Increasing MPG without voiding warranty...
Discussion in 'Performance and Tuning' started by CFI AandP, Oct 14, 2013.
  1. Oct 25, 2013 at 5:08 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    05 prerunner trd off road DC
    Red hot glass pack muffler dumped preaxle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front and modified zuk mod coil spring lift for about 2" in rear paired with 5100 also. C channel front bumper. Maxxis bighorn 255/85/16
    Yeah I went 12 weeks not 52 my bad so 300/6.76 ~45years, which in a ToyotA would be possible for it to pay for itself but that's a long freakin time.
  2. Oct 25, 2013 at 5:12 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    If you are already getting 18-23 out of your 4.0, then you are doing better than most TW members.
    We've got people with the 2.7 that aren't getting that.
    There's no more to be had. Any mods and gadgets are not going to be cost effective.
  3. Oct 25, 2013 at 5:17 PM
    Trail Cat
    Trail Cat Well-Known Member
    Florida to NC
    2013 TRD Sport 4x4
    Bull Bar - TRD Exhaust - Predator Side Steps - Alarm - Anytime On Fog Lights mod - OBD UltraGauge II - LED Dome & Map Lights - LED Aux BackUp Lights - LED DRL - Gate Keeper mod - TRD bed Cup Holder & Bottle Opener - Center Console Lock mod - WeatherTech Mats - Kicker Hideaway - Rear Door Speakers - Spare Tire Extension Valve mod - Tail gate 3rd Brake Light Bar - Proline Wheels - Rear Diff Breather mod (left rear tail light area) - "Florida Tacoma's" sticker - BFG A/T KO2 tires -
    I got the Ultragauge, and well worth the 80 bucks.
    It will make you more aware of your mpg
  4. Oct 25, 2013 at 5:29 PM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Is there a shorter rear diff you could install? One with gears around 3.23 or so?
  5. Oct 25, 2013 at 5:56 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    My base model 5 lug 2.7 5 speed has really nice 3.31 street gears. 60 mph is only 2,000 rpm. It gets 23-24 mpg in the city, and 28-29 mpg on the freeway.
  6. Oct 25, 2013 at 7:11 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Here I didn't even do the math correct and then corrected you, I assumed your only mistake was getting $0.13 a week which should be $50 * 0.025 = $1.25.
    $1.25 a week is $65 a year or payback is 300/65 = 4.6 years.
    Still, there is no mpg gain with intakes, so the real payback is infinite years.
  7. Oct 25, 2013 at 8:56 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    LOL!
    Years ago, one of my customers was retrofitting his traffic signals with LED.
    At the time, red was about $100, but green and yellow were over $300.
    City Council gave the go-ahead for red immediately, but before approving green and yellow, they wanted a break-even schedule.
    He calculated the break-even date for red only (about a year) and all 3 colors (about 3 years, well within the 5 year warranty and 10 year expected life).
    They came back and asked for a breakdown BY COLOR!
    Yellow is only on about 10% of the time, and the break-even point doing only yellow would have been 37 years :D
  8. Oct 30, 2013 at 3:24 AM
    pkricorian
    pkricorian New Member
    virginia
    07 Tacoma TRD SR5
    Suspension, sway, air intake, heated seats, stereo/nav
    Agree - Cold air intake IS OEM standard. I went with the K&N because it was recommended on this forum, readily available used ($100), can be cleaned vice replaced, and allows for a bigger air gulp (Toyo Technician said the ECU by-passes fuel out the back end during rapid accelerations due to lack of air, well, it made seemed to make sense.)
  9. Nov 1, 2013 at 6:23 PM
    CFI AandP
    CFI AandP [OP] Well-Known Member
    Cory
    Florida
    The black Taco.
    Exactly why I did. After having the UltraGauge for a couple weeks, I have modified my behavior and have been getting ~25MPG out of a 2013 2WD DCSB. Highway driving 65-72MPH on flat terrain with the A/C on.
  10. Nov 2, 2013 at 8:21 AM
    AeroKen
    AeroKen Well-Known Member
    Kendrick
    Littlefun, CO
    2wd Tacoma, 2.7L 5spd
    None so far
    My thing is, MPG is the cherry on top, always. But I keep it in mind when doing work on the truck. Eg. I'll be making a soft top for the back, with at least enough structural integrity to be used as a boat rack (kayaks, canoes, etc) when needed. I am planning to use it for camping as well. Since I'm making it myself (maybe with the help of a friend partially), I am going to shape it to help improve highway mpg slightly. Unless I'm carrying significantly more than just two boats, it should help quite a bit, especially compared to putting them on the roof rack and letting them act as wind-sails (like I did on the corolla, or like you do with certain toppers).
    Planning on eventually having some undercarriage protection. The skid plates can also help smooth it out aerodynamically, if done right.
    As long as I stick to using the Tacoma for its main purpose, recreation, it should eventually have pretty sweet mpg. I just then need to quit being lazy and start using my scooter for the work commute more often, even in the bitter cold. Takes a lot of prep in the morning, but it's worth it when you get 90+mpg. The work commute accounts for most of my miles, across all the vehicles I've owned. Would like to change that.
  11. Nov 2, 2013 at 8:37 AM
    tooter
    Greg
    Los Angeles
    Using two wheel transportation saves more gas than anything that anyone could ever do to their Tacos. :thumbsup:
  12. Nov 2, 2013 at 3:13 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    There are quite a few 4-wheelers that get better mileage than my 2 wheeler.
    Worthywads averages his Tacoma comparably.
  13. Nov 2, 2013 at 6:34 PM
    worthywads
    Not as enjoyable of course. :turtleride:
  14. Nov 2, 2013 at 6:36 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    True true....
    And my 2-wheeler could be referred to as the Excursion of motorcycles.
    Fairing, hardbags and trunk, 200w stereo, 1600cc...
  15. Nov 3, 2013 at 6:16 AM
    #35
    ironmanjay
    ironmanjay Well-Known Member
    I just got my 2012 TRD v6 Taco last night and I am thrilled to get 16-21 mpg. I am coming off a Tundra getting 11.5-12.1 mpg in the city and 16-18 HWY.
  16. Nov 3, 2013 at 2:22 PM
    #36
    Rich91710
    Rich
    Los Angeles
    08 Base
    I really miss my 1st Gen Tundra with the 4.7, and wish Toyota would bring it back (with a return to 1st-Gen size in the Tacoma).
  17. Nov 16, 2013 at 2:17 AM
    #37
    steve2267
    steve2267 Active Member
    Colorado
    04 Double Cab Tacoma 3.4L 4WD/TRD
    Since purchasing my '04 DC Taco 3.4l V6 a few weeks ago, and reading the recommendations in this thread, I am averaging about 20.5mpg mixed driving. Seems to be between 19-20mpg all city driving. Highway seems to be about 23mpg. Cab high Leer topper. Avoid cruise control whenever hilly. Egg shell treatment of skinny right pedal. Try to keep RPMS <= 2000 even when accelerating. 60mph seemed to be a sweetspot on the highway before the topper, although she seems to accelerate very easily with a light foot to 65mph on level highway.
    From Denver up I-70 over the Eisenhower Tunnel to Silverthorn: 19.4 mpg
    From Kremmling/Granby over Berthoud Pass via US-40 / I-70 back to Denver: 25.1 mpg
  18. Nov 16, 2013 at 1:51 PM
    #38
    Rich91710
    Rich
    Los Angeles
    08 Base
    That is an interesting run with the elevation changes.
    Normally, the downhill will never regain the uphill losses, but my '03 Tundra made it from Grand Junction to Denver and back with some local cruising in Denver while there (blew in for a training class and left the next afternoon after the class was over).
  19. Nov 22, 2013 at 10:23 AM
    #39
    AeroKen
    Kendrick
    Littlefun, CO
    None so far
    The steep hills aren't as bad on i-70 if you don't feel the need to exceed 60mph.
    This was with my Corolla, so the difference could be much bigger on the Tacoma, but I used to make the trip from Littleton to Silverthorne (for a lower-blue/green mountain kayaking run) frequently and would track how much it cost me. One time, I saved 2 full gallons of gas one way by simply cruising at 60mph the whole way in 4th gear. I was just lazy that morning and didn't feel like shifting, lane-changing, etc, just to save a few minutes.
