a mpg loss should I expect if I put tires a few inches bigger/ wider on??
    I would like to keep the factory ride and want a little more clearance and a more aggressive look what would you recommend for a lift setup if any??
    thanks!!
  2. May 22, 2008 at 7:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The only lift I know of that will stil keep the factory ride is a spindle lift. WHen you preload the coil spring to achieve lift, you are going to stiffen the ride. As for mpg lost, you shouldnt lose more than 2 mpg. Be sure that when you are checking milage, you are accounting for the increase in tire size. If you dont you will get lower than normall figures. :)
  3. May 23, 2008 at 6:08 AM
    dirtroader
    USA
    03 taco bone stock
    Thanks does anyone have pics of a 5 lug lift installed on the truck. what would be a reasonable tire size for a 2 inch lift. i want a little more clearence for when the road ends and better looks
