Increasing Load Capacity?
Discussion in 'Towing' started by RickW, Aug 5, 2017.
  1. Aug 5, 2017 at 10:26 AM
    RickW
    RickW [OP] Well-Known Member
    Rick
    Stockton, Ca
    07 Tacoma daily driven
    I would like to tow a small camp trailer w/07 Prerunner. The problem is I had a lowering kit put on that drops the truck a couple of inches. Not a low rider but a normal ride height. The shop was trying to put in some air bags, but they just will not fit w/lowering kit.
    I will not remove the lowering kit to haul a trailer a couple of times. Back in the day I had air shocks on my El Camino. They were perfect for hauling extra weight occasionally.
    I'm looking for some kind of air lift as an option.
    A heavier rear spring is out of the question, I like the nice ride w/Bilsteins and 18" wheels.
    Any suggestions out there?
    TIA
    R
  2. Aug 5, 2017 at 10:30 AM
    Clearwater Bill
    Billy
    Largo Florida
    Hellwig helper spring
  3. Aug 7, 2017 at 12:05 PM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    I have Firestone RideRight air bags in my truck to help with my snowmobile trailer. The thing I like about them as opposed to heavy duty springs is the truck can be made to ride like normal when you aren't towing. But I don't know what to do if they don't fit. I think you should try a different installer, maybe a speciality shop? Because there is no magic with airbags. I would assume that if they don't fit, something should be possible to modify to make them work. Just might require some innovative thought.
  4. Aug 7, 2017 at 1:39 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    You legally cannot exceed what your truck is rated for. Any mods serve to only decrease sag.
    Misfit likes this.
  5. Aug 7, 2017 at 1:59 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Weight distributing hitch????
    I am not exactly sure what you are truely trying to accomplish. You mention increasing load capacity by posting in a towing sub forum and vaguely mention not wanting to change the lowering kit for the few times you need to tow. I can only assume you are trying to tow and don't want your rear end too low.
    WDH is the right tool for the job if I am understanding your issue. It is the safest way to tow / level your truck. Airbags or springs while great for leveling aesthetically don't fix the problem as well as a WDH in terms of towing safely with better control.
    Ruggybuggy and stickyTaco like this.
  6. Aug 7, 2017 at 2:01 PM
    Bishop84
    Bishop84 Well-Known Member
    The only air bags for these trucks were not meant for the smaller clearance of the lowered springs. I'm assuming you have a spring flip where the axle is over the springs.
  7. Aug 21, 2017 at 10:09 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    2nd on a weight distribution hitch...and some supple bump stops in case you end up bottoming it out.
